 anyone lock a mtd fnr
MowKartEnvy
mudmonkey06
TroyBilt Pony
10 posters
anyone lock a mtd fnr - Page 2 Empty
PostSubject: Re: anyone lock a mtd fnr   anyone lock a mtd fnr - Page 2 Icon_minitimeNovember 16th 2013, 6:09 pm
anyone lock a mtd fnr - Page 2 1469842_457049214416824_1512615243_n
"This is best I can do for now. Took pics with tablet so they aint the best. You'll notice the bottom center pic has an arrow. That points to a c clip. Its the same on the other side. To remove the spiders one has to be removed then the shaft slides thru the housing and spiders to come out. The only way ive seen transaxles locked is by welding the spiders to the shaft, thats why I said impossible (premature im shore). Also, the spiders must be removed to bolt the axles gear on. Ill try to do a pictorial or video on a disassembley."
Ok- I copied it over. you should be able to do this too- Right click and copy your URL. Then, hit the little icon that looks like a picture, two icons to the left of the YouTube button. Paste the URL in there and you're off.
My first impression is that I can't see why a Fozzy Locker wouldn't work. Failing all else, it should be a doable option. If you cannot (or refuse to ) purchase the special gears, you can make your own. I will show an example of a purchased gearset, and a homebrew version. anyone lock a mtd fnr - Page 2 4b9903ec582bd_153864b
anyone lock a mtd fnr - Page 2 PIC_0235
Note- the homebrew version shown above was made by one of our members, W1ldyOvvnZ, and located here- https://www.atltf.com/t845-fozzy-locker-or-welded-spiders
tractor_guy
tractor_guy
PostSubject: gear ratio?   anyone lock a mtd fnr - Page 2 Icon_minitimeNovember 16th 2013, 8:04 pm
Incase anyone is interested, I counted the teeth in the gears incase you wanna figure out the ratio. Ive never bothered to learn.
The top gear turned by the pulley is 14 tooth, it turns the forward and reverse gears that are 42 tooth. Those turn the shaft that a 10 tooth is on turning the 72 tooth that bolts to the housing for the spider gears. If anyone could explain how to figure out the ratio I be greatfull.
***THANKS FOR HELPIN GET THESE PICS UP DOC SPROCKET***
PostSubject: Re: anyone lock a mtd fnr   anyone lock a mtd fnr - Page 2 Icon_minitimeNovember 16th 2013, 8:51 pm
It's all division and multiplication. Divide the input set 42/14= 3
Divide the output set- 72/10= 7.2
multiply both results 3x7.2= 21.6
Therefore, total reduction ratio is 21.6:1
tractor_guy
tractor_guy
PostSubject: Re: anyone lock a mtd fnr   anyone lock a mtd fnr - Page 2 Icon_minitimeNovember 17th 2013, 2:06 am
Posted a pictorial on how these transaxles work.
http://www.diygokarts.com/vb/showthread.php?p=296786&posted=1#post296786
crafsmankiller
PostSubject: Re: anyone lock a mtd fnr   anyone lock a mtd fnr - Page 2 Icon_minitimeNovember 18th 2013, 11:23 am
are you sure its 21:1? that seems to be geared really low
PostSubject: Re: anyone lock a mtd fnr   anyone lock a mtd fnr - Page 2 Icon_minitimeNovember 18th 2013, 11:31 am
mine was that low.
tractor_guy
tractor_guy
PostSubject: Re: anyone lock a mtd fnr   anyone lock a mtd fnr - Page 2 Icon_minitimeNovember 18th 2013, 1:49 pm
Lol I had no idea it was that simple! Thanks Doc.
PostSubject: Re: anyone lock a mtd fnr   anyone lock a mtd fnr - Page 2 Icon_minitimeNovember 18th 2013, 2:02 pm
Yep.
You're welcome!
» to lock, or not to lock?
» trans lock
» Peerless 600 "diff lock"
» Mtd tranny lock???
» how NOT to lock a mtd axle
