| Pony's MTD Seven Hundred (Battle Wagon) | |
+1583ratrodmurray Moose Doc Sprocket richie thomas simplicity14twin Craftsman1998 redlinemotorsportts LAWN MOWER MUDDER Thunderdivine camomanusa Lawren Wimberly mr.modified Creepycrawler 1997 Murray TroyBilt Pony 19 posters |
![TroyBilt Pony](https://2img.net/u/2812/37/66/46/avatars/942-63.jpg)
Join date : 2013-06-01 Points : 4736 Posts : 578 Location : West Virginia
![Pony's MTD Seven Hundred (Battle Wagon) Empty](https://2img.net/i/empty.gif) | Subject: Pony's MTD Seven Hundred (Battle Wagon) January 1st 2014, 10:07 pm | |
| Here is my entry boys, an all around offroad woods mowe based on a MTD 700 7hp mower from a long time ago (year still undetermined :/), with a gnarly military theme soon to come! What I've done so far before contest, mounted gx200 (won't run all of a sudden) Mounted front tires (fitting modifications still heavily needed) Took it apart.. Lots of mockup Removed transaxle Fixed a steering gear by welding and grinding in teeth. THAT IS ALL. It looks like more but seriously that' it. Heres my code bs... ![Pony's MTD Seven Hundred (Battle Wagon) 20140101_205635_zpsxnboq8xm](https://2img.net/h/i1119.photobucket.com/albums/k631/CBXPRESS/20140101_205635_zpsxnboq8xm.jpg) Here is where she started on day 1 when I brought it home about a month ago (haven't had much time to work on it) ![Pony's MTD Seven Hundred (Battle Wagon) 20131202_194236_zps9d8e824b](https://2img.net/h/i1119.photobucket.com/albums/k631/CBXPRESS/20131202_194236_zps9d8e824b.jpg) ![Pony's MTD Seven Hundred (Battle Wagon) 20131202_194244_zps8e974ee2](https://2img.net/h/i1119.photobucket.com/albums/k631/CBXPRESS/20131202_194244_zps8e974ee2.jpg) ![Pony's MTD Seven Hundred (Battle Wagon) 20131202_194256_zps452c16b5](https://2img.net/h/i1119.photobucket.com/albums/k631/CBXPRESS/20131202_194256_zps452c16b5.jpg) ![Pony's MTD Seven Hundred (Battle Wagon) 20131202_201403_zps63b42d72](https://2img.net/h/i1119.photobucket.com/albums/k631/CBXPRESS/20131202_201403_zps63b42d72.jpg) ![Pony's MTD Seven Hundred (Battle Wagon) 20131208_144848_zps39f09e29](https://2img.net/h/i1119.photobucket.com/albums/k631/CBXPRESS/20131208_144848_zps39f09e29.jpg) Here it is in mockup form. (back tires not mounted, its on a jack) ![Pony's MTD Seven Hundred (Battle Wagon) IMG_20131229_221747_zpstp7diy6n](https://2img.net/h/i1119.photobucket.com/albums/k631/CBXPRESS/IMG_20131229_221747_zpstp7diy6n.jpg) ![Pony's MTD Seven Hundred (Battle Wagon) 20131229_220127_zpszdvlas7t](https://2img.net/h/i1119.photobucket.com/albums/k631/CBXPRESS/20131229_220127_zpszdvlas7t.jpg) Had to remove transaxle after pounding on the hub and the axle came with it. (e-clip inside broke) ![Pony's MTD Seven Hundred (Battle Wagon) 20131230_175136_zpsir0js4q9](https://2img.net/h/i1119.photobucket.com/albums/k631/CBXPRESS/20131230_175136_zpsir0js4q9.jpg) ![Pony's MTD Seven Hundred (Battle Wagon) 20131230_182406_zpsfsekqzev](https://2img.net/h/i1119.photobucket.com/albums/k631/CBXPRESS/20131230_182406_zpsfsekqzev.jpg) Fixed the eclip lol ![Pony's MTD Seven Hundred (Battle Wagon) 20140101_175410_zpsr6kiyain](https://2img.net/h/i1119.photobucket.com/albums/k631/CBXPRESS/20140101_175410_zpsr6kiyain.jpg) While I was in there I locked the diff by welding the spiders to the pin. (like fearlessfront) (sorry no picture)
Last edited by TroyBilt Pony on January 25th 2014, 11:04 am; edited 1 time in total | |
1997 Murray Veteran Member
Age : 25 Join date : 2013-11-13 Points : 5372 Posts : 1311 Location : NW USA
![Pony's MTD Seven Hundred (Battle Wagon) Empty](https://2img.net/i/empty.gif) | Subject: Pony's Battle Wagon! January 1st 2014, 10:13 pm | |
| wow that looks old! strongest thing from MTD that I know of! very tough! good luck! | |
![Creepycrawler](https://2img.net/u/2812/37/66/46/avatars/999-39.jpg)
Age : 37 Join date : 2013-07-02 Points : 4945 Posts : 731 Location : Logan Ohio
![Pony's MTD Seven Hundred (Battle Wagon) Empty](https://2img.net/i/empty.gif) | |
![Lawren Wimberly](https://2img.net/u/2812/37/66/46/avatars/1273-1.jpg)
Age : 57 Join date : 2013-12-21 Points : 4731 Posts : 744 Location : Salem Illinois
![Pony's MTD Seven Hundred (Battle Wagon) Empty](https://2img.net/i/empty.gif) | Subject: Re: Pony's MTD Seven Hundred (Battle Wagon) January 2nd 2014, 4:38 pm | |
| - Lawren Wimberly wrote:
- I really need to find a transmission like that... what model was it again?
Its a 3speed with reverse. Model is Peerless 1205. | |
![Pony's MTD Seven Hundred (Battle Wagon) Empty](https://2img.net/i/empty.gif) | Subject: Re: Pony's MTD Seven Hundred (Battle Wagon) January 2nd 2014, 9:32 pm | |
| Update! Got transaxle in and locked! Now It just needs pulled back out, wire wheeled, and painted, then filled with oil! ![Pony's MTD Seven Hundred (Battle Wagon) 20140102_210554_zpslq7qpgr2](https://2img.net/h/i1119.photobucket.com/albums/k631/CBXPRESS/20140102_210554_zpslq7qpgr2.jpg) Got a bad ass shifter knob lol ![Pony's MTD Seven Hundred (Battle Wagon) 20140102_211606_zpslkoezzsy](https://2img.net/h/i1119.photobucket.com/albums/k631/CBXPRESS/20140102_211606_zpslkoezzsy.jpg) | |
camomanusa Member
![camomanusa](https://2img.net/u/2812/37/66/46/avatars/1098-34.jpg)
Age : 25 Join date : 2013-09-15 Points : 4505 Posts : 467 Location : Greensburg, PA
Thunderdivine Veteran Member
![Thunderdivine](https://2img.net/i/fa/i/avatars/gallery/Cine_Seigneur_des_anneaux/Lotr_129.jpg)
Join date : 2012-12-21 Points : 6469 Posts : 2101 Location : Norway, Europe
![Pony's MTD Seven Hundred (Battle Wagon) Empty](https://2img.net/i/empty.gif) | Subject: Re: Pony's MTD Seven Hundred (Battle Wagon) January 3rd 2014, 8:31 pm | |
| - Thunderdivine wrote:
Cool, and PS: remember we gonna build until June lol. - I got the same Knob, but mines blinking.
Lol, I love to attack stuff lol When I commit, its gametime for me! | |
![LAWN MOWER MUDDER](https://2img.net/u/2812/37/66/46/avatars/825-65.jpg)
Age : 23 Join date : 2013-04-08 Points : 5135 Posts : 913 Location : Central Pa
![Pony's MTD Seven Hundred (Battle Wagon) Empty](https://2img.net/i/empty.gif) | Subject: Re: Pony's MTD Seven Hundred (Battle Wagon) January 3rd 2014, 9:32 pm | |
| - LAWN MOWER MUDDER wrote:
- I would make full running boards going all the way back.
I might if i can figure Something out to move my clutch back towards me some. | |
![Pony's MTD Seven Hundred (Battle Wagon) Empty](https://2img.net/i/empty.gif) | Subject: Re: Pony's MTD Seven Hundred (Battle Wagon) January 3rd 2014, 11:42 pm | |
| ![Pony's MTD Seven Hundred (Battle Wagon) PedalDesign_zps6d2c8abd](https://2img.net/h/i1119.photobucket.com/albums/k631/CBXPRESS/PedalDesign_zps6d2c8abd.png) Might do something like this to get my clearance in the front.. Although, I think I'd rather make some axle mods.. We will see. I am gonna try and make some fenders for the front tires. | |
Craftsman1998 Veteran Member
![Craftsman1998](https://2img.net/u/2812/37/66/46/avatars/1167-45.jpg)
Age : 26 Join date : 2013-10-30 Points : 5078 Posts : 1068 Location : New jersey
![Pony's MTD Seven Hundred (Battle Wagon) Empty](https://2img.net/i/empty.gif) | Subject: Re: Pony's MTD Seven Hundred (Battle Wagon) January 18th 2014, 12:55 pm | |
| - TroyBilt Pony wrote:
- Got it running.. jet was clogged. Might drop out of the compition due to other reasons here on the forum tho.
If you want your buddie to enter have him take one picture..... Not hard. | |
simplicity14twin Member
![simplicity14twin](https://2img.net/u/2812/37/66/46/avatars/1393-18.jpg)
Age : 26 Join date : 2014-01-13 Points : 4040 Posts : 112 Location : New Hampshire
richie thomas Veteran Member
![richie thomas](https://2img.net/u/2812/37/66/46/avatars/156-8.jpg)
Age : 29 Join date : 2011-08-04 Points : 6326 Posts : 1434 Location : east dublin georgia
![Pony's MTD Seven Hundred (Battle Wagon) Empty](https://2img.net/i/empty.gif) | Subject: Re: Pony's MTD Seven Hundred (Battle Wagon) January 18th 2014, 6:30 pm | |
- Removed. -Doug
no need for gettin pissed, he took 3 pics, and the admin didn't think it was enough, they make the rules, everyone has to follow them | |
Doc Sprocket Site VIP
![Pony's MTD Seven Hundred (Battle Wagon) Empty](https://2img.net/i/empty.gif) | Subject: Re: Pony's MTD Seven Hundred (Battle Wagon) January 18th 2014, 6:43 pm | |
| Don't get your shorts twisted. If your pal shows up here, he can contact me, and I'm sure we can work it out. But as things are, you're not doing him any favours by getting pissy. He was issued the warnings to hopefully get his attention. | |
![Pony's MTD Seven Hundred (Battle Wagon) Empty](https://2img.net/i/empty.gif) | Subject: Re: Pony's MTD Seven Hundred (Battle Wagon) January 20th 2014, 8:32 pm | |
| Got er Running today! Jet was clogged. Shoved some tiny wire thru it and it was clean. Then I drilled out my wheels with hole saw to get the old mtd hub out of it and made room for the new 3bolt hub to bolt up to it. Also. Got keyways for my motor pulley, tires.. and ofcourse.. I took no pictures lol | |
