 horizontal shaft transaxle locking trouble
Marines2621
offroadredneck
9 posters
offroadredneck
offroadredneck
horizontal shaft transaxle locking trouble Empty
PostSubject: horizontal shaft transaxle locking trouble   horizontal shaft transaxle locking trouble Icon_minitimeJanuary 28th 2013, 11:44 pm
I have an older Murray lawn tractor, haven't taken the transaxle apart yet but I was wondering if it is possible to lock a horizontal shafted transaxle. Its a 4 speed and cast iron.
PostSubject: Re: horizontal shaft transaxle locking trouble   horizontal shaft transaxle locking trouble Icon_minitimeJanuary 29th 2013, 9:10 am
Just about the same as any transaxle. They are more complicated than some to put back together.
offroadredneck
offroadredneck
PostSubject: Re: horizontal shaft transaxle locking trouble   horizontal shaft transaxle locking trouble Icon_minitimeJanuary 29th 2013, 7:06 pm
How would I make the axles strait It bolts together horizontally too.
Marines2621
Marines2621
PostSubject: Re: horizontal shaft transaxle locking trouble   horizontal shaft transaxle locking trouble Icon_minitimeJanuary 29th 2013, 9:08 pm
oh heck yeah its possible. I have one sitting outside from my murray (Profile Pic) the bearings went out on the input shaft. Got different plans now since i have 2 mowers. It is possible to do it. I did it to my 4 speed. Its easy alittle hard putting back together. I figured i would know the best about them kinda transaxles. Talk to me.
offroadredneck
offroadredneck
PostSubject: Re: horizontal shaft transaxle locking trouble   horizontal shaft transaxle locking trouble Icon_minitimeJanuary 30th 2013, 12:20 pm
mine is my profile picture so how do you lock. I havent taken it apart yet but us dont see hoe to keep the axles strait because unlike other transaxles it bolts together sideways. So
PostSubject: Re: horizontal shaft transaxle locking trouble   horizontal shaft transaxle locking trouble Icon_minitimeJanuary 30th 2013, 1:37 pm
Easiest way would probably be to make fozzy lockers out of the spider gears, that way the transmission still goes together the same. There have been some threads on those here.
Chaos Build
Check out the pics and vids!
Haspin 2021 thread
Haspin Acres Rally 2022!
TheRainbowBoxer on YouTube
Marines2621
Marines2621
PostSubject: Re: horizontal shaft transaxle locking trouble   horizontal shaft transaxle locking trouble Icon_minitimeJanuary 30th 2013, 4:22 pm
On the inside it have a bowel gear. like usual, But it have holes in it. The reason for the holes in it is because it have the two axles in a bolt together locker. I took the transaxle apart. Pulled the bowel gear locker out. Took the bolt out of it and put on side on it with the spider gears alined with it. Tack wielded the spider gears. Took the spider gears out and fully wield them on. Then put it back together and there is your locked transaxle. I might have to make a video about it for you if u want me to.
offroadredneck
offroadredneck
PostSubject: Re: horizontal shaft transaxle locking trouble   horizontal shaft transaxle locking trouble Icon_minitimeJanuary 30th 2013, 9:21 pm
You might because im not sure on how to alline it. I know how to do a normal transaxle, but I wasnt sure on how to do this one. If you could make a vid that would be vary helpfull, but dont worrie about it if you cant.
Marines2621
Marines2621
PostSubject: Re: horizontal shaft transaxle locking trouble   horizontal shaft transaxle locking trouble Icon_minitimeJanuary 30th 2013, 11:09 pm
I'll do one tomorrow if it's not to cold
Marines2621
Marines2621
PostSubject: Re: horizontal shaft transaxle locking trouble   horizontal shaft transaxle locking trouble Icon_minitimeFebruary 7th 2013, 8:42 pm
Sorry i havent done nothing. been super busy and no time to get on. Have u figured it out?
offroadredneck
offroadredneck
PostSubject: Re: horizontal shaft transaxle locking trouble   horizontal shaft transaxle locking trouble Icon_minitimeFebruary 8th 2013, 12:11 am
Havent taken it apart yet, having a mud bog tomarrow and dont want to break any thing.
But if you cant do a vid dont worrie about it I can figure it out
PostSubject: Re: horizontal shaft transaxle locking trouble   horizontal shaft transaxle locking trouble Icon_minitimeFebruary 8th 2013, 10:26 pm
I know the horizontal shaft transmissions in craftsmans are a serious pain to put back together, from what ive herd - its ALL gears inside, not easy to line things up.
Id research and find spec drawings on it before cracking it open, so you know what to expect.
offroadredneck
offroadredneck
PostSubject: Re: horizontal shaft transaxle locking trouble   horizontal shaft transaxle locking trouble Icon_minitimeFebruary 9th 2013, 1:36 am
Ok Man thanks
WellThatsSurprising
WellThatsSurprising
PostSubject: Re: horizontal shaft transaxle locking trouble   horizontal shaft transaxle locking trouble Icon_minitimeFebruary 9th 2013, 9:48 am
Yup, all gears inside. I really want to take mine apart to lock it but then I look at the diagram and think, Nah, better not.
horizontal shaft transaxle locking trouble 305639_175240229271836_124269513_n
Murray modder
Murray modder
PostSubject: Re: horizontal shaft transaxle locking trouble   horizontal shaft transaxle locking trouble Icon_minitimeFebruary 9th 2013, 2:03 pm
Seems to me you could drill a hole in a table, and mount that transmission on it's side. Kinda like how most transmissions have a removable top or bottom lid. That way andd the gear and washers and what not dont just drop out. Keeps em all standing up.
AcreFarm
AcreFarm
PostSubject: Re: horizontal shaft transaxle locking trouble   horizontal shaft transaxle locking trouble Icon_minitimeFebruary 9th 2013, 2:35 pm
That, or using a vice to hold the transaxle is the way to go. Just make sure the correct half is facing UP.
offroadredneck
offroadredneck
PostSubject: Re: horizontal shaft transaxle locking trouble   horizontal shaft transaxle locking trouble Icon_minitimeFebruary 9th 2013, 5:58 pm
Thats alot of parts Shocked . Im not sure if im wonna take it apart and mess it up, what do you guys think.
Marines2621
Marines2621
PostSubject: Re: horizontal shaft transaxle locking trouble   horizontal shaft transaxle locking trouble Icon_minitimeFebruary 10th 2013, 10:13 pm
I have a video up on my YouTube. Marines2621
WellThatsSurprising
WellThatsSurprising
PostSubject: Re: horizontal shaft transaxle locking trouble   horizontal shaft transaxle locking trouble Icon_minitimeFebruary 17th 2013, 12:43 pm
Well, I took mine apart yesterday, check my build thread and you'll see what it looks like. Actually a lot less complex then the diagram makes it look. Just make sure you take off the right side of the shell. The side with the input shaft is usually the one you want to take off. http://atltf.forumotion.com/t1315p30-project-big-cat#18793
Marines2621
Marines2621
PostSubject: Re: horizontal shaft transaxle locking trouble   horizontal shaft transaxle locking trouble Icon_minitimeFebruary 18th 2013, 12:00 am
Yeah, I figured that out the hard way. But it's junk transaxle now
PostSubject: Re: horizontal shaft transaxle locking trouble   horizontal shaft transaxle locking trouble Icon_minitimeFebruary 18th 2013, 5:44 pm
Is it a regular 3 speed or 3 hi/low trans- that would make the difference on how much stuff is inside.
Id only take mine apart if something goes wrong with it - id just yank the trans out of my parts GT6000 and run that- both a 3 hi/low trans, altho ive had the trans from my 69 raider 10 apart, also a hi/low - that didnt seem to have hardly any gears in it.
offroadredneck
offroadredneck
PostSubject: Re: horizontal shaft transaxle locking trouble   horizontal shaft transaxle locking trouble Icon_minitimeFebruary 18th 2013, 8:59 pm
Its a four speed
Marines2621
Marines2621
PostSubject: Re: horizontal shaft transaxle locking trouble   horizontal shaft transaxle locking trouble Icon_minitimeFebruary 18th 2013, 10:25 pm
Check out my vid, you will see the inside of one its not to bad as the diagrams show
offroadredneck
offroadredneck
PostSubject: Re: horizontal shaft transaxle locking trouble   horizontal shaft transaxle locking trouble Icon_minitimeFebruary 19th 2013, 6:31 am
What vid Question
PostSubject: Re: horizontal shaft transaxle locking trouble   horizontal shaft transaxle locking trouble Icon_minitimeFebruary 19th 2013, 10:13 am
offroadredneck wrote:
What vid Question
» Vertical Shaft Engine on Horizontal Shaft Mower
» locking my transaxle
» Transaxle locking problems
» Briggs horizontal shaft carburator upgrade
