 How do i find the belt size?
2 posters
lane85
lane85
How do i find the belt size? Empty
PostSubject: How do i find the belt size?   How do i find the belt size? Icon_minitimeAugust 13th 2013, 6:04 pm
i have a 1964 simplicty brodmoor 707 with a white half steering wheel its a beast it has ag tires but its so slow! i told my dad he can pully swap it but the last tractor i pully swaped the clutch doesent work now he asked me to find out how to find the belt size corectly after pully swaping the back smaller so the clutch works any answers on how to?
crazykid1994
crazykid1994
PostSubject: Re: How do i find the belt size?   How do i find the belt size? Icon_minitimeAugust 13th 2013, 6:08 pm
sometimes you need to redesign the clutch.... but to find the proper belt size take a piece of rope and some tape.... make sure your clutch is pressed in and locked... wrap the rope through the pulleys the way it is ment to go. and pull it tight now mark where the end of the rope meets and add an inch to that. that should work.
lane85
lane85
PostSubject: Re: How do i find the belt size?   How do i find the belt size? Icon_minitimeAugust 13th 2013, 6:16 pm
If i decrees 4 inches from 9in to 5in how do i figure out the belt size just
crazykid1994
crazykid1994
PostSubject: Re: How do i find the belt size?   How do i find the belt size? Icon_minitimeAugust 13th 2013, 6:17 pm
doing what i mentioned. honestly. thats the only way i know because different size pulley changes how the belt sits so you just have to measure
lane85
lane85
PostSubject: Re: How do i find the belt size?   How do i find the belt size? Icon_minitimeAugust 13th 2013, 6:29 pm
well is i went from 9 to 5 a 4 inch decrees do you think 2 inches shorter of a belt would work?
crazykid1994
crazykid1994
PostSubject: Re: How do i find the belt size?   How do i find the belt size? Icon_minitimeAugust 13th 2013, 6:33 pm
no clue. lol trial and error or just measure. i couldnt tell you
lane85
lane85
PostSubject: Re: How do i find the belt size?   How do i find the belt size? Icon_minitimeAugust 13th 2013, 6:37 pm
well thanks anyway man!
crazykid1994
crazykid1994
PostSubject: Re: How do i find the belt size?   How do i find the belt size? Icon_minitimeAugust 13th 2013, 6:44 pm
measuring is the easiest way. sorry if i didnt help much. there is not set belt size for each pulley size set up
» what belt size should i need
» Belt size help
» belt size help and pulley
» whats the drive belt size for a bolens stg 125
