 Belt size help
murraymnan96
6 posters
murraymnan96
Belt size help Empty
PostSubject: Belt size help   Belt size help Icon_minitimeJanuary 30th 2013, 5:22 pm
I just successfully completed a pulley swap on my Murray Very Happy . I replaced the old transaxle pulley with a smaller one. My old belt was a 37x87. I have to take 3 inches off of it to make it fit. Obviously you cant just cut and weld a belt back together so I need to know what I need for a replacement belt, don't know a lot about sizing of belts and whatnot and Google didn't help, any help at all would be greatly appreciated. Question
PostSubject: Re: Belt size help   Belt size help Icon_minitimeJanuary 30th 2013, 5:36 pm
If you know it needs 3" less then go to a hardware stroe and buy a 3" shorter belt.
Marines2621
Marines2621
PostSubject: Re: Belt size help   Belt size help Icon_minitimeJanuary 30th 2013, 6:58 pm
For my mower i cut the belt in 2 and got my right measurement by cutting. Then layed it straight and measured it with a tape measure then i got my belt. Easy
CornishMorgan
PostSubject: Re: Belt size help   Belt size help Icon_minitimeJanuary 30th 2013, 8:21 pm
If you need to find out the belt size, try this http://www.blocklayer.com/pulley-belt.aspx
tractorboy567
tractorboy567
PostSubject: Re: Belt size help   Belt size help Icon_minitimeJanuary 31st 2013, 9:59 am
Take a rope and use it as a mock up belt and use it to size
PostSubject: Re: Belt size help   Belt size help Icon_minitimeApril 5th 2013, 1:35 am
This is sweet tool to calculate MPH and what your max/min pulleys can be.
Belt size help
» what belt size should i need
» belt size help and pulley
» How do i find the belt size?
» whats the drive belt size for a bolens stg 125
