| Pully question | |
Dipshaw87 Member
Age : 29 Join date : 2014-01-02 Points : 4152 Posts : 135 Location : Vanderbilt, Pa
| Subject: Pully question May 14th 2014, 3:15 pm | |
| I have a 14.5 briggs and a 5 speed peerless transaxle. I plan on doing a pulley swap on it. I want to put a 6 inch on the motor and a 5 on the transaxle. Is this a good ratio for mudding? And is there a way to set the governor to 4000 instead of 3600? | |
| | | B440 Member
Join date : 2014-01-22 Points : 4199 Posts : 226 Location : Thompson, CT
| Subject: Re: Pully question May 14th 2014, 9:12 pm | |
| I use a 6" front and 4" rear and it works good, but 5th gear isn't very useful in the woods. I'll be switching back to the stock 6" in the rear. You should have plenty of wheel speed with 6/5 to clean the treads for mudding. | |
| | | Dipshaw87 Member
| | | | Dipshaw87 Member
| Subject: Re: Pully question May 14th 2014, 9:43 pm | |
| Is there anything else I would need to do to it? I'm not locking the rear end. Is there any place I can get cheap atv tires? | |
Age : 25 Join date : 2013-04-05 Points : 4957 Posts : 661 Location : New Smyrna Beach,Fl
| | | | 1997 Murray Veteran Member
Age : 26 Join date : 2013-11-13 Points : 5441 Posts : 1311 Location : NW USA
| Subject: Re: Pully question May 15th 2014, 10:49 am | |
| look in the vendor section, the cheepest i've found yet | |
| | | Dipshaw87 Member
Age : 28 Join date : 2013-04-10 Points : 5756 Posts : 1408 Location : Galway NY
| Subject: Re: Pully question May 15th 2014, 12:14 pm | |
| PM DirtyD on here. he is a tire dealer on here. he has great prices. thats where i got my Executioners from, at almost 20 less than RMCATV | |
| | | Dipshaw87 Member
| | | | Angchor Member
Age : 67 Join date : 2014-04-14 Points : 4414 Posts : 491 Location : Index, Washington
| | | | Sponsored content
| | | | | Pully question | |
| Who is online? | In total there are 7 users online :: 0 Registered, 0 Hidden and 7 Guests
