 steering options
Webmaster
Cr8zyB0b
7 posters
Cr8zyB0b
Cr8zyB0b
steering options  Empty
PostSubject: steering options    steering options  Icon_minitimeJanuary 2nd 2013, 6:07 pm
Is it a good idea to use bike handle bars with a thumb throttle instead of a steering wheel and a gas pedal? I want to switch since my clutch pedal is on the right.
PostSubject: Re: steering options    steering options  Icon_minitimeJanuary 2nd 2013, 6:30 pm
You can only use handlebars if you use a direct steering setup. There a thread being tossed around here somewhere on how to set one up.
Webmaster
Webmaster
Webmaster
Webmaster
PostSubject: Re: steering options    steering options  Icon_minitimeJanuary 2nd 2013, 6:35 pm
Doug is right. Lawn mower steering wheels usually take 2-3 turns to fully steer from lock to lock. You wouldn't want to do that with handlebars
http://ww.atltf.com
Cr8zyB0b
Cr8zyB0b
PostSubject: Re: steering options    steering options  Icon_minitimeJanuary 2nd 2013, 6:40 pm
I will have to see because im gonna chuck a 2 cylinder kubota engin in it and theres not gonna be enoght room ro a direct stering linkgage to fit as the i had to move the stock steering back 3 inhes to fit the engine and tank in.
PostSubject: Re: steering options    steering options  Icon_minitimeJanuary 2nd 2013, 8:02 pm
Could go over the motor and make a sort of 'go kart' steering - similar to this ( that i found on a racing tractor website):
steering options  01310
TennesseeCowboy
TennesseeCowboy
PostSubject: Re: steering options    steering options  Icon_minitimeJanuary 2nd 2013, 9:15 pm
Thats a cool setup, dangeroustoys56, you always have helpful pics haha
Tractor Man Jeff
Tractor Man Jeff
PostSubject: Re: steering options    steering options  Icon_minitimeJanuary 2nd 2013, 9:26 pm
Yes, It be kinda difficult to turn handle bars over and over. I like that steering job. Someday, I'm going to figure out how to fit a golf cart steering box into my tractor. Much tighter than what I have.
PostSubject: Re: steering options    steering options  Icon_minitimeJanuary 2nd 2013, 9:40 pm
lolwhat? Looks complicated.
Cr8zyB0b
Cr8zyB0b
PostSubject: Re: steering options    steering options  Icon_minitimeJanuary 3rd 2013, 8:18 am
I can fit a direct steering linkage in with 3 mm of clearence from the engine block. I am now working on the direct steering from the images and digrams u provided thnk u
PostSubject: Re: steering options    steering options  Icon_minitimeJanuary 4th 2013, 7:32 pm
Racers come up with crazy stuff to make things work - i dont know how they do it and comply with the strict rules they have to follow - since ive been trying different setups on tractors over the years ( half arsed- this time its being done right) ive amassed a bunch of racing tractor pics/setups off different sites over the past few years. Ideas i might incorporate into my next tractor.
Modding tractors has never really been easy - racers set their machines a certain way - most revolve around motor placement and trans/rear axle placement - rest has to fit around it.
The steering setup on that racing tractor IS basically similar to a go kart /RER tractor - just has a few more pieces and might need a bit of experementing on setup.
boggo
boggo
PostSubject: Re: steering options    steering options  Icon_minitimeJanuary 5th 2013, 1:54 am
a greenfield mower has a short steering wheel turn would suit a handle bar conversion easy Very Happy
steering options
» steering rod to axle help
» Steering Geometry
» Hydraulic steering
» how do i tighten up my steering?
» A little too much steering on an mtd
