| What Size Pully? | |
+4matt-man redlinemotorsportts crazykid1994 Seth Chester 8 posters |
Seth Chester New Member
Age : 25 Join date : 2013-09-09 Points : 4116 Posts : 23 Location : Florida
| Subject: What Size Pully? September 11th 2013, 10:51 pm | |
| I Was Wondering If Ya'll Know What Size Pulley's I Should Get I Am Thinking About 6" Pulley's ! I Don't Want Belt Slipage Problems! And I Want A Good Amount Of Torque. But Still Want The Mower To Run About 12MPH! | |
Age : 30 Join date : 2013-03-18 Points : 4920 Posts : 618 Location : loxahatchee, florida
| Subject: Re: What Size Pully? September 12th 2013, 5:42 am | |
| Is that the engine pulley? If so what size is on the transmission | |
Age : 27 Join date : 2013-03-18 Points : 7478 Posts : 3131 Location : raleigh nc
| Subject: Re: What Size Pully? September 12th 2013, 6:16 am | |
| I say 4-4 or 5-5 and beef up the clutch springs. | |
matt-man Member
Age : 27 Join date : 2013-07-26 Points : 4386 Posts : 221 Location : North Fort Myers, Florida
| Subject: Re: What Size Pully? September 12th 2013, 7:45 am | |
| I would keep it 1:1 or as close to that as possible for now if you find it to fast or to slow then change one of them out I have found that 1:1 is the best ratio for starting out | |
Doc Sprocket Site VIP
Age : 51 Join date : 2013-04-21 Points : 7313 Posts : 2914 Location : Ontario Canada
| Subject: Re: What Size Pully? September 12th 2013, 9:34 am | |
| Things to think about:
Go too small on any pulley, and slippage may prove to be a problem. Increasing belt tension to compensate, only stresses components out more. Speeding up the tranny input too much, can threaten the tranny. Consider "race prepping" your tranny if you're going to run it much faster than stock. Gearing is a matter of mathematics. Calculate the difference between old pulley sizes, and new pulley sizes to see how hard you're pushing it, and what sort of speed you can expect. Watch your clearances. Go too big on the engine pulley, and you might have interferences somewhere... | |
| Subject: Re: What Size Pully? September 12th 2013, 9:47 pm | |
| I was thinking 6" on the motor and 7" on the transaxle now actually! What do you think about that? | |
matt-man Member
| Subject: Re: What Size Pully? September 13th 2013, 7:44 am | |
| - Seth Chester wrote:
- I was thinking 6" on the motor and 7" on the transaxle now actually! What do you think about that?
A 7 should work on your transaxle but a 6 might not work on your engine check and make sure the clutch assembly is not in the way you may have to go smaller | |
richie thomas Veteran Member
Age : 29 Join date : 2011-08-04 Points : 6395 Posts : 1434 Location : east dublin georgia
| Subject: Re: What Size Pully? September 13th 2013, 7:54 am | |
most mowers can easily have a 6" pully on the motor without interfering with the clutch, and a 6" to a 7" will still get your around 15 and also have small chance for a belt slipping | |
greener179 Member
| Subject: Re: What Size Pully? September 13th 2013, 7:57 am | |
| I agree with Richie the only mowers I really see that need the clutch modded is the ayp brands. | |
willis923 Veteran Member
Age : 28 Join date : 2013-04-10 Points : 5756 Posts : 1408 Location : Galway NY
| Subject: Re: What Size Pully? September 13th 2013, 8:18 am | |
| make a mock up of a pully using cardboard to test the clearance of everything. then just double up or beef up the clutch springs. there might be a little slippage, but if you get tighter clutch springs, you might be able to minimize it | |
| Subject: Re: What Size Pully? September 13th 2013, 5:58 pm | |
most mowers can easily have a 6" pully on the motor without interfering with the clutch, and a 6" to a 7" will still get your around 15 and also have small chance for a belt slipping Yea, Thanks! Let Me Ask Again Do You Put The Smaller Pulley On The Motor Or Larger For More Torque? | |
| Subject: Re: What Size Pully? September 13th 2013, 5:59 pm | |
| - Doc Sprocket wrote:
- Things to think about:
Go too small on any pulley, and slippage may prove to be a problem. Increasing belt tension to compensate, only stresses components out more. Speeding up the tranny input too much, can threaten the tranny. Consider "race prepping" your tranny if you're going to run it much faster than stock. Gearing is a matter of mathematics. Calculate the difference between old pulley sizes, and new pulley sizes to see how hard you're pushing it, and what sort of speed you can expect. Watch your clearances. Go too big on the engine pulley, and you might have interferences somewhere... What Size Do You Say Is Too Small? Thankyou. | |
| Subject: Re: What Size Pully? September 13th 2013, 6:00 pm | |
| - willis923 wrote:
- make a mock up of a pully using cardboard to test the clearance of everything. then just double up or beef up the clutch springs. there might be a little slippage, but if you get tighter clutch springs, you might be able to minimize it
Good Idea! I'll Go Ahead And Try That. | |
| Subject: Re: What Size Pully? September 13th 2013, 6:01 pm | |
| - greener179 wrote:
- I agree with Richie the only mowers I really see that need the clutch modded is the ayp brands.
Thanks, For The Advice. | |
| Subject: Re: What Size Pully? September 13th 2013, 6:03 pm | |
- I say 4-4 or 5-5 and beef up the clutch springs.
I don't really know what you mean by "Beef up the clutch springs." | |
| Subject: Re: What Size Pully? September 13th 2013, 9:39 pm | |
I don't really know what you mean by "Beef up the clutch springs." Put stronger ones in there. tractor supply sells some on isle ends. maybe make a mount and run two springs. | |
| Subject: Re: What Size Pully? September 13th 2013, 11:30 pm | |
Ok, I'll go ahead and try that! Should I do that even with a 7" and a 6" | |
