| | My ford LT 10 | |
+12k2500life willis923 MowBandit crazykid1994 greener179 Doc Sprocket Stretch44875 Marines2621 Thunderdivine craftsmancole redlinemotorsportts xxXMowerdudeXxx 16 posters | |
xxXMowerdudeXxx Established Member
![My ford LT 10 - Page 2 Empty](https://2img.net/i/empty.gif) | Subject: Re: My ford LT 10 August 4th 2013, 10:33 pm | |
- estimated speed now?
oh yeah, im going for 60 | |
| ![Go down](https://2img.net/i/empty.gif) | | xxXMowerdudeXxx Established Member
![My ford LT 10 - Page 2 Empty](https://2img.net/i/empty.gif) | | ![Go down](https://2img.net/i/empty.gif) | | Doc Sprocket Site VIP
![My ford LT 10 - Page 2 Empty](https://2img.net/i/empty.gif) | Subject: Re: My ford LT 10 September 13th 2013, 8:49 am | |
| - xxXMowerdudeXxx wrote:
- Stretch44875 wrote:
- Okay, now I'm confused. I thought you were using a 700 peerless at some point, but don't see that in the thread. Using the transaxle as a transmission will be tricky, as Doc pointed out. I don't know if it will handle the stress if you drive it with one axle, and lock it.
And then I see you want to mow with it? And do 65, and do haspin, and spend who knows how much? I put countless hours of experience, planing, building, and lots of money, just to have a reliable race/offroad mower, that does 45.
This is beginning to sound like a what if thread. What exactly do you want it to do, and what parts do you have?
i dont know where the thing about the tranny came from.
ok, heres the plan, new and updated. ford frame, reinforced, with a 18hp v twin im not sure im getting it yet but thats the plan other wise im using my 16hp opposy, 7in pully on the engine, going to a 3.5in on the rear, rear end will be a 3/5 speed peerless 700, using #40 chain, 12 tooth sprocket onv tranny to a 45ish for a 3 speed, 16 to 60ish for 5 speed, going to a 1 1/4in chromly axle with high speed bearings off bmi carts, see pic, with 4x4 hubs to 4x4 tires with 18in turfs, for the front will be your front end edited a bit, with direct steer, 3/4in axles and 3 bolt high speed hubs with rims and 13in tire, and breaks are going to be mechanical with a 8in disc. thats all i got so far, lots to do before i need to worry more Before you get all "calculatered out"... You might want to wait and see what you get. I see that you have theoretical pulley sizes selected, and theoretical sprocket selections based on whether you get a 3spd or 5spd 700. Stop and take a breath. The Peerless 700 is available commonly in 3,4, and 5 speed configurations, and some documentation I found suggests a rare 2 speed. The high ratio can vary, and it does NOT necessarily depend on how many gears it has- so don't plan your sprockets until you have a 700 in hand- you never know what you're going to get! (I'm writing an article on the 700. I SHOULD finish...) | |
![My ford LT 10 - Page 2 Empty](https://2img.net/i/empty.gif) | Subject: Re: My ford LT 10 September 13th 2013, 9:17 am | |
| I have a 5speed 700, and theres a rare 6speed | |
![My ford LT 10 - Page 2 Empty](https://2img.net/i/empty.gif) | Subject: Re: My ford LT 10 September 13th 2013, 10:01 am | |
| I have found no suggestion ANYWHERE that a 6-speed 700 was ever made. And I have a lot of documentation. Six gearsets will certainly not fit in a standard 700 casing, either. So- I got no idea where you got that... Got a link or something? | |
| ![Go down](https://2img.net/i/empty.gif) | | greener179 Member
![greener179](https://2img.net/h/i1169.photobucket.com/albums/r507/mudmower16/profile_zps224b9c20.jpg)
![My ford LT 10 - Page 2 Empty](https://2img.net/i/empty.gif) | Subject: Re: My ford LT 10 September 13th 2013, 2:37 pm | |
| i came across alittle info on a 6 speed peerless 700 to when i was looking up gear ratios. | |
| ![Go down](https://2img.net/i/empty.gif) | | crazykid1994 Established Member
![crazykid1994](https://2img.net/u/2812/37/66/46/avatars/750-21.jpg)
Age : 29 Join date : 2013-03-18 Points : 4851 Posts : 618 Location : loxahatchee, florida
![My ford LT 10 - Page 2 Empty](https://2img.net/i/empty.gif) | | ![Go down](https://2img.net/i/empty.gif) | | xxXMowerdudeXxx Established Member
![My ford LT 10 - Page 2 Empty](https://2img.net/i/empty.gif) | | ![Go down](https://2img.net/i/empty.gif) | | redlinemotorsportts Moderator
![My ford LT 10 - Page 2 Empty](https://2img.net/i/empty.gif) | Subject: Re: My ford LT 10 September 14th 2013, 5:23 pm | |
- What did you trade for it?
the cub | |
![My ford LT 10 - Page 2 Empty](https://2img.net/i/empty.gif) | Subject: Re: My ford LT 10 September 14th 2013, 5:28 pm | |
the cub Lol glad to have that outta your hair I bet | |
![My ford LT 10 - Page 2 Empty](https://2img.net/i/empty.gif) | | ![Go down](https://2img.net/i/empty.gif) | | Guest Guest
![My ford LT 10 - Page 2 Empty](https://2img.net/i/empty.gif) | Subject: Re: My ford LT 10 September 14th 2013, 8:16 pm | |
| no it's not, needs to be in my build lol |
![My ford LT 10 - Page 2 Empty](https://2img.net/i/empty.gif) | Subject: Re: My ford LT 10 September 14th 2013, 8:52 pm | |
| Hmm... S that's how an oppy would look in MULE... LOL
Looks good. You got the left side head shroud? | |
![My ford LT 10 - Page 2 Empty](https://2img.net/i/empty.gif) | Subject: Re: My ford LT 10 September 14th 2013, 8:53 pm | |
| - Doc Sprocket wrote:
- Hmm... S that's how an oppy would look in MULE... LOL
Looks good. You got the left side head shroud? nope, nor do i have the air box -_- | |
| ![Go down](https://2img.net/i/empty.gif) | | craftsmancole Established Member
![craftsmancole](https://2img.net/u/2812/37/66/46/avatars/817-65.jpg)
Age : 25 Join date : 2013-04-05 Points : 4888 Posts : 661 Location : New Smyrna Beach,Fl
![My ford LT 10 - Page 2 Empty](https://2img.net/i/empty.gif) | Subject: Re: My ford LT 10 September 14th 2013, 8:58 pm | |
| Lol, my craftsmans oppy is missing the same things | |
![My ford LT 10 - Page 2 Empty](https://2img.net/i/empty.gif) | Subject: Re: My ford LT 10 September 14th 2013, 9:00 pm | |
| - craftsmancole wrote:
- Lol, my craftsmans oppy is missing the same things
XD | |
![My ford LT 10 - Page 2 Empty](https://2img.net/i/empty.gif) | Subject: Re: My ford LT 10 September 15th 2013, 8:41 am | |
| If you're somewhat creative (and you HAVE to be, to live here at ATLTF, LOL) you might be able to come up with some temporary workarounds until you source the right parts. I made an air filter from a tuna can once (can link you if you want to see the example) and the Twin carbs have a great surface to work with. As for the head shroud- I personally would not run without it, as that head will get hot, but you might be able to throw together some sheetmetal to direct the air through the cooling fins. | |
![My ford LT 10 - Page 2 Empty](https://2img.net/i/empty.gif) | Subject: Re: My ford LT 10 September 15th 2013, 10:21 am | |
| I would, but I'm just selling it and he'll have to fix the problems, it runs and drives tho | |
![My ford LT 10 - Page 2 Empty](https://2img.net/i/empty.gif) | Subject: Re: My ford LT 10 September 15th 2013, 12:12 pm | |
| i wish i would have not gotten that engine... head #1 ![My ford LT 10 - Page 2 Img_1530](https://i.servimg.com/u/f73/18/14/68/87/img_1530.jpg) Cil #1 ![My ford LT 10 - Page 2 Img_1531](https://i.servimg.com/u/f73/18/14/68/87/img_1531.jpg) Head #2 ![My ford LT 10 - Page 2 Img_1532](https://i.servimg.com/u/f73/18/14/68/87/img_1532.jpg) Cil #2 ![My ford LT 10 - Page 2 Img_1533](https://i.servimg.com/u/f73/18/14/68/87/img_1533.jpg) | |
| ![Go down](https://2img.net/i/empty.gif) | | Stretch44875 Administrator
![Stretch44875](https://2img.net/u/2812/37/66/46/avatars/314-28.jpg)
Age : 49 Join date : 2012-04-05 Points : 5627 Posts : 959 Location : Mansfield, Ohio
![My ford LT 10 - Page 2 Empty](https://2img.net/i/empty.gif) | Subject: Re: My ford LT 10 September 16th 2013, 9:18 am | |
| Don't see anything wrong, just dirty. Clean, new gaskets, plugs, and run. | |
![My ford LT 10 - Page 2 Empty](https://2img.net/i/empty.gif) | Subject: Re: My ford LT 10 September 16th 2013, 10:55 am | |
- Don't see anything wrong, just dirty. Clean, new gaskets, plugs, and run.
As long as the cyl isn't scared then its fine | |
![My ford LT 10 - Page 2 Empty](https://2img.net/i/empty.gif) | Subject: Re: My ford LT 10 September 16th 2013, 11:05 am | |
| Im still trying to figure out howall tha sand got in it... On the one side the black sopts that are thick, its oil carbon and sand | |
![My ford LT 10 - Page 2 Empty](https://2img.net/i/empty.gif) | | ![Go down](https://2img.net/i/empty.gif) | | Sponsored content
![My ford LT 10 - Page 2 Empty](https://2img.net/i/empty.gif) | | ![Go down](https://2img.net/i/empty.gif) | | | My ford LT 10 | |
| Who is online? | In total there are 135 users online :: 0 Registered, 0 Hidden and 135 Guests
