 Peerless 600 "diff lock"
SearsRacing
6 posters
SearsRacing
Peerless 600 "diff lock" Empty
PostSubject: Peerless 600 "diff lock"   Peerless 600 "diff lock" Icon_minitimeMarch 20th 2017, 10:08 pm
Any idea of what is the best way to lock this tranny 3speed H pattern with reverse.
PostSubject: Re: Peerless 600 "diff lock"   Peerless 600 "diff lock" Icon_minitimeMarch 21st 2017, 8:59 am
If it's a Peerless 600 it should have the same differential carrier as the 801 series and what not. Matthew D and Sadeoo have locked their 801 series transaxles using strait axle conversions. Maybe you could check their build threads. P.S. You have yourself one tough transaxle my friend hahaha!
PostSubject: Re: Peerless 600 "diff lock"   Peerless 600 "diff lock" Icon_minitimeMarch 21st 2017, 9:17 am
PostSubject: Re: Peerless 600 "diff lock"   Peerless 600 "diff lock" Icon_minitimeMarch 23rd 2017, 2:31 pm
Can those methods be used to lock the 633? Atleast, I was under the impression they are similar cept the 633 has hi-lo?
Being that I'm using an iPod I can't look at them without getting logged off. Ha.
PostSubject: Re: Peerless 600 "diff lock"   Peerless 600 "diff lock" Icon_minitimeMarch 23rd 2017, 2:33 pm
I don't think the 633's are made my Peerless are they? I thought they where manufactured by Roper.
PostSubject: Re: Peerless 600 "diff lock"   Peerless 600 "diff lock" Icon_minitimeMarch 23rd 2017, 2:35 pm
I thought they were peerles... But I don't have one handy so I don't know lol
PostSubject: Re: Peerless 600 "diff lock"   Peerless 600 "diff lock" Icon_minitimeMarch 23rd 2017, 2:38 pm
Yeah I could be wrong hahaha.
PostSubject: Re: Peerless 600 "diff lock"   Peerless 600 "diff lock" Icon_minitimeMarch 23rd 2017, 3:16 pm
I will second that they were made by Roper.
Peerless 600 "diff lock" Sig115PROJECTS:
Peerless 600 "diff lock" Sig214Peerless 600 "diff lock" Sig314
sadeoo7
sadeoo7
PostSubject: Re: Peerless 600 "diff lock"   Peerless 600 "diff lock" Icon_minitimeMarch 23rd 2017, 4:29 pm
The 633 is made by roper. They do not use bevel cut spider gears, that means you cannot use some of the popular methods such as adding gears to lock it. Its a different configuration, not the same as a peerless.
If you want to lock your 600 series peerless i would use fozzy or doc lock with straight axle. If you go with a doc locker keep your wheel spaced closed to the trans so you dont bend an axle like me... Also be carefull with the keystock that you use, i had to weld my locker because my key broke. Checkout my yard man build if you want more info on the doc locker for that kind of trans. The case looks dofferent but the dofferential assembly is the same as a peerless 600.
nanner161988 likes this post
http://gdftech.com
PostSubject: Re: Peerless 600 "diff lock"   Peerless 600 "diff lock" Icon_minitimeMarch 23rd 2017, 10:23 pm
OP specified peerless 600 series
PostSubject: Re: Peerless 600 "diff lock"   Peerless 600 "diff lock" Icon_minitimeMarch 23rd 2017, 11:15 pm
There are some video's out there where people have flipped the orbital gears to lock a Roper 633. There are people with differing opinions about this whether it makes it weak or not.
» is it a good idea to lock a rear diff on my new craftsman lt 1000
» Can't get my peerless diff apart.
» adding a Limited slip diff to a 2500 peerless... Any ideas?
» Lock a 820 peerless with spider gears.
» Craftsman II GT 18 3spd Hi-Lo diff question
