| What side of the tractor is the clutch on; Does it matter? | |
+5Stretch44875 Doc Sprocket Thunderdivine TroyBilt Pony redlinemotorsportts 9 posters |
Age : 27 Join date : 2013-03-18 Points : 7478 Posts : 3131 Location : raleigh nc
| Subject: What side of the tractor is the clutch on; Does it matter? November 29th 2013, 10:42 pm | |
| Hey guys, i was thinking of a few things while watching some youtube videos. i see people do 5th gear drops in the mud and it goes flying and everyones happy. I have yet to get to that stage in how my belt is hooked up. I make my double pulley clutch on the left side of the tractor (if you were standing behind it). I was thinking when i see all the other stock tractors, the clutch is on the right side. Is that becuse when theres a load on the belt, it will just un-tention the clutch? My belt is quite tight. I dunno why it still slips in higher gears. When i do my 820 swap it will be a good time to move my clutch if this is a problem Pic explains this better | |
Join date : 2013-06-01 Points : 4805 Posts : 578 Location : West Virginia
Thunderdivine Veteran Member
Join date : 2012-12-21 Points : 6538 Posts : 2101 Location : Norway, Europe
Doc Sprocket Site VIP
Age : 51 Join date : 2013-04-21 Points : 7313 Posts : 2914 Location : Ontario Canada
Stretch44875 Administrator
Age : 49 Join date : 2012-04-05 Points : 5696 Posts : 959 Location : Mansfield, Ohio
Carshowkid Member
Age : 25 Join date : 2014-07-22 Points : 4166 Posts : 347 Location : Downers Grove Illinois
TheRainbowBoxer Moderator
Age : 49 Join date : 2012-04-23 Points : 5696 Posts : 1091 Location : Galion, OH
| Subject: Re: What side of the tractor is the clutch on; Does it matter? April 15th 2015, 1:52 pm | |
| The clutch needs to be on the "slack side". Basically look at the engine pulley dragging the belt around like if you were pulling on a rope.
The " rope" is the length of belt moving from the transaxle towards the engine (the engine pulley is "pulling the rope")... This is the tension side... This is what is doing the actual work.
The slack side is where the belt is coming off the engine pulley and heading back to the transaxle. Since the transaxle isn't actively pulling the slack side, putting a clutch there allows you to effectively shorten the belt without fighting the pull of the engine. | |
802 Customs Member
Age : 25 Join date : 2015-01-08 Points : 3753 Posts : 146 Location : Vermont
Carshowkid Member
Carshowkid Member
Carshowkid Member
1997 Murray Veteran Member
Age : 26 Join date : 2013-11-13 Points : 5441 Posts : 1311 Location : NW USA
