| Front axle hubcaps | |
TokyoDrift99 Member
Age : 24 Join date : 2014-03-28 Points : 4012 Posts : 111 Location : Vermont
| Subject: Front axle hubcaps May 12th 2014, 9:54 pm | |
| Ok, so this may be a REALLY stupid question, but how do you take off/ put on the dust caps/hubcaps on the front axle? When I took mine off I had to use a small pry bar and Channel lock pliers, I put a hole in one and bent the washer on another. Also when trying to get one back on it seemed way to small to fit over the washer, and I actually destroyed one. I'm sorry I have to ask this stupid question, thanks for any advice. Notice that the hubcap wont fit over the washer. Busted hubcap. | |
Age : 34 Join date : 2013-11-02 Points : 7142 Posts : 2907 Location : New Jersey USA
| Subject: Re: Front axle hubcaps May 12th 2014, 10:29 pm | |
| Probably no good way to get them off without ruining them if they are old and hardened up. Guess their rubber aren't they? Warm it up with a hair dryer or something maybe before you try working it off is all I can think of. | |
| | | TokyoDrift99 Member
| | | | 1997 Murray Veteran Member
Age : 26 Join date : 2013-11-13 Points : 5424 Posts : 1311 Location : NW USA
| Subject: Re: Front axle hubcaps May 13th 2014, 10:27 am | |
| ha, those stupid things are the first thing i took off of my murray when i got it! ripped them off, never looked back. | |
| | | B440 Member
Join date : 2014-01-22 Points : 4182 Posts : 226 Location : Thompson, CT
| Subject: Re: Front axle hubcaps May 14th 2014, 12:29 pm | |
| +1 on heat. That will make them soft and pliable again, for about a minute. | |
| Subject: Re: Front axle hubcaps May 14th 2014, 1:00 pm | |
| try putting on one side and using a pick tool to pull the other side on. | |
