| | General Mayhem- Race Tractor | |
+121997 Murray murrayracer LAWN MOWER MUDDER TennesseeCowboy MowBandit TheRainbowBoxer TheBeal Murray modder redlinemotorsportts k2500life Stretch44875 Doc Sprocket 16 posters | |
Doc Sprocket Site VIP
| Subject: Re: General Mayhem- Race Tractor August 20th 2013, 2:19 pm | |
| You bet your belt it is!!! No guesswork- measure and go. No buying 3 or 4 and returning the wrong ones. I stopped at this sale one day and spotted it in a corner. I asked, and the guy wasn't even clear what it was. He asked for $2, and I whipped out the cash so fast my wallet smoked! | |
Age : 49 Join date : 2012-04-23 Points : 5667 Posts : 1091 Location : Galion, OH
| Subject: Re: General Mayhem- Race Tractor August 20th 2013, 2:25 pm | |
| Stretch literally has a few hundred belts hanging up in his garage... the first task of one of those tools in his garage would be to measure and tag all of them. That would beat the heck out of holding up belts one by one to the broken one trying to find a match. | |
| | | MowBandit Member
Age : 28 Join date : 2013-03-16 Points : 4715 Posts : 477 Location : Haddock,Georgia
Age : 51 Join date : 2013-04-21 Points : 7284 Posts : 2914 Location : Ontario Canada
| Subject: Re: General Mayhem- Race Tractor August 21st 2013, 8:44 am | |
| Hey, that's okay! Sarge... General.... Makes sense to me! And while the General's working on lap times, Sarge can climb the bleachers! LOL | |
| | | TennesseeCowboy Member
Age : 28 Join date : 2012-08-05 Points : 4592 Posts : 124 Location : TEN-A-SAYY
| Subject: Re: General Mayhem- Race Tractor August 21st 2013, 3:44 pm | |
| Im loving this build. I've always been a fan of the flat olive drab paint on vehicles. How much speed are you looking to get out of it? | |
| Subject: Re: General Mayhem- Race Tractor August 21st 2013, 5:30 pm | |
| Thanks! probably~40 MPH. Maybe even a bit slower. The tracks are fairly short and round, so top speed takes a back seat to acceleration. Gotta be able to get up and go off the line, rather than win a drag race. | |
| Subject: Re: General Mayhem- Race Tractor August 21st 2013, 6:26 pm | |
| - Doc Sprocket wrote:
- Thanks! probably~40 MPH. Maybe even a bit slower. The tracks are fairly short and round, so top speed takes a back seat to acceleration. Gotta be able to get up and go off the line, rather than win a drag race.
Makes sense haha. I wish I had some people to race with here. | |
| | | MowBandit Member
| Subject: Re: General Mayhem- Race Tractor August 21st 2013, 7:07 pm | |
- Hey, that's okay! Sarge... General.... Makes sense to me! And while the General's working on lap times, Sarge can climb the bleachers! LOL
reading this just made my day man lol for a few hours i thought about selling Sarge to fulling turn black widow into a true racing mower but nah reading this has changed my mind lol ive got a few plans i gotta do to sarge before i fully release the info | |
| Subject: Re: General Mayhem- Race Tractor August 31st 2013, 9:36 am | |
| I'm not doing much for updates right now, because I'm not doing much work on it right now. As I recuperate from surgery, I'm somewhat limited in my abilities. Right now I am concentrating on all the little fiddly bits that would normally annoy me. I re-centered and trimmed the rear axle for length, adjusted and set all the lock collars and keys, etc. I got the final drive chain cut to length, installed, and the tensioner adjusted. I'm going to have to remove the transmission and adjust the bolt holes a touch. I noticed yesterday during chain alignment that the gearbox is not perfectly square to the chassis, and I'm not keen on throwing the chain a bunch of times.
Then, I'm going to grind a bevel into a collar and weld it to the tranny plate to serve as a support for the tranny input.
Another thing I did was to move the brake master cylinder to the right-hand side of the frame. I had planned to put the brake on the left and the clutch on the right. I did this based on a write up from a veteran racer who argued that going around a left handed circle with a ton of weight on your right foot made it difficult to adequately control braking with your right foot. After originally mocking it up and careful consideration, I have decided to take a pass on this. As a veteran of driving conventional vehicles and NOT specially built racers, I am convinced it will be too confusing. All I need is for things to get hairy on my first or second race and instinct tells me my right foot is going to brake my to safety... but it's the dang clutch! *BOOM*
So, the brake will be reconfigured on the right as is the norm, and the clutch on the left. | |
Age : 27 Join date : 2013-03-18 Points : 7449 Posts : 3131 Location : raleigh nc
| Subject: Re: General Mayhem- Race Tractor September 29th 2013, 10:55 pm | |
| would you be kind enough to take a picture of the tensioner? Also, (without a chain breaker or press) how can you cut the chain accordingly? Just grind the pin off and slide the pin out, and adding a master link? | |
| Subject: Re: General Mayhem- Race Tractor September 30th 2013, 10:23 am | |
- would you be kind enough to take a picture of the tensioner?
Certainly. I'll shoot a pic as soon as I have the chance. - redlinemotorsportts wrote:
- Also, (without a chain breaker or press) how can you cut the chain accordingly? Just grind the pin off and slide the pin out, and adding a master link?
That's exactly how you'd do it. After grinding, you'll likely have to drive it out with a punch (or nail, or whatever you have). | |
Age : 23 Join date : 2013-04-08 Points : 5175 Posts : 913 Location : Central Pa
| Subject: Re: General Mayhem- Race Tractor November 2nd 2013, 11:50 am | |
| No- I've been busy enough with everything else. However- winter is coming, and it's one of only two projects that I have space for in my garage, so I oughta be getting back into it shortly. I think I'm going to do a full engine overhaul while I'm at it. It did run well when I took it down, but it had some leaks, and after cleaning it I found where a previous owner had JB Welded a repair on the case. The repair seems to have held, but the last thing I need is to have it let go under the rigours of racing and blow my oil all over the track. Seizure then, is only mere moments away. Fortunately, I bought a parts engine when I started the project, so if I need it, I've got it. | |
| | | murrayracer Member
Age : 27 Join date : 2013-07-14 Points : 4221 Posts : 84 Location : Benton city, WA
| | | | 1997 Murray Veteran Member
Age : 26 Join date : 2013-11-13 Points : 5412 Posts : 1311 Location : NW USA
| | | | matt-man Member
Age : 27 Join date : 2013-07-26 Points : 4357 Posts : 221 Location : North Fort Myers, Florida
| Subject: Re: General Mayhem- Race Tractor March 21st 2014, 10:02 pm | |
| No- I was supposed to get back on it this winter. Didn't happen, too much going on. I have till late summer to finish it, in time for the fall agricultural fair exhibition races. | |
| | | Mitch'sgarage Member
Age : 25 Join date : 2014-03-24 Points : 3908 Posts : 46 Location : Omaha, Nebraska
| Subject: Re: General Mayhem- Race Tractor June 19th 2014, 9:11 am | |
| Man this thing is looking sweet! I cannot wait to see it done. You should make a video so we can all hear that beautiful twin run. | |
| Subject: Re: General Mayhem- Race Tractor June 19th 2014, 7:43 pm | |
| Thank you. I haven't touched this one it quite some time. I have been busy with both life, and other projects. However... If I wish to race it this fall in the ag fair circuit (which I DO), I need to get back into it pretty soon. | |
| | | Hillbilly Offroading Established Member
2019 Build-Off Entrant
1st Place Build-Off 2020
Age : 22 Join date : 2018-11-09 Points : 2819 Posts : 582 Location : Reeses Mill, WV
| | | | JohnLidell New Member
Age : 26 Join date : 2019-10-03 Points : 1847 Posts : 5 Location : United States
| | | | Sponsored content
| Who is online? | In total there are 19 users online :: 0 Registered, 0 Hidden and 19 Guests
