| Lifted Murray 4x4 | |
+31997 Murray Doc Sprocket GenevaCustoms 7 posters | Author | Message |
GenevaCustoms Member
Age : 27 Join date : 2013-09-24 Points : 4412 Posts : 315 Location : Florida
| Subject: Lifted Murray 4x4 January 1st 2014, 7:35 am | |
| Here it is again, no work since the last post in other thread lol its a friggin pile | |
| | | Doc Sprocket Site VIP
| Subject: Re: Lifted Murray 4x4 January 1st 2014, 9:24 am | |
| Start off by getting the framework/lift all welded up, then start with the actual mechanical engineering. ... lol | |
| Subject: Re: Lifted Murray 4x4 January 1st 2014, 9:43 am | |
| Kinda looking for an overview here... Convince me you've a lot of work ahead? Like more than 50%? Hint! | |
| Subject: Re: Lifted Murray 4x4 January 1st 2014, 6:07 pm | |
| Completely redo the frame, weld it all solid, paint it, make, lift, rebuikd another, tranny, do some engine work on the 10hp, mount 4 truck wheels to mtd wheels, get a seat, change motor moubts, rebuild steering, make front steering knuckles, widen the wheel base by 4 inches on eavh side, everything .... lol | |
| | | | 1997 Murray Veteran Member
| Subject: Lifted Murray 4x4 January 3rd 2014, 5:32 pm | |
| good idea! after taking the bolts out 2 times the holes are worn out.......... | |
| Subject: Re: Lifted Murray 4x4 January 4th 2014, 8:15 am | |
| I have two directions to go with this... use a 10hp flathead, with a torque converter to a mini transfer case witch runs driveshafts and U joint down to the trannys, or, put a suzuki 160, horizontal shaft fourwheeler motor, run it to a jack shaft eitch will drive the front and rear straught axles. I woukd do this but will the length if the chain be to long?
| | | | bry_93 Member
Age : 31 Join date : 2014-01-02 Points : 4053 Posts : 78 Location : somerset, ky
| Subject: Re: Lifted Murray 4x4 January 6th 2014, 1:31 pm | |
| Yep it does good luck with it sounds like its gonna be pretty cool | |
| Subject: Re: Lifted Murray 4x4 January 6th 2014, 1:40 pm | |
| you could use small solid axles out of a jeep or something and shorten them! Also could run a peerless as your transfer case maybe?
| | | matt-man Member
Age : 27 Join date : 2013-07-26 Points : 4388 Posts : 221 Location : North Fort Myers, Florida
| Subject: Re: Lifted Murray 4x4 January 6th 2014, 4:30 pm | |
| I like the idea about the ATV drivetrain I think it would work better | |
| | | camomanusa Member
Age : 25 Join date : 2013-09-15 Points : 4576 Posts : 467 Location : Greensburg, PA
| Subject: Re: Lifted Murray 4x4 February 3rd 2014, 11:18 pm | |
| sounds like it is planned good, have you done any progress? | |
| Who is online? | In total there are 29 users online :: 0 Registered, 0 Hidden and 29 Guests
