 Craftsman1998's Cub Cadet Puller build
TokyoDrift99
lincolnmaniac
B440
MSteele323
camomanusa
Moose
TroyBilt Pony
rarbaugh07
T-Dub13
matt-man
Krawler86
bry_93
GenevaCustoms
redzz02
Jedi
Craftsman1998
30 posters
Go to page : Previous  1, 2, 3, 4, 5, 6 ... 12 ... 20  Next
rarbaugh07
Craftsman1998's Cub Cadet Puller build - Page 5 Empty
PostSubject: Re: Craftsman1998's Cub Cadet Puller build   Craftsman1998's Cub Cadet Puller build - Page 5 Icon_minitimeJanuary 23rd 2014, 10:27 pm
I pulled with my 122 a few years in the 900 lb and the 1000 lb classes with ag style tires and did pretty well all stock. It weighed 890 lb with me on it.
Craftsman1998
Craftsman1998
PostSubject: Re: Craftsman1998's Cub Cadet Puller build   Craftsman1998's Cub Cadet Puller build - Page 5 Icon_minitimeJanuary 23rd 2014, 10:58 pm
Ok thanks for the info. Do you have pictures of you pullers? i would like to see them. and my mower is about 750 pounds. so its pretty heavy.
Craftsman1998
Craftsman1998
PostSubject: Re: Craftsman1998's Cub Cadet Puller build   Craftsman1998's Cub Cadet Puller build - Page 5 Icon_minitimeJanuary 24th 2014, 9:31 am
Removed
Last edited by Craftsman1998 on January 27th 2015, 6:19 pm; edited 1 time in total
Craftsman1998
Craftsman1998
PostSubject: Re: Craftsman1998's Cub Cadet Puller build   Craftsman1998's Cub Cadet Puller build - Page 5 Icon_minitimeJanuary 24th 2014, 5:13 pm
Craftsman1998's Cub Cadet Puller build - Page 5 IMG_20140124_121545_zps131323ad
Started body puttying the fenders today.
Craftsman1998
Craftsman1998
PostSubject: Re: Craftsman1998's Cub Cadet Puller build   Craftsman1998's Cub Cadet Puller build - Page 5 Icon_minitimeJanuary 24th 2014, 5:15 pm
Craftsman1998's Cub Cadet Puller build - Page 5 IMG_20140124_121553_zps38822023
And i got the hood done. just adding a little more primer then when thats done i can paint it.
Craftsman1998
Craftsman1998
PostSubject: Re: Craftsman1998's Cub Cadet Puller build   Craftsman1998's Cub Cadet Puller build - Page 5 Icon_minitimeJanuary 25th 2014, 11:49 am
Removed
Craftsman1998
Craftsman1998
PostSubject: Re: Craftsman1998's Cub Cadet Puller build   Craftsman1998's Cub Cadet Puller build - Page 5 Icon_minitimeJanuary 27th 2014, 6:02 am
well one of are pipes froze and split this morning so me and my dad have to fix it. so i dont know if ill have time to work on my tractor today. but im going to try and squeeze time in today.
Craftsman1998
Craftsman1998
PostSubject: Re: Craftsman1998's Cub Cadet Puller build   Craftsman1998's Cub Cadet Puller build - Page 5 Icon_minitimeJanuary 27th 2014, 6:09 pm
Craftsman1998's Cub Cadet Puller build - Page 5 IMG_20140127_145619_zpsb17ae9e6
Craftsman1998's Cub Cadet Puller build - Page 5 IMG_20140127_145641_zpsf2a940af
Craftsman1998's Cub Cadet Puller build - Page 5 IMG_20140127_145734_zpsf0d607f0
Got the hood done
Craftsman1998
Craftsman1998
PostSubject: Re: Craftsman1998's Cub Cadet Puller build   Craftsman1998's Cub Cadet Puller build - Page 5 Icon_minitimeJanuary 27th 2014, 6:10 pm
Craftsman1998's Cub Cadet Puller build - Page 5 IMG_20140127_150622_zps7811752a
Sanding some brackets
Craftsman1998
Craftsman1998
PostSubject: Re: Craftsman1998's Cub Cadet Puller build   Craftsman1998's Cub Cadet Puller build - Page 5 Icon_minitimeJanuary 28th 2014, 8:53 am
Is it better for my tractor to be ungoverned or should i not remove the governor. I dont want to blow it up but having it ungoverned might make it more powerful. What are your guys thoughts????
Craftsman1998
Craftsman1998
PostSubject: Re: Craftsman1998's Cub Cadet Puller build   Craftsman1998's Cub Cadet Puller build - Page 5 Icon_minitimeJanuary 28th 2014, 10:05 am
Removed
Last edited by Craftsman1998 on January 27th 2015, 6:20 pm; edited 1 time in total
PostSubject: Re: Craftsman1998's Cub Cadet Puller build   Craftsman1998's Cub Cadet Puller build - Page 5 Icon_minitimeJanuary 28th 2014, 10:30 am
just remove the govener and use your head, don't rev it high as it will go, just 2 grand or under. always remember:
Craftsman1998's Cub Cadet Puller build - Page 5 Bkfdzm10
T-Dub13
T-Dub13
PostSubject: Re: Craftsman1998's Cub Cadet Puller build   Craftsman1998's Cub Cadet Puller build - Page 5 Icon_minitimeJanuary 28th 2014, 10:35 am
My initial thought (Un-governed Foot Throttle cheers ) may not be the best approach for a pulling tractor, now that I'm thinking of it.
I think we need to ask some questions about the tractor before we make an educated suggestion. (the education would be mine of course because I don't know)...
* will this be a competition pulling tractor only?
* Will this tractor be used for romping / rallying as well?
I'm thinking that during a pull, the governor will help you maintain a certain rpm and adjust power according to available traction. This may be a benefit to a puller since you don't want to spin the tires and lose traction.
Also, if your governor is working correctly, it will have the ability to open the throttle wide open. So it shouldn't limit power,just RPM.
So I think it depends on the end use of the tractor really. I'm also really curious to see what the other guys say because I'm certainly not an expert in pulling. But I thought the subject should be explored a little more deeply than just stomping the throttle WFO. You may benefit from some of the finesse that the gov can offer.
TroyBilt Pony
TroyBilt Pony
PostSubject: Re: Craftsman1998's Cub Cadet Puller build   Craftsman1998's Cub Cadet Puller build - Page 5 Icon_minitimeJanuary 28th 2014, 12:17 pm
Why couldn't you buy a tach and just watch your rpms like a real puller?
T-Dub13
T-Dub13
PostSubject: Re: Craftsman1998's Cub Cadet Puller build   Craftsman1998's Cub Cadet Puller build - Page 5 Icon_minitimeJanuary 28th 2014, 1:17 pm
Just like the difference between an automatic and a standard trans: I like standard because I like to be in control, but on the drag strip the automatic will win.  This is because it's programmable, and is faster reacting than a person's brain-to-foot connection and eliminates human error.
Most of my experience in traction comes from MX racing.  On the start, it's usually best to start a gear high and slip the clutch.  This limits wheelspin and also saves time by eliminating the 1st to 2nd shift time.  The key is to either limit wheelspin with the clutch or with the throttle, really it's a bit of both.
I'm thinking that possibly the governor will help limit human error in this case.  I can imagine it's hard to keep a foot on a foot throttle steady as the machine is heaving and bouncing trying to find traction.  It's hard enough with a twist throttle!
Just thinking out loud here and again, I'm no expert.  Maybe experience from a different type of competition can cross over???
I do know a little about traction...  Razz Laughing  (#238, me)
Craftsman1998's Cub Cadet Puller build - Page 5 Holeshotstill_zps1efed457
TroyBilt Pony
TroyBilt Pony
PostSubject: Re: Craftsman1998's Cub Cadet Puller build   Craftsman1998's Cub Cadet Puller build - Page 5 Icon_minitimeJanuary 28th 2014, 1:54 pm
I know more than plenty about mx.. raced from age 6 to 14 rode from 3 til now. lol I was always good on starts until I got to the corner...
I always would start a gear high and rev her to the max, sit on the gas cap and let her rip.. Concrete starts i sat neutral position and took off in second 3/4 throttle until i hit the dirt. Of course this was after a bad ass burnout lol
T-Dub13
T-Dub13
PostSubject: Re: Craftsman1998's Cub Cadet Puller build   Craftsman1998's Cub Cadet Puller build - Page 5 Icon_minitimeJanuary 28th 2014, 2:17 pm
Cool!  Cool  I've been riding for 35+ years. The new bikes are so good it's like cheating! That's why I race a vintage open class bike. Razz  Wink Laughing
Craftsman1998
Craftsman1998
PostSubject: Re: Craftsman1998's Cub Cadet Puller build   Craftsman1998's Cub Cadet Puller build - Page 5 Icon_minitimeJanuary 28th 2014, 3:06 pm
The more i think about it the more i dont want to blow up the engine  Neutral
Craftsman1998
Craftsman1998
PostSubject: Re: Craftsman1998's Cub Cadet Puller build   Craftsman1998's Cub Cadet Puller build - Page 5 Icon_minitimeJanuary 28th 2014, 3:07 pm
And the tractor will be used for tractor pulling and pulling things around the yard. no offroading
T-Dub13
T-Dub13
PostSubject: Re: Craftsman1998's Cub Cadet Puller build   Craftsman1998's Cub Cadet Puller build - Page 5 Icon_minitimeJanuary 28th 2014, 4:51 pm
I was just thinking out loud back there. I'm still not 100% convinced either way, but unless you compare results between two identical machines, one with and one without a governor it will all be speculation and opinion.  Wink
I don't think there will be a big difference anyway. So unless it's a serious competition machine, just do what you feel comfortable with. You can always do a foot throttle to a Gov, then eliminate the Gov at a later date.  Cool  cheers
Craftsman1998
Craftsman1998
PostSubject: Re: Craftsman1998's Cub Cadet Puller build   Craftsman1998's Cub Cadet Puller build - Page 5 Icon_minitimeJanuary 28th 2014, 5:12 pm
Yep
Craftsman1998
Craftsman1998
PostSubject: Re: Craftsman1998's Cub Cadet Puller build   Craftsman1998's Cub Cadet Puller build - Page 5 Icon_minitimeJanuary 28th 2014, 8:01 pm
Ok i guess ill leave it the way it is so i dont break parts lol
Craftsman1998
Craftsman1998
PostSubject: Re: Craftsman1998's Cub Cadet Puller build   Craftsman1998's Cub Cadet Puller build - Page 5 Icon_minitimeJanuary 29th 2014, 12:19 pm
Craftsman1998's Cub Cadet Puller build - Page 5 IMG_20140128_115949_zps0e6e994d
Craftsman1998's Cub Cadet Puller build - Page 5 IMG_20140128_115936_zpsfdc60219
Craftsman1998's Cub Cadet Puller build - Page 5 IMG_20140128_115928_zpse687fff3
Craftsman1998's Cub Cadet Puller build - Page 5 IMG_20140128_110202_zpsdd962aaa
Almost done cleaning behind the dashboard. once thats done i can prime it. Very Happy
Craftsman1998
Craftsman1998
PostSubject: Re: Craftsman1998's Cub Cadet Puller build   Craftsman1998's Cub Cadet Puller build - Page 5 Icon_minitimeJanuary 29th 2014, 12:21 pm
Craftsman1998's Cub Cadet Puller build - Page 5 IMG_20140128_110154_zpsebafe713
Linkages are ready to be painted
Craftsman1998
Craftsman1998
PostSubject: Re: Craftsman1998's Cub Cadet Puller build   Craftsman1998's Cub Cadet Puller build - Page 5 Icon_minitimeJanuary 29th 2014, 12:22 pm
Craftsman1998's Cub Cadet Puller build - Page 5 IMG_20140127_145821_zpsd0db3347
Got the transmission pump all cleaned up
Craftsman1998
Craftsman1998
PostSubject: Re: Craftsman1998's Cub Cadet Puller build   Craftsman1998's Cub Cadet Puller build - Page 5 Icon_minitimeJanuary 29th 2014, 12:24 pm
Craftsman1998's Cub Cadet Puller build - Page 5 IMG_20140128_110131_zps9c619dc5
Craftsman1998's Cub Cadet Puller build - Page 5 IMG_20140128_110126_zps6df37db2
Craftsman1998's Cub Cadet Puller build - Page 5 IMG_20140128_110120_zpsba75309b
Got it painted with the first coat then ran out of paint
Page 5 of 20Go to page : Previous  1, 2, 3, 4, 5, 6 ... 12 ... 20  Next
» CUB CADET 104 Puller
» [DNF][2020 Build-Off Entry] mrshaft696's The Grey Boy Sears puller
» 1250 Cub Cadet Build
» MasonMcK's Off-road/Mudding Cub Cadet [2016 Build-Off Entry]
» The 1968 SS12/18 puller
All-Terrain Lawn Tractor Forum :: Competitions and Challenges :: Build-Off Competition :: Build-Off Archives :: 2014 Archive :: Finalists Archive-
