 22hp vanguard running problems
22hp vanguard running problems Empty
PostSubject: 22hp vanguard running problems   22hp vanguard running problems Icon_minitimeJuly 21st 2013, 10:21 pm
My Husqvarna has a 22hp briggs and Stratton vanguard and it is surging like it will runs strong for a second or two then sort of stall but stays running and repeats for about 5 min till it dies any ideas?
http://www.lastdropgarage.com
Craftsman Dude
Craftsman Dude
PostSubject: Re: 22hp vanguard running problems   22hp vanguard running problems Icon_minitimeJuly 21st 2013, 10:39 pm
Sounds like the carb is dirty.
PostSubject: Re: 22hp vanguard running problems   22hp vanguard running problems Icon_minitimeJuly 21st 2013, 10:40 pm
That's what I thought so I cleaned it but still the same
Craftsman Dude
Craftsman Dude
PostSubject: Re: 22hp vanguard running problems   22hp vanguard running problems Icon_minitimeJuly 21st 2013, 10:43 pm
Well then im geusing you checked the fuel filter and gas tank vent , maybe a vacuum leak on the carb/intake.
PostSubject: Re: 22hp vanguard running problems   22hp vanguard running problems Icon_minitimeJuly 21st 2013, 10:44 pm
Maybe it's a gasket leak ill have to check
Craftsman Dude
Craftsman Dude
PostSubject: Re: 22hp vanguard running problems   22hp vanguard running problems Icon_minitimeJuly 21st 2013, 10:46 pm
That's what I meant.
PostSubject: Re: 22hp vanguard running problems   22hp vanguard running problems Icon_minitimeJuly 22nd 2013, 12:07 am
had the same problem on a honda. I had just cleaned the carb and put it back together and it ran just like that. finally figured out that the low speed side of the carb was clogged with some dirt. high speed side was perfect, low speed junky. took lots of carb cleaner and compressed air in all the little tiny ports to get it to run right. I would try that first.
PostSubject: Re: 22hp vanguard running problems   22hp vanguard running problems Icon_minitimeJuly 22nd 2013, 8:45 am
Alright thanks ill have to try that
PostSubject: Re: 22hp vanguard running problems   22hp vanguard running problems Icon_minitimeAugust 5th 2013, 8:45 pm
Alright so I cleaned all of the ports in the carb I got it to stay running and not stall but still surges I did a compression check
And it is good and it has strong spark any more ideas?
crazykid1994
crazykid1994
PostSubject: Re: 22hp vanguard running problems   22hp vanguard running problems Icon_minitimeAugust 5th 2013, 8:47 pm
check every gasket everywhere. my 17.5 hp had a slight gasket leak on the intake touching the engine. and it kept surging till i figured that out
PostSubject: Re: 22hp vanguard running problems   22hp vanguard running problems Icon_minitimeAugust 5th 2013, 8:49 pm
Alright I'll check and take some silicon to them
PostSubject: Re: 22hp vanguard running problems   22hp vanguard running problems Icon_minitimeAugust 6th 2013, 9:30 pm
Also I just thought of this I converted the tractor to front fuel tank and it has a fuel pump would that make my engine run like that
crazykid1994
crazykid1994
PostSubject: Re: 22hp vanguard running problems   22hp vanguard running problems Icon_minitimeAugust 6th 2013, 9:37 pm
as long as the fuel is still flowing like normal than it should not
PostSubject: Re: 22hp vanguard running problems   22hp vanguard running problems Icon_minitimeAugust 6th 2013, 9:42 pm
Well it's up higher so it has more flow
crazykid1994
crazykid1994
PostSubject: Re: 22hp vanguard running problems   22hp vanguard running problems Icon_minitimeAugust 6th 2013, 9:43 pm
that shouldnt matter than. the carb still limits how much fuel will get in
crazykid1994
crazykid1994
PostSubject: Re: 22hp vanguard running problems   22hp vanguard running problems Icon_minitimeAugust 6th 2013, 9:44 pm
i would try siliconing everything past the carb. thats how i fixed my 17.5 hp
» 22hp intek vtwin running rough
» 14/16 HORSE VANGUARD CARB
» Throttle return spring on a 22hp intec
» 1999 yard king 22hp gt ( murray widebody gt)
» 12.5hp vanguard
