 My ford LT 10
MowBandit
crazykid1994
greener179
Marines2621
xxXMowerdudeXxx
16 posters
Go to page : 1, 2, 3, 4  Next
xxXMowerdudeXxx
My ford LT 10 Empty
PostSubject: My ford LT 10   My ford LT 10 Icon_minitimeJuly 29th 2013, 9:47 pm
This is how is how it looks now
My ford LT 10 Img_1222
Plan is to make it go as fast as I can and still be able to mow in 1st
first things first, crack open the tranny to see if the thing is in ok condition,
My ford LT 10 Img_1229
everything appears to be intact, still gotta check the shift keys add some grease and bit of gear oil, seal it up and call that good for the tranny. Its a peerless 900 031. its going to get a ratio of 6in on the motor and a 4in on the trans, like i said i still wanna mow with it, so tell me what ya'll think and Thanks for reading
Last edited by xxXMowerdudeXxx on August 17th 2013, 2:18 am; edited 2 times in total
My ford LT 10 Empty
PostSubject: Re: My ford LT 10   My ford LT 10 Icon_minitimeJuly 29th 2013, 10:21 pm
*squints* is the bull gear off to the right of the spider gear pin? im not shure I guess that's how it is. huh, outside looks nasty lol, pull the gears and clean it up
xxXMowerdudeXxx
My ford LT 10 Empty
PostSubject: Re: My ford LT 10   My ford LT 10 Icon_minitimeJuly 29th 2013, 10:27 pm
 its VERY nasty, theres no sealer on it, wonder y? lol
My ford LT 10 Empty
PostSubject: Re: My ford LT 10   My ford LT 10 Icon_minitimeJuly 30th 2013, 1:49 am
my foote hat i used to have (broke it) was gease filled had no sealent and it had never been opened
xxXMowerdudeXxx
My ford LT 10 Empty
PostSubject: Re: My ford LT 10   My ford LT 10 Icon_minitimeJuly 30th 2013, 2:56 pm
ill let the pics speak for themselves Smile
My ford LT 10 Img_1230
My ford LT 10 Img_1231
My ford LT 10 Img_1232
My ford LT 10 Img_1233
My ford LT 10 Img_1234
My ford LT 10 Img_1235
xxXMowerdudeXxx
My ford LT 10 Empty
PostSubject: Re: My ford LT 10   My ford LT 10 Icon_minitimeJuly 31st 2013, 12:14 pm
tight fit ? lol
 My ford LT 10 Img_1249
My ford LT 10 Img_1250
xxXMowerdudeXxx
My ford LT 10 Empty
PostSubject: Re: My ford LT 10   My ford LT 10 Icon_minitimeAugust 1st 2013, 1:30 pm
ok, ive been making some plans and looking for parts i need to buy.
http://www.bmikarts.com/Axle-Shaft--1-x-39-38_p_518.html
^ axle i think im going to get
http://www.bmikarts.com/White-4-x-4-Wheel-Hub-1-Bore_p_1662.html
^ hubs i think i'm gonna get
http://www.bmikarts.com/Flanged-High-Speed-Wheel-Bearing-34-x-1-38_p_2369.html
bearings for the front, i belive they will fit if i pop out the old front bushings, the outside diameter is like 1.5 ins and the bearings are 1 3/8, so the bearings should fit.
before i buy all this stuff im going to build a front axle that can handle the speeds and abuse
im up to 90 bucks in this thing with just those parts above.
My ford LT 10 Empty
PostSubject: Re: My ford LT 10   My ford LT 10 Icon_minitimeAugust 1st 2013, 5:08 pm
I choose these, http://www.bmikarts.com/Galvanize-4-x-4-Wheel-Hub-1-Bore_p_1661.html
With those you can choose to mount the hub to make it wider. Those whites You cn't. And cheaper too.
Also compare prizes with both BMI and MFG Supply, Ask them for a good price if you get all at once.
tight fit indeed, lol
Marines2621
Marines2621
My ford LT 10 Empty
PostSubject: Re: My ford LT 10   My ford LT 10 Icon_minitimeAugust 1st 2013, 7:08 pm
That looks like a good strong chassis
My ford LT 10 Empty
PostSubject: Re: My ford LT 10   My ford LT 10 Icon_minitimeAugust 1st 2013, 7:40 pm
How about combining the two threads, keep everything in one place. Lot of overlap.
No need to overspeed the transmission, use the kart axle and sprockets to gear it up to the speed you want. 6in front and rear would be fine for the transmission.
xxXMowerdudeXxx
My ford LT 10 Empty
PostSubject: Re: My ford LT 10   My ford LT 10 Icon_minitimeAugust 1st 2013, 8:41 pm
i dont think some people under stand, the ford im going to go full racer, wide the wheel base(some) im going to get good brakes im going to make sure the steering is good and tight im going for 65 building it for 70 ill probably never go over 55,well i will once or twice. but, point being im going to build it right even if it takes me a whole year to get the cash to get good parts.
xxXMowerdudeXxx
My ford LT 10 Empty
PostSubject: Re: My ford LT 10   My ford LT 10 Icon_minitimeAugust 1st 2013, 8:44 pm
My ford LT 10 Empty
PostSubject: Re: My ford LT 10   My ford LT 10 Icon_minitimeAugust 1st 2013, 9:48 pm
My ford LT 10 Empty
PostSubject: Re: My ford LT 10   My ford LT 10 Icon_minitimeAugust 1st 2013, 9:55 pm
Stretch, MD explained to me the reason the threads are not combined is due to some explanation expected on how you do your axles so that he may incorporate it into his build and yet leave it as a how-to for everyone else wanting to do the same.
MD - I think its a killer build bud....
xxXMowerdudeXxx
My ford LT 10 Empty
PostSubject: Re: My ford LT 10   My ford LT 10 Icon_minitimeAugust 1st 2013, 9:56 pm
xxXMowerdudeXxx
My ford LT 10 Empty
PostSubject: Re: My ford LT 10   My ford LT 10 Icon_minitimeAugust 3rd 2013, 5:17 pm
the parts list is getting longer Smile
My ford LT 10 Bmi11
the enine renfocements, just needs to be welded
My ford LT 10 Img_1261
xxXMowerdudeXxx
My ford LT 10 Empty
PostSubject: Re: My ford LT 10   My ford LT 10 Icon_minitimeAugust 3rd 2013, 7:49 pm
hey, need help, what should i set the castor at to handle 65? and im only going 60 but would like to be safe at 60 and build it for 65. should i do 10 like stretch did?
My ford LT 10 Empty
PostSubject: Re: My ford LT 10   My ford LT 10 Icon_minitimeAugust 3rd 2013, 9:05 pm
To much is worse than none, so maybe a 5-8.
6" Wheels?
xxXMowerdudeXxx
My ford LT 10 Empty
PostSubject: Re: My ford LT 10   My ford LT 10 Icon_minitimeAugust 3rd 2013, 9:17 pm
6in rims, 13in tires
My ford LT 10 Empty
PostSubject: Re: My ford LT 10   My ford LT 10 Icon_minitimeAugust 4th 2013, 7:07 am
Kool
My ford LT 10 Empty
PostSubject: Re: My ford LT 10   My ford LT 10 Icon_minitimeAugust 4th 2013, 8:53 am
I completely agree. Let's not stress that sucker out any more than we have to. By the same token, you've got to keep the sprocket sizes reasonable. I suspect that the end result would require a pulley swap (not as extreme though) AND careful sprocket selection.
Now- you're using a transaxle (as opposed to a transmission). How do you plan to locate and drive that rear axle? If the transaxle were to remain more or less in it's stock location, you'd have to locate the axle several inches away in order to leave room for the final drive sprockets. Since a shorter wheelbase isn't a good idea, I guess you're going to strecth it, or did I miss something?
Also- with an open differential in the transaxle, you will be forced to do one of two things- either lock it and take the output off one side to the the axle, OR you'll have to run redundant sprockets and chains off BOTH sides of the transaxle to the axle. Leave one side open, and you won't move.
IMO- you're better off just shopping for a transmission, but I understand that you want to use what you already have.
My ford LT 10 Empty
PostSubject: Re: My ford LT 10   My ford LT 10 Icon_minitimeAugust 4th 2013, 11:44 am
Okay, now I'm confused. I thought you were using a 700 peerless at some point, but don't see that in the thread. Using the transaxle as a transmission will be tricky, as Doc pointed out. I don't know if it will handle the stress if you drive it with one axle, and lock it.
And then I see you want to mow with it? And do 65, and do haspin, and spend who knows how much? I put countless hours of experience, planing, building, and lots of money, just to have a reliable race/offroad mower, that does 45.
This is beginning to sound like a what if thread. What exactly do you want it to do, and what parts do you have?
xxXMowerdudeXxx
My ford LT 10 Empty
PostSubject: Re: My ford LT 10   My ford LT 10 Icon_minitimeAugust 4th 2013, 10:03 pm
i dont know where the thing about the tranny came from.
ok, heres the plan, new and updated. ford frame, reinforced, with a 18hp v twin im not sure im getting it yet but thats the plan other wise im using my 16hp opposy, 7in pully on the engine, going to a 3.5in on the rear, rear end will be a 3/5 speed peerless 700, using #40 chain, 12 tooth sprocket onv tranny to a 45ish for a 3 speed, 16 to 60ish for 5 speed, going to a 1 1/4in chromly axle with high speed bearings off bmi carts, see pic, with 4x4 hubs to 4x4 tires with 18in turfs, for the front will be your front end edited a bit, with direct steer, 3/4in axles and 3 bolt high speed hubs with rims and 13in tire, and breaks are going to be mechanical with a 8in disc. thats all i got so far, lots to do before i need to worry more
My ford LT 10 Empty
PostSubject: Re: My ford LT 10   My ford LT 10 Icon_minitimeAugust 4th 2013, 10:26 pm
estimated speed now?
xxXMowerdudeXxx
My ford LT 10 Empty
PostSubject: Re: My ford LT 10   My ford LT 10 Icon_minitimeAugust 4th 2013, 10:33 pm
oh yeah, im going for 60
My ford LT 10 Empty
My ford LT 10
Page 1 of 4Go to page : 1, 2, 3, 4  Next
» Ford Super 34 Snowblower For a Ford 100
» Ford Wheeler "Ford 100"
» New ford gt85!
» my 80s ford yt16
» Ford YT 18H Transaxle
