| Craftsman1998's Cub Cadet Puller build | |
+26TokyoDrift99 lincolnmaniac B440 willis923 MSteele323 camomanusa redlinemotorsportts mr.modified Moose TroyBilt Pony rarbaugh07 Ariens YT11 richie thomas T-Dub13 matt-man Thunderdivine Krawler86 bry_93 Lawren Wimberly 1997 Murray GenevaCustoms redzz02 Jedi Doc Sprocket Doug Craftsman1998 30 posters | |
Craftsman1998 Veteran Member
| Subject: Re: Craftsman1998's Cub Cadet Puller build August 29th 2014, 7:21 am | |
| Yeah when i bought it i thought someone just but a hole in the front of it but after looking at it more i noticed that the exhaust lines up with the hole so i knew it when thru the hole. And i like the way it looks. | |
| | | T-Dub13 Established Member
Age : 55 Join date : 2013-12-06 Points : 4572 Posts : 540 Location : Central MA
| Subject: Re: Craftsman1998's Cub Cadet Puller build August 29th 2014, 9:55 am | |
| Yeah, do rear wheel weights first. Then, if the suitcase weights are too pricey, you could mount one or two pipes sticking out front and put barbell type weights on them. I can't wait to see this thing pull some serious stuff. I bet that with the right weighting, you could pull that camper around the yard no problem. Or all your tractors stuck in gear. Hmm, Even drag a couple tractors sideways! It may take some experimentation and practice... But with the right gear selection, right engine RPM and right weight distribution, you are going to be amazed at what that tractor can do. I think we will all be amazed! | |
Age : 26 Join date : 2013-10-30 Points : 5152 Posts : 1068 Location : New jersey
| | | | Sponsored content
| Who is online? | In total there are 87 users online :: 0 Registered, 0 Hidden and 87 Guests
