| Craftsman1998's Cub Cadet Puller build | |
+26TokyoDrift99 lincolnmaniac B440 willis923 MSteele323 camomanusa redlinemotorsportts mr.modified Moose TroyBilt Pony rarbaugh07 Ariens YT11 richie thomas T-Dub13 matt-man Thunderdivine Krawler86 bry_93 Lawren Wimberly 1997 Murray GenevaCustoms redzz02 Jedi Doc Sprocket Doug Craftsman1998 30 posters |
Craftsman1998 Veteran Member
| Subject: Re: Craftsman1998's Cub Cadet Puller build February 3rd 2014, 8:19 pm | |
| - camomanusa wrote:
- Just red the entire thing, love it so far! Keep it up its coming along great!
Thanks I could put red on it but it wouldn't look right. When i got it it was yellow and white. So i want to keep it that color. | |
Age : 26 Join date : 2013-10-30 Points : 5149 Posts : 1068 Location : New jersey
| Subject: Re: Craftsman1998's Cub Cadet Puller build February 4th 2014, 6:57 pm | |
| Ok so i found the yellow paint i need. I found it on amazon now i just need to order it. I think im going to order 10 cans of yellow do you guys thing thats enough? | |
Jedi Member
Join date : 2013-11-27 Points : 4060 Posts : 44 Location : Georgia
Thunderdivine Veteran Member
| Subject: Re: Craftsman1998's Cub Cadet Puller build February 8th 2014, 4:49 pm | |
| - Craftsman1998 wrote:
- Ok so i found the yellow paint i need. I found it on amazon now i just need to order it. I think im going to order 10 cans of yellow do you guys thing thats enough?
Depends on the paint and coverage, but it would suck to order to little | |
| Subject: Re: Craftsman1998's Cub Cadet Puller build February 8th 2014, 4:56 pm | |
| Yea it would so i would rather order to much and i used about 8 cans of primer and still have to do the fenders. and it will take 2 to do the fenders. So i figured it would take as many cans of yellow as primer so i thought i would just get 10. | |
| Subject: Re: Craftsman1998's Cub Cadet Puller build February 8th 2014, 5:00 pm | |
- Yea it would so i would rather order to much and i used about 8 cans of primer and still have to do the fenders. and it will take 2 to do the fenders. So i figured it would take as many cans of yellow as primer so i thought i would just get 10.
So you can't get it in quart tins? and brush it on I had to do that on my JD mower deck i restored. Usually bad covering on yellow also, so you better get a light primer color. | |
| Subject: Re: Craftsman1998's Cub Cadet Puller build February 8th 2014, 5:05 pm | |
So you can't get it in quart tins? and brush it on I had to do that on my JD mower deck i restored. Usually bad covering on yellow also, so you better get a light primer color. And i used gray for somethings and white | |
| Subject: Re: Craftsman1998's Cub Cadet Puller build February 8th 2014, 5:07 pm | |
- Does it look good when you brush it on. And that will take awhile so i thought spray cans would be faster.
Yeah looks like any normal paint job, if you do it right. But it can't be cold, since the paint need to be warm to flow and get that nice finish. | |
| Subject: Re: Craftsman1998's Cub Cadet Puller build February 8th 2014, 5:10 pm | |
Yeah looks like any normal paint job, if you do it right. But it can't be cold, since the paint need to be warm to flow and get that nice finish. Well thats a problem lol because its really cold right now and i cant really wait. I could paint in the basement but i dont want dust in the paint. | |
| Subject: Re: Craftsman1998's Cub Cadet Puller build February 8th 2014, 5:14 pm | |
Yeah looks like any normal paint job, if you do it right. But it can't be cold, since the paint need to be warm to flow and get that nice finish. Well thats a problem lol because its really cold right now and i cant really wait. I could paint in the basement but i dont want dust in the paint. Yeah lol, well you could "get dust in it", then rub it down or wet sand it then do clear coats. | |
| Subject: Re: Craftsman1998's Cub Cadet Puller build February 8th 2014, 5:30 pm | |
| Yea im going to clear coat it. but 141 days is a long time but when your painting and you need to put the whole tractor together it isnt alot of time. | |
camomanusa Member
Age : 25 Join date : 2013-09-15 Points : 4576 Posts : 467 Location : Greensburg, PA
| Subject: Re: Craftsman1998's Cub Cadet Puller build February 9th 2014, 4:48 pm | |
| Ok so i bought some engine paint its semi gloss. And im cleaning the block with kerosene. And when im done that i can start painting the engine. And once that drys i can paint the other pieces Like the flywheel,starter,engine shroud. | |
