 Steering Geometry
Murray modder
Murray modder
Steering Geometry Empty
PostSubject: Steering Geometry   Steering Geometry Icon_minitimeMarch 14th 2013, 9:03 pm
Anyone got any good sttering geometry? Caster, camber, toe in/out, etc etc...
I would love to see your layout in action before I get a shop to make it, vids are nice..
PostSubject: Re: Steering Geometry   Steering Geometry Icon_minitimeMarch 15th 2013, 2:23 am
For low speed aka 20mph, nothing is really critical.
For above 20mph
+10 Caster
0 Camber or less for coolness
0 Toe In/out
Positive Caster helps you get a less "nervous" steering. Tho only to a certain point, to much Caster will make them nervous again.
This is for rearwheeldrive, for a fwd you would want Negative Caster.
All this info I got from RcTek
PostSubject: Re: Steering Geometry   Steering Geometry Icon_minitimeMarch 15th 2013, 8:45 am
What Thunder said is exactly how we have ours set up and we can roll 40+ MPH down the road with zero sweat due to steering. The steering works well for us out in the woods as well. Win win!
Don't have any road vids (will have to remedy that) but here is some offroad racing that shows the steering works okiedokie offroad Very Happy
https://www.youtube.com/watch?v=wCeQW4O_SIg
Chaos Build
Check out the pics and vids!
Haspin 2021 thread
Haspin Acres Rally 2022!
TheRainbowBoxer on YouTube
PostSubject: Re: Steering Geometry   Steering Geometry Icon_minitimeMarch 15th 2013, 10:29 am
Whoops, I've been saying negative, we do have postive caster. Need to fix some posts
PostSubject: Re: Steering Geometry   Steering Geometry Icon_minitimeMarch 15th 2013, 11:48 am
I know lol, it felt natural to me to say negative.
And you should def do some vids.
Murray modder
Murray modder
PostSubject: Re: Steering Geometry   Steering Geometry Icon_minitimeMarch 15th 2013, 3:55 pm
So caster should be exactly 10,
Camber isn't needed
the toes isn't needed
last, are these set for straight axles?
and does the length of the axle bar matter?
PostSubject: Re: Steering Geometry   Steering Geometry Icon_minitimeMarch 15th 2013, 5:24 pm
Not exactly, depending on what you are building.
And what set? And no.
Murray modder
Murray modder
PostSubject: Re: Steering Geometry   Steering Geometry Icon_minitimeMarch 16th 2013, 1:43 am
Set being the angles and degrees
Racing mower, almost just like fearless', except mine topped at 55.
PostSubject: Re: Steering Geometry   Steering Geometry Icon_minitimeMarch 16th 2013, 1:23 pm
Wow really 55mph? That's fast.
If you plan on running it like fearless on asphalt/dirt you will be fine with camber and toe in / out at zero.
If you feel it changes direction when running straight you can try some toe in, maybe 1 degree.
If you plan on running on a short grass or dirt track with mostly corners, I'd go on and try with some camber settings.
Murray modder
Murray modder
PostSubject: Re: Steering Geometry   Steering Geometry Icon_minitimeMarch 17th 2013, 1:05 am
Thats the current gearing for it, so 10 caster, 0 camber, no toe in/out?
Steering Geometry
» messed up steering?
» A little too much steering on an mtd
» how do i tighten up my steering?
» Hydraulic steering
» Stock steering
