| MTD mudder | |
+14willis923 LAWN MOWER MUDDER crazykid1994 jakethetractorguy richie thomas Doc Sprocket Ariens YT11 cumminsbayou theswampmachine redlinemotorsportts MurrayMayhem TroyBilt Pony craftsmancole GenevaCustoms 18 posters |
| Subject: Re: MTD mudder October 6th 2013, 5:29 pm | |
| The front of the axle has to be supported. Theres screw hole on the side up front. you risk cracking the case or the axle driving underneath it. | |
GenevaCustoms Member
Age : 27 Join date : 2013-09-24 Points : 4381 Posts : 315 Location : Florida
| I don't know why these are upside down.... If anyone knows how to flip them lol that'd be great | |
| Subject: Re: MTD mudder October 6th 2013, 5:30 pm | |
| Yea I know about the front mount, I'm doing that first thing I can but I was just testing it on flat ground and takin it easy, and yea an X brace sounds smart lol | |
Doc Sprocket Site VIP
Age : 51 Join date : 2013-04-21 Points : 7284 Posts : 2914 Location : Ontario Canada
| Subject: Re: MTD mudder October 6th 2013, 6:00 pm | |
| You definitely need to add some cross-bracing. Lateral forces will bend those plates like a taco. You got rid of the wood? Good man!
As for the pics, remove them from your post (use EDIT button), flip them over, and upload them again. | |
| Subject: Re: MTD mudder October 6th 2013, 6:22 pm | |
| I need to get some more steel for the cross bracing, and yes lol I got rid of the wood (only because I needed an extra 2inches lol) jk the wood would eventually get soft from the water logging it takes but a good temp trial testing block if you ask me. I also need to make a new shifter on this thing | |
cumminsbayou Member
Age : 27 Join date : 2011-11-04 Points : 4987 Posts : 232 Location : fairhope Al.
| Subject: Re: MTD mudder October 6th 2013, 9:43 pm | |
| I was able to flip my lab top uside down and look at them lol. It looks really sweet with that size lift. I should do one that side on my RER lol. As for the clutch what if you used on from the murray the 6 speed came off of? I've never had a problem with a murray clutch. What are go doing about the tires? | |
| Subject: Re: MTD mudder October 7th 2013, 6:17 am | |
| I should prolly get 22s but i still want skinny so like 22x7x8 if they have those lol | |
cumminsbayou Member
| Subject: Re: MTD mudder October 7th 2013, 7:19 am | |
| You could get some 4 wheeler tires from some where that size. They make some with some pretty thick lugs on them. | |
| Subject: Re: MTD mudder October 7th 2013, 5:32 pm | |
| I think you would get a LOT of strength by framing in an X that spans from side-to-side between the "towers".
You definitely want some forward support too, to take any possible twist out of it. | |
| Subject: Re: MTD mudder October 7th 2013, 5:51 pm | |
| Yea I think I'm going to go back to where the old Murray sits and rip out the shift mechanism and the old front mount bracket so I don't have to fab it all, get some more steel for the cross bracing and weld that in and hook up the front mount. After that's all done maybe weds day or so I can start the shifting linkage. | |
| Subject: Re: MTD mudder October 10th 2013, 7:00 pm | |
| Started on the shifter and put the horizontal brace in, couldn't do a X because the pulley would hit it and I though this is strong enough, here's some update pics! Also redid the steering the other day and made a wire harness, fixed the charging problem stole the old diode off a junk mower and now it charges! Hopefully these are right side up lol My finger is pointing at the shift lever ... New place for it it felt alright The shifting shaft The brace Diode Rear cross brace Fresh steering The clutch in the makin | |
cumminsbayou Member
| Subject: Re: MTD mudder October 10th 2013, 7:33 pm | |
| So are you using the stuff for shifting off the murray? I'd like to do that with my spicer. Get more pictures of the clutch when you get done to if you will. | |
| Subject: Re: MTD mudder October 10th 2013, 7:38 pm | |
| Yea I used the Murray shifting lever I'm having to extend the actually shift linkage to the tranny tho. And I used one of the Murray like brackets. I didn't need the other one cuz it's the frame right now I might reinforce it with it but I don't see why I would have to | |
| Subject: Re: MTD mudder October 11th 2013, 6:03 pm | |
| Got the tranny mounted solid now and finished up the shifting linkage works perfect. Still need a bigger belt and a clutch lol The pulley painted tranny brackets painted Tranny back in Front mount Rear mounts Shifting linkage (missing the final link) | |
Age : 23 Join date : 2013-04-08 Points : 5175 Posts : 913 Location : Central Pa
| Subject: Re: MTD mudder October 11th 2013, 6:51 pm | |
| I like it, but two things I would like to say. 1.maybe you should brace those front mounts for the trans-axle. 2.For the shift linkage I used a chopped up piece on a tie-rod with a bolt welded on the end and a heim-joint on the end.
Hope it helps. | |
| Subject: Re: MTD mudder October 11th 2013, 7:26 pm | |
| Yea after that pic I hooked up the last link it was dryin with paint and it works good | |
willis923 Veteran Member
Age : 28 Join date : 2013-04-10 Points : 5727 Posts : 1408 Location : Galway NY
| Subject: Re: MTD mudder October 30th 2013, 7:43 pm | |
| looks like you had some fun gettin her buried.. lol. nice shoes BTW | |
| Subject: Re: MTD mudder October 30th 2013, 7:57 pm | |
| I wouldn't want to ruin a pair of shoes would I? Hahahah | |
Age : 25 Join date : 2013-04-05 Points : 4928 Posts : 661 Location : New Smyrna Beach,Fl
| Subject: Re: MTD mudder November 8th 2013, 10:18 pm | |
| Lol, i romp bare foot too, and what are the tire you gunna put on it? | |
Age : 27 Join date : 2013-03-18 Points : 7449 Posts : 3131 Location : raleigh nc
| Subject: Re: MTD mudder November 8th 2013, 11:00 pm | |
| Oh i didnt see the romp. good editing. I like how you included everything. Exhaust sounds good too for a single. | |
| Subject: Re: MTD mudder November 9th 2013, 6:37 am | |
| Yea I think it sounds pretty good, they camera didn't pick it up very good though, and I'll do a another romp soon. With the new exhaust. Brow thanks for subscribing ! | |
| MTD mudder | |
