 messed up steering?
modmaniac
modmaniac
messed up steering? Empty
PostSubject: messed up steering?   messed up steering? Icon_minitimeDecember 25th 2013, 12:05 pm
Yesterday i was romping with a friend on my tractor, the steering on my mower is one of those gear ones, when i hit a bump i guess the steering wheel gear skipped teeth and now it only turns left. how could i fix this? i tried re adjusting it but that didnt help...
camomanusa
camomanusa
PostSubject: Re: messed up steering?   messed up steering? Icon_minitimeDecember 25th 2013, 12:46 pm
i have the same problem, but mine also has play
PostSubject: Re: messed up steering?   messed up steering? Icon_minitimeDecember 25th 2013, 12:53 pm
Sounds like the gears are stripped. You need to find a new set of gears.
modmaniac
modmaniac
PostSubject: Re: messed up steering?   messed up steering? Icon_minitimeDecember 25th 2013, 1:00 pm
well the gears look fine and it has some play
PostSubject: Re: messed up steering?   messed up steering? Icon_minitimeDecember 25th 2013, 2:25 pm
Look and see If they look rounded or broken, my friends steering did the same thing, it would turn one way and not the other. Gears were toast
messed up steering?
» Steering Geometry
» A little too much steering on an mtd
» steering options
» To much play in steering
» steering rod to axle help
