| Swapping Clutch to the Left-hand side. | |
MatthewD Veteran Member
Age : 23 Join date : 2014-11-16 Points : 5749 Posts : 1993 Location : Northern Ireland
| Subject: Swapping Clutch to the Left-hand side. July 22nd 2015, 3:21 pm | |
| Hi, On my Westwood tractor the clutch is on the right hand side. Would it be easy/possible to swap it to the left side?
Thanks, Matthew | |
| | | Doug Site Owner
Age : 29 Join date : 2012-12-24 Points : 7778 Posts : 3047 Location : Lebanon County, PA
| Subject: Re: Swapping Clutch to the Left-hand side. July 22nd 2015, 4:52 pm | |
| No. Clutch needs to be on the right hand side, where the slack in the belt is. If its on the left, the engine will fight the clutch rendering it useless, and it will slip and go nowhere. Head Forum Administrator ** Chat Moderator ** Facebook Page AdminATLTF Facebook Page ** Chatbox ** How To Upload Pictures
| | | | Doug Site Owner
| | | | redlinemotorsportts Moderator
Age : 27 Join date : 2013-03-18 Points : 7479 Posts : 3131 Location : raleigh nc
| Subject: Re: Swapping Clutch to the Left-hand side. July 22nd 2015, 9:40 pm | |
| On most tractors the clutch petal is connected to a 3/4"/5/8" rod underneath for all the clutch linkage to connect to (should be obvious to see underneath) I figure you can weld a extension off that and make a new petal on the left side, or put in a new rod with the petal welded to it and make arms off that for the clutch linkage but thats a little more involved. | |
| Who is online? | In total there are 8 users online :: 0 Registered, 0 Hidden and 8 Guests
