 murry pull strength?
cumminsbayou
5horsebriggs
7 posters
5horsebriggs
murry pull strength? Empty
PostSubject: murry pull strength?   murry pull strength? Icon_minitimeOctober 13th 2013, 10:51 pm
hey guys, I have a 1996 murry with a 12hp briggs and want it to be able to go through snow and have lots of torque to pull heavy loads, how can I accomplish this?
cumminsbayou
cumminsbayou
PostSubject: Re: murry pull strength?   murry pull strength? Icon_minitimeOctober 14th 2013, 8:55 am
The snow part I would have no idea, but I would think you'd need a lift to go in it and some better tires off a 4 wheeler or something, and of course a pulley swap. You can watch some of feerlessfronts videos on youtube and find out more modifications for snow and water. For the towing part you should be able to tow heavy loads now then you could with a pulley swap. But if the loads are really heavy its gonna stress your transaxle and possible crack the cases.
PostSubject: Re: murry pull strength?   murry pull strength? Icon_minitimeOctober 14th 2013, 10:50 am
Budget, tools and skills aside, here's what I would do-
Get rid of the transaxle in favour of a 1 1/4" solid axle and separate transmission, such as a Peerless 700. This will give the rearend massive strength and eliminate the differential, greatly improving motive force in the snow.
Since this will result in a chain final drive, you can use both the pulley ratios and final sprocket ratio to fine-tune the overall redux ratio. You can end up with a decent transport speed, and yet plenty of torque.
Snow traction can be improved with ballast weight, aggressive tire treads, tire chains, or a combination of these.
What kind of loads do you intend to pull?
5horsebriggs
PostSubject: Re: murry pull strength?   murry pull strength? Icon_minitimeOctober 14th 2013, 5:41 pm
maybe 200 pound, is it capable of that stock?
PostSubject: Re: murry pull strength?   murry pull strength? Icon_minitimeOctober 14th 2013, 5:55 pm
I've pulled 5000lbs with a stock hydro 12hp. Was a camper, didn't like it, but would do it.
5horsebriggs
PostSubject: Re: murry pull strength?   murry pull strength? Icon_minitimeOctober 14th 2013, 6:08 pm
wow, so even 500 pounds could be pulled?
crazykid1994
crazykid1994
PostSubject: Re: murry pull strength?   murry pull strength? Icon_minitimeOctober 14th 2013, 6:44 pm
if its on wheels a mower can generally pull it as long as you dont excede tire recomendations. otherwise bad things can happen. mowers have tons of torque because they are geared to go so slow
PostSubject: Re: murry pull strength?   murry pull strength? Icon_minitimeOctober 15th 2013, 2:24 pm
LOL- your idea of a heavy load, and ours is far from matching. You'll have no problem at all hauling the kind of weight you're talking about!
5horsebriggs
PostSubject: Re: murry pull strength?   murry pull strength? Icon_minitimeOctober 15th 2013, 2:45 pm
Oh good to hear
PostSubject: Re: murry pull strength?   murry pull strength? Icon_minitimeOctober 15th 2013, 3:01 pm
I was able to pull a 1000lbs sled with my tractor before my pully swap, now I'm getting a little too much belt slippage.
PostSubject: Re: murry pull strength?   murry pull strength? Icon_minitimeOctober 15th 2013, 4:43 pm
I've pulled upwards of 2000lbs with MULE, and it didn't break a sweat. As others have mentioned, just watch your tongue weight. Pulling is one thing, taking a load directly on the rearend is another thing.
I've seen one of the videos of Stretch moving a camper. Dead funny, especially considering he had to have his son (I believe) hanging off the frontend of the tractor as counterweight!
PostSubject: Re: murry pull strength?   murry pull strength? Icon_minitimeOctober 15th 2013, 7:20 pm
Great video... It was my son who was playing counterweight for Stretch btw...
Chaos Build
Check out the pics and vids!
Haspin 2021 thread
Haspin Acres Rally 2022!
TheRainbowBoxer on YouTube
» friggin got a estate by murry.
» murry lift kit ideas
» murry wide body 4wd project
» need a better clutch for my 1987 murry rear engine ridder
» Does anybody know how much our tractor's can pull?
