| lifted Murray | |
+7richie thomas Lawren Wimberly redzz02 Ariens YT11 Doc Sprocket redlinemotorsportts 1997 Murray 11 posters |
1997 Murray Veteran Member
| Subject: lifted Murray January 1st 2014, 11:55 am | |
| this is my first mower, and it has taught me a lot about mechanical things, and is about to teach me more. this will be for pulling and mudding, and ridding in general. it will be lifted about 10" and will be powered by a 17 hp tecumsea. (sorry if you can't read the sign, it was raining and it got wet) | |
| Subject: Re: lifted Murray January 1st 2014, 11:59 am | |
| Nice! Wide body's have some of the easiest frames or bases to work with when modding, should be in your favor! | |
| Subject: lifted Murray January 1st 2014, 12:18 pm | |
| thanks for the compliment! the only problem I've had is the dashes are made of cheep steel, and they like to break. that and you have to lay in the dirt to work on it...... but if it is lifted it should be better. | |
Doc Sprocket Site VIP
| Subject: lifted Murray January 1st 2014, 12:56 pm | |
| thanks for the compliment doc! | |
Age : 27 Join date : 2012-10-31 Points : 5161 Posts : 745 Location : The Wyo-Braska Panhandle
| Subject: Re: lifted Murray January 1st 2014, 1:41 pm | |
| I like the idea of lifting it but 10" is a bit too much in my honest opinion. maby a 6" would be better. | |
| Subject: lifted Murray January 1st 2014, 3:19 pm | |
| I know, but with the suspention and 6" taller tires I figured it would be close to that. | |
Last edited by 1997 Murray on January 1st 2014, 10:15 pm; edited 1 time in total (Reason for editing : posted twice) | |
redzz02 Site VIP
1st Place Build-Off 2015
1st Place Build-Off 2017
1st Place Build-Off 2018
| Subject: lifted Murray January 1st 2014, 10:16 pm | |
| thanks for the compliment redzz02! do you still have the craftsman with suspention on the front? the green one? that is what truely inspired me to do this. | |
| Subject: lifted Murray January 3rd 2014, 11:15 am | |
| in this build I plan on using: a peerless 700 230 suzuki rear axle 24" snow tires on the front 26" ags on the back using a chinese atv for parts for beaks, shocks, and tubing (I've spent over $700 on parts for this quad and it still is a loong way from finished) | |
Age : 57 Join date : 2013-12-21 Points : 4802 Posts : 744 Location : Salem Illinois
| Subject: Re: lifted Murray January 3rd 2014, 12:18 pm | |
| so are you building a Quad or a tractor? | |
| Subject: lifted Murray January 3rd 2014, 3:07 pm | |
| the tractor with quad suspention. | |
| Subject: lifted Murray January 3rd 2014, 5:54 pm | |
| a plan for the front suspension | |
| Subject: lifted Murray January 6th 2014, 11:21 am | |
| the front tires that will go on it (by the way, it is REALLY cold out there ) | |
| Subject: lifted Murray January 8th 2014, 3:50 pm | |
| well, here is a little update. got the swing arm off of the quad today, and it fits in the frame almost perfectly. i will try to get pics soon. | |
| Subject: lifted Murray January 14th 2014, 11:22 am | |
| do you guys think these are a good canidate for a 700? i know where there two of these by my grandpa's house...... | |
| Subject: lifted Murray January 23rd 2014, 10:36 am | |
| could someone move this to my other thread? I'm dropping out of the contest, too much to do and I can't get the pats I need, and the frame does not have enough room for the 700. | |
| Subject: lifted Murray February 4th 2014, 12:40 pm | |
| could someone merge this thread with my other one? thanks. | |
| Subject: Re: lifted Murray April 1st 2014, 12:50 pm | |
| not going to make the suspention oh well. got the clutch back in and "fixed" the stock pulley mount had to do that because I didn't have a a pulley that would fit on it, but i had a John Deere pulley that was the right od but the wrong id. now to take the tranny out of the MTD and figure out how to make hubs and buy a 5" pulley for the back. | |
| Subject: Re: lifted Murray April 1st 2014, 3:49 pm | |
| workn on gettin the tranny out of the mtd (206) | |
richie thomas Veteran Member
| Subject: Re: lifted Murray April 1st 2014, 5:14 pm | |
| - 1997 Murray wrote:
- workn on gettin the tranny out of the mtd (206)
lucky s.o.b. i need a mst-206 lol | |
| Subject: Re: lifted Murray April 2nd 2014, 1:33 pm | |
| you can have it if you trade me for an 820! | |
| Subject: Re: lifted Murray April 4th 2014, 11:12 am | |
| got it repainted, made a pulley, need a belt. If it stops raining I will try to get pics. | |
| Subject: Re: lifted Murray April 8th 2014, 4:05 pm | |
| just need a belt... and finish my rims | |
| lifted Murray | |
