 locking my transaxle in my lt4000
Trcustoms
Chunk
7 posters
locking my transaxle in my lt4000 Empty
PostSubject: locking my transaxle in my lt4000   locking my transaxle in my lt4000 Icon_minitimeOctober 5th 2010, 2:00 am
how do you lock a craftsman lt4000 6 speed transaxle without a welder my rear has a spool deal with 2 spider gears on a shaft and the spider gears on the axles i do alot of mudding and hill climbing and need posi i have atv tires on the rear but really need posi any help will be greatly appreciated
PostSubject: Re: locking my transaxle in my lt4000   locking my transaxle in my lt4000 Icon_minitimeOctober 5th 2010, 6:15 am
Without a welder- youd need an extra pair of spider gears to lock the whole assembly , then bolt them in with grade 8 bolts - eventually you might want to upgrade to a peerless 700 ( the trans with a lower input pulley and a side output sprocket) and a 1" or bigger straight axle - using a pair of pillow block berings to support the axle.
Good thing about that setup is it can be lifted easily.
PostSubject: Re: locking my transaxle in my lt4000   locking my transaxle in my lt4000 Icon_minitimeOctober 5th 2010, 10:08 am
thank you i really appriciate the help
Chunk
Chunk
PostSubject: Re: locking my transaxle in my lt4000   locking my transaxle in my lt4000 Icon_minitimeOctober 6th 2010, 3:22 am
What he said basically. I opted for the extra spider gear method on mine.
PostSubject: Re: locking my transaxle in my lt4000   locking my transaxle in my lt4000 Icon_minitimeOctober 8th 2010, 9:54 am
i welded the spyder gears on my axles to the spyder gears the are in the spool it works great but it winds out really loud i hear over the motor is this normal
Trcustoms
Trcustoms
PostSubject: Re: locking my transaxle in my lt4000   locking my transaxle in my lt4000 Icon_minitimeOctober 8th 2010, 2:06 pm
Yes! Razz
Did you put gear oil in it?
If so they will still do it a bit but not as bad.
PostSubject: Re: locking my transaxle in my lt4000   locking my transaxle in my lt4000 Icon_minitimeOctober 8th 2010, 3:09 pm
Yes its normal - when i wound up my 94 mod murray to near 40mph, even with gear oil in it, itd whine something fierce- heck even my stock mowing MTD's all have bad gear whine.
Trcustoms
Trcustoms
PostSubject: Re: locking my transaxle in my lt4000   locking my transaxle in my lt4000 Icon_minitimeOctober 8th 2010, 3:11 pm
Yeah, why do all those MTD's do that even stock.
I hate it, when i go to sell one people are like that thing needs a tranny.
Chunk
Chunk
PostSubject: Re: locking my transaxle in my lt4000   locking my transaxle in my lt4000 Icon_minitimeOctober 10th 2010, 5:08 pm
Just cheap designs I guess, lack of proper grease in the right places.
Its MTD. SHame, I like their older tractors
But gear whine is normal, just make sure you use some htick gear oil if you're going much faster than stock
PostSubject: Re: locking my transaxle in my lt4000   locking my transaxle in my lt4000 Icon_minitimeOctober 10th 2010, 5:19 pm
MTD's whine alot because the factory puts about a half handful of bennonite grease in the trans.
My stock 97 mastercut howls like crazy when im in high gear and mowing - even the 91 mod MTD howls pretty good, even after socking new grease in it. Oddly, my 90 MTD task force is pretty quiet tho.
I thought of using oil in the mod MTD, but after i put some in another MTD, it all just leaked out- so i put zerks in it and sock the heck out of it with grease every other time i run it. Im thinking about doing that on my mowing MTD's as well.
Farmster
Farmster
PostSubject: Re: locking my transaxle in my lt4000   locking my transaxle in my lt4000 Icon_minitimeOctober 19th 2010, 9:40 pm
im lookin to lock my trans but have no clue what trans i got yet havnt even looked i think i realy dont know what the hell it might be. its a Crastman 2 12hp.
Trcustoms
Trcustoms
PostSubject: Re: locking my transaxle in my lt4000   locking my transaxle in my lt4000 Icon_minitimeOctober 19th 2010, 9:53 pm
Probably a peerless or spicer.
Is it a 5 or 6 speed?
They are all pretty much the same on the inside.
Farmster
Farmster
PostSubject: Re: locking my transaxle in my lt4000   locking my transaxle in my lt4000 Icon_minitimeOctober 19th 2010, 10:07 pm
5 speed manual im thinkin its a peerless just dont know .
Trcustoms
Trcustoms
PostSubject: Re: locking my transaxle in my lt4000   locking my transaxle in my lt4000 Icon_minitimeOctober 19th 2010, 10:09 pm
I have a factory service manual with all the break downs and part numbers for all peerless trannys.
Let me know if you need info on your tranny and i could scan it for you and post it.
Farmster
Farmster
PostSubject: Re: locking my transaxle in my lt4000   locking my transaxle in my lt4000 Icon_minitimeOctober 19th 2010, 10:59 pm
alright man thanks ill take a look at the thing this weekend hopefully my dad gets friday off
biscuit
biscuit
PostSubject: Re: locking my transaxle in my lt4000   locking my transaxle in my lt4000 Icon_minitimeDecember 3rd 2010, 5:35 pm
might be askin a bit much here...but can anyone post a couple pics of what to do? i am thinkin about doin that to mine. but...how are they on the street? not that it will be on the road much, but i might take it to my local waterin hole.
PostSubject: Re: locking my transaxle in my lt4000   locking my transaxle in my lt4000 Icon_minitimeDecember 3rd 2010, 5:46 pm
Traction will be awsome, however steering will be horrible- dont plan on any super tight turning after locking a trans.
My wizard build and future wheelhorse build will have straight axles, then again those will be more for speed then actual turning.
Jordan
Jordan
PostSubject: Re: locking my transaxle in my lt4000   locking my transaxle in my lt4000 Icon_minitimeDecember 3rd 2010, 6:18 pm
i locked the diff in my lt4000 it turns as tight as it did the day i got it and i have atv tires on it, trick is i slide my ass to the side on the outside of the turn so it lifts up the inside tire and it allows it to skid. this will reduce the amount of grass ripped and also reduce the stress on the welds and axles
Jamus
Jamus
PostSubject: Re: locking my transaxle in my lt4000   locking my transaxle in my lt4000 Icon_minitimeDecember 3rd 2010, 8:00 pm
That's the opposite of what you think to do though. It would take some getting used to I guess.
http://www.rcbashers.com
Jordan
Jordan
PostSubject: Re: locking my transaxle in my lt4000   locking my transaxle in my lt4000 Icon_minitimeDecember 3rd 2010, 8:02 pm
it did take a little while but with mine it only goes stock speed so its not that bad, but after the snapped the welds the first time i learned real fast lol
PostSubject: Re: locking my transaxle in my lt4000   locking my transaxle in my lt4000 Icon_minitimeDecember 4th 2010, 11:40 am
thats what the racers do- they 'push' the rear of the tractor around the corners with thier butts- they make some pretty good rooster tails once the grass is torn off. Thats why alot of racers also have that support bar to the right side of the seat- so they dont slide off.
» locking my transaxle
» HOW TO: Transaxle Locking Methods
» Transaxle locking problems
» horizontal shaft transaxle locking trouble
» Locking A Peerless Transaxle... The Doc Locker! Video Added 2/23/14
