| | R.E.R Transmission and Snow Blower Auger Rear Diff | |
W1ldyOvvnZ Member
Age : 28 Join date : 2011-12-06 Points : 5217 Posts : 499 Location : Winchester, ON, Canada
| Subject: R.E.R Transmission and Snow Blower Auger Rear Diff March 1st 2013, 11:01 pm | |
| I was thinking of this while I was taking apart a snowblower that was given to me, what if you were to take a transmission from a rear engine rider lawn tractor(the ones that have a chain drive on the output side of the transmission, the same thing that Fearless Front used for his Lifted Toro mudder) and then use a Snow blower Auger drive system and use that for a rear differential for a lawn tractor, allowing it to be easier to lift in one way,the rear end is already locked and less slippage of the belts. Also then you can make a rear suspension just like a truck, car, etc. and you can run leaf springs in the rear, coils, etc. independent suspension, etc. The only problem I see if anyone was to attempt this is would the snowblower auger be strong enough and handle the weight and abuse. | |
| | | Doug Site Owner
Age : 29 Join date : 2012-12-24 Points : 7745 Posts : 3044 Location : Lebanon County, PA
| Subject: Re: R.E.R Transmission and Snow Blower Auger Rear Diff March 1st 2013, 11:35 pm | |
| - W1ldyOvvnZ wrote:
- I was thinking of this while I was taking apart a snowblower that was given to me, what if you were to take a transmission from a rear engine rider lawn tractor(the ones that have a chain drive on the output side of the transmission, the same thing that Fearless Front used for his Lifted Toro mudder) and then use a Snow blower Auger drive system and use that for a rear differential for a lawn tractor, allowing it to be easier to lift in one way,the rear end is already locked and less slippage of the belts. Also then you can make a rear suspension just like a truck, car, etc. and you can run leaf springs in the rear, coils, etc. independent suspension, etc.
You could run a suspension without the RAGB off a snowblower using a RER transmission. Head Forum Administrator ** Chat Moderator ** Facebook Page AdminATLTF Facebook Page ** Chatbox ** How To Upload Pictures
Age : 49 Join date : 2012-04-05 Points : 5667 Posts : 959 Location : Mansfield, Ohio
| | | | W1ldyOvvnZ Member
| Subject: Re: R.E.R Transmission and Snow Blower Auger Rear Diff March 2nd 2013, 11:15 am | |
| i know you can run suspension off a RER Transmission but it would most likely be chain drive to the axle, you can run rear suspension off a transmission on most lawn tractors(independent rear suspension off of each side and have U-joints and custom make hubs, etc.). | |
| | | CornishMorgan Member
| Subject: Re: R.E.R Transmission and Snow Blower Auger Rear Diff March 2nd 2013, 12:49 pm | |
| - W1ldyOvvnZ wrote:
- i know you can run suspension off a RER Transmission but it would most likely be chain drive to the axle, you can run rear suspension off a transmission on most lawn tractors(independent rear suspension off of each side and have U-joints and custom make hubs, etc.).
Good idea but I'm not skilled enough to even think about doing that. Ill leave this to the experts to attempt. | |
| Who is online? | In total there are 33 users online :: 0 Registered, 0 Hidden and 33 Guests
