 Puzzling Westwood Gazelle handbrake
2 posters
FOSWMT
FOSWMT
Puzzling Westwood Gazelle handbrake Empty
PostSubject: Puzzling Westwood Gazelle handbrake   Puzzling Westwood Gazelle handbrake Icon_minitimeJuly 29th 2013, 12:19 pm
I have a Westwood Gazelle W11 and am currently refurbishing the brakes as they were a mess. I have noticed there is an extension on the brake bar that looks as if it would latch the brake on through depressing the knob by the seat. Is this correct way of engaging the handbrake. Does the brake have to be adjusted correctly so that this will work please?
http://www.friendsofspeckledwood.org.uk
PostSubject: Re: Puzzling Westwood Gazelle handbrake   Puzzling Westwood Gazelle handbrake Icon_minitimeJuly 29th 2013, 12:23 pm
westwoods are not common, you will have to take a picture of what your talking about and hopefully we can help you figure it out. I doubt anyone knows off the top of there head how it works.
FOSWMT
FOSWMT
PostSubject: Re: Puzzling Westwood Gazelle handbrake   Puzzling Westwood Gazelle handbrake Icon_minitimeJuly 29th 2013, 12:43 pm
I think its the same as the craftsman and Countax I have a PDF here
http://static.fatsoma.com/gts-pdfs/westwood/westwood-83.pdf Look down to the W11. Thank you for your help as this is a puzzle and the instruction manual suggest twisting the clutch brake to engage the hand brake which doesnt seem to do anything
FOSWMT
FOSWMT
PostSubject: Re: Puzzling Westwood Gazelle handbrake   Puzzling Westwood Gazelle handbrake Icon_minitimeJuly 29th 2013, 4:09 pm
I have been out and took some pictures of he brake and what i think is the handbrake. Even though I have the brake working I cannot figure out how the hand brake functions through this leaver. There is a bar at 45 degrees to the break rod that I think is supposed to catch when this brake and lever is depressed it doesn't seem to work though . Does any one have any ideas.
Puzzling Westwood Gazelle handbrake SAM_2982
Puzzling Westwood Gazelle handbrake SAM_2983
PostSubject: Re: Puzzling Westwood Gazelle handbrake   Puzzling Westwood Gazelle handbrake Icon_minitimeJuly 29th 2013, 5:53 pm
does the brake come on when you push down the clutch? it looks like someone made an extension for the factory brake lever on the transmission. its possible someone switched up how the brake functions vs a bone stock tractor and that is why your handbrake/parking brake wont work.
FOSWMT
FOSWMT
PostSubject: Re: Puzzling Westwood Gazelle handbrake   Puzzling Westwood Gazelle handbrake Icon_minitimeJuly 29th 2013, 6:22 pm
Thanks for replying no its stock it de clutches then brake comes on its all stock at moment
Thanks for looking
FOSWMT
FOSWMT
PostSubject: Re: Puzzling Westwood Gazelle handbrake   Puzzling Westwood Gazelle handbrake Icon_minitimeSeptember 14th 2013, 4:14 pm
Have worked this out the bar that actuates the brake  is not threaded far enough up to allow the rod to travel back through the brake to engage hand brake . I have took it out and it needs taping down 1.5" . I think this rod was powder coated and the rod rusted the thread away when it was coated i am going to try to cut the 5/8UNF thread further up it. You can see with peda down nut backed all wa up its wrong
Puzzling Westwood Gazelle handbrake 56053111
Does anyone have a pic of the engine brake inhibitor switch bracket please as mine is missing
FOSWMT
FOSWMT
PostSubject: Have park brake working   Puzzling Westwood Gazelle handbrake Icon_minitimeSeptember 15th 2013, 11:23 am
Finally have park brake working . All it was was that the 5/16 UNF thread did not go up the bar far enough. Now I dont know if this was because it was corroded or was a wrong brake bar but threaded it up a further 1.5" and now works fine.
I need a picture of the brake inhibitor bracket if anyone has one I have only seen this so far on ebay
Puzzling Westwood Gazelle handbrake Kgrhqj11
FOSWMT
FOSWMT
PostSubject: Re: Puzzling Westwood Gazelle handbrake   Puzzling Westwood Gazelle handbrake Icon_minitimeSeptember 15th 2013, 1:48 pm
Found the place for the switch and the hole to feed the wire through chassis
Puzzling Westwood Gazelle handbrake Sam_3911
Have fitted brake rod:
Puzzling Westwood Gazelle handbrake Sam_3912
You can now get some idea how long it is supposed to be. I still need a bracket or a picture of one for the safety switch.
Can anyone help please?
» What's the minimum hp needed for my westwood gazelle
» Fitting Countax - X rims to front of Westwood Gazelle W11?
» Has anyone a pic of the safety brake switch location on Gazelle W11 Please?
» '86 Westwood T1200
All-Terrain Lawn Tractor Forum :: Technical Forum :: Drivetrain & Brake Tech :: Brake Support-
