| what belt size should i need | |
+4meigs man crazykid1994 TroyBilt Pony axemanjr 8 posters |
axemanjr New Member
| Subject: what belt size should i need August 3rd 2013, 12:30 am | |
| im new to this im doing pully swap it had 3 inch on front and 8 3/4 inch on rear stock belt for the ford lt8 from what i found on the web is 84inch. pullys just came in today going to start puting them on tommorow im going to 5 3/4 inch in front and 2.25 inch in rear i should i just take away the differcne which would be 4inch or do i need to take moore | |
Join date : 2013-06-01 Points : 4810 Posts : 578 Location : West Virginia
| Subject: Re: what belt size should i need August 3rd 2013, 1:04 pm | |
| Just take a guess.. if it dont fit take it back anf guess again.. or buy a few belts tthen taje the ones back that dont fit.. | |
Age : 30 Join date : 2013-03-18 Points : 4925 Posts : 618 Location : loxahatchee, florida
| Subject: Re: what belt size should i need August 3rd 2013, 1:13 pm | |
| take some rope and put it through the pulleys like the belt goes and make sure the clutch is in. than cut the rope or put tape where the ends meet leaving it a little slack. and that should be your length | |
meigs man New Member
Age : 60 Join date : 2013-05-17 Points : 4228 Posts : 20 Location : Pomeroy Ohio
Doug Site Owner
| Subject: Re: what belt size should i need August 3rd 2013, 4:31 pm | |
| - crazykid1994 wrote:
- take some rope and put it through the pulleys like the belt goes and make sure the clutch is in. than cut the rope or put tape where the ends meet leaving it a little slack. and that should be your length
I wouldnt do all the way in. Maybe 2/3 of the way in, but all the way wont get the best tension. Head Forum Administrator ** Chat Moderator ** Facebook Page AdminATLTF Facebook Page ** Chatbox ** How To Upload Pictures
Kody6 Member
Age : 24 Join date : 2013-07-10 Points : 4249 Posts : 76 Location : Haileybury, ONT
| Subject: Re: what belt size should i need August 19th 2013, 7:13 pm | |
| What belt size would I need if I have a 4 inche pulley on the transmission and a vari drive systeme | |
| Subject: Re: what belt size should i need August 19th 2013, 9:08 pm | |
| Take a piece of rope and run it around the pullys and tie it off then measure it and get your belt. | |
Murray modder Member
Join date : 2012-11-23 Points : 4801 Posts : 356 Location : Somewher in Va
| Subject: Re: what belt size should i need August 19th 2013, 9:29 pm | |
| - Kody6 wrote:
- What belt size would I need if I have a 4 inche pulley on the transmission and a vari drive systeme
Vari drive has 2 belts... | |
Kody6 Member
| Subject: Re: what belt size should i need August 19th 2013, 10:31 pm | |
| - Kody6 wrote:
- Sorry what belt size would I need on the transmission
Depends on your distance the two pulleys, and the Vari-drive pulley. | |
Kody6 Member
| Subject: Re: what belt size should i need August 20th 2013, 8:02 am | |
| - LAWN MOWER MUDDER wrote:
- Take a piece of rope and run it around the pullys and tie it off then measure it and get your belt.
Like I said but just around the vari-drive, idler, and rear pulley. | |
