| Pony's MTD Seven Hundred (Battle Wagon) | |
+1583ratrodmurray Moose Doc Sprocket richie thomas simplicity14twin Craftsman1998 redlinemotorsportts LAWN MOWER MUDDER Thunderdivine camomanusa Lawren Wimberly mr.modified Creepycrawler 1997 Murray TroyBilt Pony 19 posters |
| Subject: Re: Pony's MTD Seven Hundred (Battle Wagon) January 20th 2014, 8:32 pm | |
| Got er Running today! Jet was clogged. Shoved some tiny wire thru it and it was clean. Then I drilled out my wheels with hole saw to get the old mtd hub out of it and made room for the new 3bolt hub to bolt up to it. Also. Got keyways for my motor pulley, tires.. and ofcourse.. I took no pictures lol | |
| Subject: Re: Pony's MTD Seven Hundred (Battle Wagon) January 25th 2014, 2:52 am | |
| Got the engine running good oil sensor and governor free.. next engine mod is rod and flywheel or swap for a big kohler if I come across one | |
| Subject: Re: Pony's MTD Seven Hundred (Battle Wagon) February 5th 2014, 8:33 pm | |
| Still got turfs on it from the burn out! But got the hitch plate, storage rack (under the hood), and hood fitted back up today, had to make a slight cut for the intake of my gx. Next will be tires go back on, front and rear bumpers.. This tractor is never being painted. Might just high gloss clear it, but that is all. I waxed her up today with Lucas Oil Speedwax today, that's why the chrome on the stickers is actually chrome for once.. Actually I was surprised to find they were chrome, i figured they were just silver... but onto the PICS! What color should I paint my rims, I'm thinking chrome, bedliner, red, or maybe just black or white... | |
Moose Established Member
Age : 35 Join date : 2014-01-12 Points : 4948 Posts : 919 Location : Defiance, Ohio
1997 Murray Veteran Member
| Subject: Re: Pony's MTD Seven Hundred (Battle Wagon) February 6th 2014, 10:15 am | |
| - 1997 Murray wrote:
- bedliner! looking good! that steering wheel is kinda weird thow
thats a go fast wheel you grab the bottom of it and think "***** Im going fast" when your going fast | |
83ratrodmurray Member
Age : 29 Join date : 2013-07-05 Points : 4289 Posts : 94 Location : Kentucky
Doc Sprocket Site VIP
camomanusa Member
Age : 25 Join date : 2013-09-15 Points : 4576 Posts : 467 Location : Greensburg, PA
bry_93 Member
Age : 31 Join date : 2014-01-02 Points : 4053 Posts : 78 Location : somerset, ky
camomanusa Member
| Subject: Re: Pony's MTD Seven Hundred (Battle Wagon) February 17th 2014, 9:30 am | |
| - camomanusa wrote:
- hows it sound with everything running? the music
Enough to hear the music, i need a better speaker tho, because the head unit has alot more to push before the speaker gets distorted. I'm gonna build little speakers for the fenders probably. below 2500 rpm i hear it perfectly, but above that i start to hear the engine more. | |
Age : 37 Join date : 2013-07-02 Points : 5016 Posts : 731 Location : Logan Ohio
| Subject: Re: Pony's MTD Seven Hundred (Battle Wagon) February 17th 2014, 12:52 pm | |
| - Creepycrawler wrote:
- I vote clear coat the hood and fenders and bed liner the rest
X2 that. It looks great stock. Bedliner the frame. | |
camomanusa Member
| Subject: Re: Pony's MTD Seven Hundred (Battle Wagon) February 17th 2014, 3:49 pm | |
X2 that. It looks great stock. Bedliner the frame. X3 that lol | |
| Subject: Re: Pony's MTD Seven Hundred (Battle Wagon) April 1st 2014, 10:07 pm | |
| Big update Sandblasted and painted seat. Built a front bumper. (got a bar for weight, weighs 40 lbs or so..) Broke it.. So mk2 Added a cup holder in the old gas filler. Tool Kit and tray Rear bumper The stack/glass pack painted up Pics during a romp when we stopped at exxon lol Future includes reworked exhaust, motor hop ups, maybe a gearing swap. | |
willis923 Veteran Member
