| MTD mudder | |
+14willis923 LAWN MOWER MUDDER crazykid1994 jakethetractorguy richie thomas Doc Sprocket Ariens YT11 cumminsbayou theswampmachine redlinemotorsportts MurrayMayhem TroyBilt Pony craftsmancole GenevaCustoms 18 posters |
GenevaCustoms Member
| Subject: Re: MTD mudder February 19th 2014, 9:12 pm | |
| Haven't updated in a long time. But I've done some stuff and some stuff has broke. I locked the tranny and it does good, the pulley alignment went out and cut two belts I've been working on that, and then the welded pulleys on the tranny finly broke so I will be doing a coupler and extensions shaft with bearing like I should have down from the start. Stay tuned | |
Age : 27 Join date : 2013-03-18 Points : 7460 Posts : 3131 Location : raleigh nc
| Subject: Re: MTD mudder February 20th 2014, 2:32 am | |
| - GenevaCustoms wrote:
- Haven't updated in a long time. But I've done some stuff and some stuff has broke. I locked the tranny and it does good, the pulley alignment went out and cut two belts I've been working on that, and then the welded pulleys on the tranny finly broke so I will be doing a coupler and extensions shaft with bearing like I should have down from the start. Stay tuned
I was wondering how long the pulleys were gunna last. Nice to see a update | |
Age : 27 Join date : 2013-09-24 Points : 4392 Posts : 315 Location : Florida
Age : 25 Join date : 2013-04-05 Points : 4939 Posts : 661 Location : New Smyrna Beach,Fl
| Subject: Re: MTD mudder April 15th 2014, 7:56 pm | |
| Heres some suggestions for you if you want it bullet proof
Weld the hole frame sections solid search for a cast iron (90's) axle off a craftsman all new steering, drag link, gears, rod ends, tierod spindle bracing skid plates because you ride in the seaweed tranny skid plate beef front and rear bumpers brace center console | |
| Subject: Re: MTD mudder April 15th 2014, 7:58 pm | |
| I have a couple of those craftsman cast iron axles if you want one
| Subject: Re: MTD mudder April 15th 2014, 8:00 pm | |
| Would it be easier and better to have the craftsman or will the 820 do? Not going with bigger tires than 24in. And if my damn video didn't quit playing I mentioned full skid plate with nice slanted one on the front to slide of stuff, heavy duty one on tranny, and I was going with direct steer setup with heir joints. And beef the hell outa the frame along with making a new custom dash/console to fit the hood I was wanting. | |
| Subject: Re: MTD mudder April 15th 2014, 8:04 pm | |
| - craftsmancole wrote:
- I have a couple of those craftsman cast iron axles if you want one
Y'all talking bout front axles? | |
| Subject: Re: MTD mudder April 15th 2014, 8:07 pm | |
Y'all talking bout front axles? Yes, and to your previous post, sounds good, i dont see any problem with direct steer other then it will be a little hard to turn the wheels | |
| Subject: Re: MTD mudder April 15th 2014, 8:13 pm | |
True.... Maybe I could use the old blown spicer gears to make a geared steering that is tight, smooth, and easy but not able to skip teeth and such | |
| Subject: Re: MTD mudder April 16th 2014, 9:38 pm | |
| Going to finish up getting the engine painted and the main components back on then start on the frame again. Goin for three link cool overs on front, and I have the wheels and tires picked out. But I need that 820 first before I order anything like that | |
| Subject: Re: MTD mudder April 17th 2014, 8:05 pm | |
| I have a 20hp Briggs vtwin, runs great so my option is to put it on redo my exhaust, both engine runs great the only different it will have is it's a twin with about 6 more hp and however much more torque. Putting the twin and the tires I want will have me searching for super belt tension ideas. What should I do? Keep rolling with the single 14hp or start over with the 20hp | |
Carshowkid Member
Age : 25 Join date : 2014-07-22 Points : 4148 Posts : 347 Location : Downers Grove Illinois
| Subject: Re: MTD mudder February 13th 2015, 8:17 am | |
| Nice build! I wish you luck! | |
| Subject: Re: MTD mudder February 13th 2015, 9:20 am | |
| - Carshowkid wrote:
- Nice build! I wish you luck!
ghis mower served me well Untill I decided to tear it down to beef up but after I tore it down I decied to build on frame and that's my build off mower | |
| MTD mudder | |
