 Steering and front axle mods
matt-man
6 posters
matt-man
matt-man
Steering and front axle mods Empty
PostSubject: Steering and front axle mods   Steering and front axle mods Icon_minitimeSeptember 7th 2013, 8:45 am
Ok I need to start working on my front end I have a few ideas as to how I should do it but I need to have direct steer, weld the axle, and lower the tractor and as for the direct steer I just want to know what size of rods to run and where I can find them
PostSubject: Re: Steering and front axle mods   Steering and front axle mods Icon_minitimeSeptember 7th 2013, 10:26 am
5/8" Tie-rods or tubular steel, rod. It may still bend if not hardened tho.
matt-man
matt-man
PostSubject: Re: Steering and front axle mods   Steering and front axle mods Icon_minitimeSeptember 7th 2013, 12:35 pm
Well what about 3/4 or 7/8 rod?
PostSubject: Re: Steering and front axle mods   Steering and front axle mods Icon_minitimeSeptember 7th 2013, 2:12 pm
Go as thick as you can afford or have room for. Or just get a proper 5/8 tubing made for the purpose, tho I got some one Ebay, Bet there's loads of places you guys can buy it from.
PostSubject: Re: Steering and front axle mods   Steering and front axle mods Icon_minitimeSeptember 12th 2013, 11:00 am
The "proper" tubing can get expensive. Sch40 gas pipe can work well for applications like this, and is available at big-box hardware stores. 3/8" or even 1/2" black pipe is more than stout enough for all but the worst abuse. Most of us aren't big-budget guys, and I use what I can lay hands on cheaply.
TroyBilt Pony
TroyBilt Pony
PostSubject: Re: Steering and front axle mods   Steering and front axle mods Icon_minitimeSeptember 12th 2013, 11:15 am
I just use threaded rod or solid steel stock
PostSubject: Re: Steering and front axle mods   Steering and front axle mods Icon_minitimeSeptember 12th 2013, 12:08 pm
I'm not keen on threaded rod or "allthread" as some call it. It's basically the crappiest excuse for "steel" that the manufacturer can come up with. It fatigues and breaks quite easily, even in greater thicknesses. If you can weld, pipe or tubing is your best bet. You can either weld a nut to the end of the tube to create a female thread, or cut the head off a bolt and weld that in there to create a male thread. Add your favourite rod end, and you're good to go.
Fwiw, I used to have access to an unlimited supply of threaded rod and have used it for a multitude of things. It's good for mild to moderate tensile loads, and that's about it, really.
PostSubject: Re: Steering and front axle mods   Steering and front axle mods Icon_minitimeSeptember 12th 2013, 1:04 pm
I'm going to jump and and ditto what Doc said. We used all thread for a while, and it would bend way to easy.
Now we use 1/2 steel pipe, and weld 1/2-20 nuts to the ends for tie rods. Quick, easy, and tough when done, if you have a welder handy.
matt-man
matt-man
PostSubject: Re: Steering and front axle mods   Steering and front axle mods Icon_minitimeSeptember 12th 2013, 5:33 pm
Would 1/2 inch conduit work?
PostSubject: Re: Steering and front axle mods   Steering and front axle mods Icon_minitimeSeptember 12th 2013, 6:09 pm
EMT? Nah... too thin. IIRC, 1/2" EMT is somewhere between 16-18ga.
matt-man
matt-man
PostSubject: Re: Steering and front axle mods   Steering and front axle mods Icon_minitimeSeptember 12th 2013, 6:15 pm
English please
PostSubject: Re: Steering and front axle mods   Steering and front axle mods Icon_minitimeSeptember 12th 2013, 6:22 pm
Electrical Metal Tubing. Conduit. Too thin. I actually have a spec sheet here somewhere.
PostSubject: Re: Steering and front axle mods   Steering and front axle mods Icon_minitimeSeptember 13th 2013, 3:14 am
It depends what type of steel you use, not if its threaded or not. But I guess threaded rods are very soft usually.
crazykid1994
crazykid1994
PostSubject: Re: Steering and front axle mods   Steering and front axle mods Icon_minitimeSeptember 13th 2013, 5:56 am
Doc is talking about tubing called irc or intermediate rigid conduit. Its thicker than emt but thinner than rigid. Its also supposed to be as hard as rigid
matt-man
matt-man
PostSubject: Re: Steering and front axle mods   Steering and front axle mods Icon_minitimeSeptember 13th 2013, 7:42 am
I wasnt talking about electrical conduit how about plumbing pipe?
PostSubject: Re: Steering and front axle mods   Steering and front axle mods Icon_minitimeSeptember 13th 2013, 8:19 am
Well, it's like this- you said "conduit". I don't know if it's MAYBE a regional thing, but I have NEVER heard "Water pipe" called "conduit" in the 40 years I have walked the earth. Now, that said- I DID suggest Sch40 pipe. I probably said "gas pipe" but water pipe tends to be the same thing with a galvanized coating. I avoid it because it sometimes costs more with the coating, is more hazardous to weld, and harder to paint properly.
matt-man
matt-man
PostSubject: Re: Steering and front axle mods   Steering and front axle mods Icon_minitimeSeptember 13th 2013, 8:29 am
So what pipe do I need again I'm confused
PostSubject: Re: Steering and front axle mods   Steering and front axle mods Icon_minitimeSeptember 13th 2013, 8:36 am
Just go to Home Depot, and ask for 1/2" Schedule 40 black steel gas pipe. Or Lowes, or whatever huge hardware store chain you got.
» steering rod to axle help
» Front axle camber
» Make your own front 4 wheel drive axle?
» Front axle hubcaps
» Moving front axle forward?
