 Can't get my peerless diff apart.
muddstir
TroyBilt Pony
Moloko
11 posters
Moloko
Moloko
Can't get my peerless diff apart. Empty
PostSubject: Can't get my peerless diff apart.   Can't get my peerless diff apart. Icon_minitimeJanuary 4th 2014, 9:55 pm
I'm trying to open up the Peerless diff in my Massey Ferguson 1200 garden tractor, and it's fighting me. I have all the case-half bolts out, and the brake drum off the left side. Something is holding it together inside. From what I can tell those wheel hubs are not what's holding it up, and besides I don't think those are coming off at all. What am I missing here?
Can't get my peerless diff apart. IMAG0063_zps07e06127
Can't get my peerless diff apart. IMAG0065_zpsa802a750
Can't get my peerless diff apart. IMAG0064_zpsb36ccc19
https://www.youtube.com/user/FuelInjectionSucks
PostSubject: Re: Can't get my peerless diff apart.   Can't get my peerless diff apart. Icon_minitimeJanuary 4th 2014, 10:03 pm
was there any clip or bolt holding the hubs to the axle? I think you have to remove the hubs to split the case, the halfshafts probably slide thru the axle sleeves
Moloko
Moloko
PostSubject: Re: Can't get my peerless diff apart.   Can't get my peerless diff apart. Icon_minitimeJanuary 4th 2014, 10:11 pm
There is an 1/8 between the hubs and the axle tubes, and the tubes arn't hitting the hubs when I try to separate it. It's hanging up somewhere else. I also removed the 4 bolts holding each axle tube on,and those won't come apart either.
TroyBilt Pony
TroyBilt Pony
PostSubject: Re: Can't get my peerless diff apart.   Can't get my peerless diff apart. Icon_minitimeJanuary 4th 2014, 10:46 pm
Your going to have to remove hubs to split it anyhow.. the diff is a bolted shut diff. Not like your typical vertical input.
muddstir
muddstir
PostSubject: Re: Can't get my peerless diff apart.   Can't get my peerless diff apart. Icon_minitimeJanuary 4th 2014, 11:54 pm
The axle shaft is probably your problem.  They leave a gap between the hub and outer axle tube so they don't rub together durning operation, but that allows the axle to get craped up in that area of (the gap).  Then with the axle being craped up (rusted) the bearing in the axle tube cant slide over it.
The hubs will need to come off.  Theres something in the center of the hub holding them on.  Once you get the hubs off clean up the axle stub sticking out.   Then if the trans axle has bolt on axle tubes (it kinda looks like it  in the pic) I'd take the time to unbolt them and get them off the axles.  You never know if there is a snap ring in there.  Then I would pull the cases apart.
On a side note I have a transaxle that looks like that, if you cant get it apart I can try mine but it will be later in the week before I can get to it.
Moloko
Moloko
PostSubject: Re: Can't get my peerless diff apart.   Can't get my peerless diff apart. Icon_minitimeJanuary 5th 2014, 4:58 pm
About to go back out and try it. The axle tubes do bolt on, and those don't want to come off either. I'll try to take the hubs off, but I think my big puller is at my friend's shop.
PostSubject: Re: Can't get my peerless diff apart.   Can't get my peerless diff apart. Icon_minitimeJanuary 5th 2014, 7:13 pm
Moloko
Moloko
PostSubject: Re: Can't get my peerless diff apart.   Can't get my peerless diff apart. Icon_minitimeJanuary 5th 2014, 7:47 pm
Worked on it for a few hours tonight. I got the "snap ring" off the end of the axle, but I can't get the hub off without my big puller, and probably using my oxy torch. Will try again tomorrow.
Moloko
Moloko
PostSubject: Re: Can't get my peerless diff apart.   Can't get my peerless diff apart. Icon_minitimeJanuary 6th 2014, 8:45 pm
Well the oxy/acetylene torch and my large jaw puller still didn't budge it. Gonna grab a flange-style puller for tomorrow and try again.
Moloko
Moloko
PostSubject: Re: Can't get my peerless diff apart.   Can't get my peerless diff apart. Icon_minitimeJanuary 7th 2014, 8:35 pm
Grabbed a flange style puller tonight. I think this axle is in there like Excalibur. All I succeeded in doing was pulling one of the wheel studs right through the hub. Going to give it one more chance tomorrow with longer bolts then I'm giving up on the posi idea and RTV'ing the diff back together.
Can't get my peerless diff apart. IMAG0073_zpsf5c835d4
Can't get my peerless diff apart. IMAG0074_zps0d5db3b9
PostSubject: Re: Can't get my peerless diff apart.   Can't get my peerless diff apart. Icon_minitimeJanuary 7th 2014, 8:50 pm
Fill the cup with like 1/4" of PBlaster and leave it sit for a few days. Might help.
Moloko
Moloko
PostSubject: Re: Can't get my peerless diff apart.   Can't get my peerless diff apart. Icon_minitimeJanuary 7th 2014, 8:55 pm
Yep, already did that.
PostSubject: Can't get my peerless diff apart.   Can't get my peerless diff apart. Icon_minitimeJanuary 7th 2014, 9:01 pm
go to a shop that has a 60 ton or more press, that has always worked for me.
PostSubject: Re: Can't get my peerless diff apart.   Can't get my peerless diff apart. Icon_minitimeJanuary 7th 2014, 9:11 pm
This.
Id say you could support the hub and air hammer it, but that might cause damage.
TroyBilt Pony
TroyBilt Pony
PostSubject: Re: Can't get my peerless diff apart.   Can't get my peerless diff apart. Icon_minitimeJanuary 7th 2014, 10:43 pm
Press it out. Or you could try the candle wax method... Thats how i got the stuck woodruff keys outta my axle.
PostSubject: Re: Can't get my peerless diff apart.   Can't get my peerless diff apart. Icon_minitimeJanuary 8th 2014, 3:37 am
Soak it in Vinegar!  Very Happy
WellThatsSurprising
WellThatsSurprising
PostSubject: Re: Can't get my peerless diff apart.   Can't get my peerless diff apart. Icon_minitimeJanuary 8th 2014, 6:22 am
I had some stubborn hubs on mine, one I used a pickle fork and air hammer to get off and the other I actually cut off with an oxy torch.
PostSubject: Re: Can't get my peerless diff apart.   Can't get my peerless diff apart. Icon_minitimeJanuary 8th 2014, 8:09 am
heat and a BFH (big f'en hammer) a dead blow hammer may be better so you dont crack anything
T-Dub13
T-Dub13
PostSubject: Re: Can't get my peerless diff apart.   Can't get my peerless diff apart. Icon_minitimeJanuary 9th 2014, 9:48 am
My vote is on a large hydraulic press, with heat and the wax trick (or soak in PB Blaster for a while). This combination of previously mentioned methods should get the hub off without damaging either component. Just be sure to hang the transaxle below the hub and press the axle downward. Have a soft landing prepared for the transaxle too!
Good luck!! And keep us posted.  Cool
» Peerless 600 "diff lock"
» adding a Limited slip diff to a 2500 peerless... Any ideas?
» Craftsman II GT 18 3spd Hi-Lo diff question
» peerless 834
» R.E.R Transmission and Snow Blower Auger Rear Diff
