| Stock steering | |
+3Thunderdivine Doug theswampmachine 7 posters |
theswampmachine Member
| Subject: Stock steering April 6th 2013, 11:37 pm | |
| What do you think. Would it be better to just beef up the stock steering or just make a direct steering set up? | |
Doug Site Owner
Age : 29 Join date : 2012-12-24 Points : 7756 Posts : 3044 Location : Lebanon County, PA
| Subject: Re: Stock steering April 6th 2013, 11:56 pm | |
| What type of tractor do you have? Craftsmans stock steering is great. MTD, not so much. It all depends. Head Forum Administrator ** Chat Moderator ** Facebook Page AdminATLTF Facebook Page ** Chatbox ** How To Upload Pictures
| Subject: Re: Stock steering April 6th 2013, 11:58 pm | |
| It's a huskee. So if I remember correctly it made by mtd. Both of my linkages are bent though. The one from the 2 gears and the one connecting the 2 tires so I'm going to beef them up but I'm thinking just making direct steering if I'm going to spend the time doig that | |
Doug Site Owner
| Subject: Re: Stock steering April 6th 2013, 11:59 pm | |
| Your tie rod should be beefed up, ive bent mine on the Rally already. If you go direct steering thatll give you more opportunities to beef stuff up. Head Forum Administrator ** Chat Moderator ** Facebook Page AdminATLTF Facebook Page ** Chatbox ** How To Upload Pictures
Thunderdivine Veteran Member
Join date : 2012-12-21 Points : 6520 Posts : 2101 Location : Norway, Europe
| Subject: Re: Stock steering April 7th 2013, 2:45 pm | |
| If you look up "sloppy steering" in the dictionary you will see a picture of my Craftsman LT1000. So I would def. change to all Heim's joint steering, you can even keep the "reduction gear in it" if you tighten it up. | |
truckin42 Veteran Member
Age : 26 Join date : 2012-10-04 Points : 5480 Posts : 1070
| Subject: Re: Stock steering April 7th 2013, 3:39 pm | |
| I run stock steering on my mud mower and it does good. | |
mudmonkey06 Member
Age : 28 Join date : 2013-03-18 Points : 4571 Posts : 327 Location : Rindge, NH
| Subject: Re: Stock steering April 7th 2013, 4:05 pm | |
| - truckin42 wrote:
- I run stock steering on my mud mower and it does good.
If its made by mtd change it. My mtd steering is horrible. I can turn the wheel a third of the way freely without the wheels turning | |
| Subject: Re: Stock steering April 7th 2013, 4:25 pm | |
| - mudmonkey06 wrote:
If its made by mtd change it. My mtd steering is horrible. I can turn the wheel a third of the way freely without the wheels turning Yeh mtd steering is junk. I got Jd steering. | |
mudmonkey06 Member
| Subject: Re: Stock steering April 7th 2013, 4:31 pm | |
If its made by mtd change it. My mtd steering is horrible. I can turn the wheel a third of the way freely without the wheels turning Yeh mtd steering is junk. I got Jd steering. That's good. Lol. Do you get any play in your steering | |
| Subject: Re: Stock steering April 7th 2013, 4:34 pm | |
A little bit but i dont think its enought to strip the gear. I can tight up the tie rods to make it more stifer and react quicker. | |
| Subject: Re: Stock steering April 13th 2013, 6:16 pm | |
| JD Steering rocks, at least the old school. | |
| Subject: Re: Stock steering April 13th 2013, 7:44 pm | |
| - Thunderdivine wrote:
- JD Steering rocks, at least the old school.
Yeah its not bad it not newer it a 2005 i think. | |
offroadredneck Member
Age : 26 Join date : 2013-01-03 Points : 4395 Posts : 64 Location : plantcity FL
| Subject: Re: Stock steering April 13th 2013, 11:27 pm | |
| I have a old old Murray and it has indestructible steering. Except it has a piece of ruber or cloth that connects the steering shaft to the main gear | |
tractorboy567 Member
Age : 26 Join date : 2013-01-02 Points : 4434 Posts : 121 Location : PA
| Subject: Re: Stock steering April 14th 2013, 8:59 pm | |
| ive had my stock steering on my lt1000 for less than a year and the tie rod bent about 3 times and both of the steering gears are bad.... im changing them right now, so because i dont have a welder at my shop or anything for fabrication, im just going to beef it up at my vo- tech class | |
| Subject: Re: Stock steering April 14th 2013, 9:58 pm | |
| - tractorboy567 wrote:
- ive had my stock steering on my lt1000 for less than a year and the tie rod bent about 3 times and both of the steering gears are bad.... im changing them right now, so because i dont have a welder at my shop or anything for fabrication, im just going to beef it up at my vo- tech class
Yeah you could try to put haim joints on them so it wont break. I gonna do to my trail mower. | |
| Stock steering | |
