 Fitting Countax - X rims to front of Westwood Gazelle W11?
FOSWMT
FOSWMT
Fitting Countax - X rims to front of Westwood Gazelle W11? Empty
PostSubject: Fitting Countax - X rims to front of Westwood Gazelle W11?   Fitting Countax - X rims to front of Westwood Gazelle W11? Icon_minitimeAugust 4th 2014, 11:19 am
Fitting Countax - X rims to front of Westwood Gazelle W11 as on rear
I successfully fitted Countax bolt on X rims to the rear adapters I put on my Westwood these are fabulous and are 18x9.5-8 2ply LUG these are 4 stud and brilliant . I was hoping to fit some to the front to level the chassis. The steering arm on the Westwood seems quite close to the small tyre. Will this arm fit inside my new wheels or will I have to mod it please. If I need to mod it what needs to be done
Thanks
FOSWMT
http://www.friendsofspeckledwood.org.uk
PostSubject: Re: Fitting Countax - X rims to front of Westwood Gazelle W11?   Fitting Countax - X rims to front of Westwood Gazelle W11? Icon_minitimeAugust 4th 2014, 11:38 am
can you put pics of it
FOSWMT
FOSWMT
PostSubject: Re: Fitting Countax - X rims to front of Westwood Gazelle W11?   Fitting Countax - X rims to front of Westwood Gazelle W11? Icon_minitimeAugust 4th 2014, 4:42 pm
Will do tomorrow
FOSWMT
FOSWMT
PostSubject: Re: Fitting Countax - X rims to front of Westwood Gazelle W11?   Fitting Countax - X rims to front of Westwood Gazelle W11? Icon_minitimeAugust 5th 2014, 3:06 pm
Fitting Countax - X rims to front of Westwood Gazelle W11? Dscn3514
As you can see the rack is nearly on the tyre
This is what I want to put on it
Fitting Countax - X rims to front of Westwood Gazelle W11? Dscn3511
FOSWMT
FOSWMT
PostSubject: Re: Fitting Countax - X rims to front of Westwood Gazelle W11?   Fitting Countax - X rims to front of Westwood Gazelle W11? Icon_minitimeAugust 5th 2014, 3:54 pm
Saw this video and it shows how to put larger wheels on:
https://www.youtube.com/watch?v=buRrOd8vz34
I noticed the steering arm is underneath on this toro I am presuming i need a mod. I am going to fit same Countax adapters
Fitting Countax - X rims to front of Westwood Gazelle W11? _1210
PostSubject: Re: Fitting Countax - X rims to front of Westwood Gazelle W11?   Fitting Countax - X rims to front of Westwood Gazelle W11? Icon_minitimeAugust 5th 2014, 4:51 pm
Only way is to try it. Try to space the tire out a little to clear the arm. Or make the arm taller to clear over the tire.
FOSWMT
FOSWMT
PostSubject: Re: Fitting Countax - X rims to front of Westwood Gazelle W11?   Fitting Countax - X rims to front of Westwood Gazelle W11? Icon_minitimeAugust 5th 2014, 5:00 pm
Hi Redlinemotorsports . I did think this but fab is going to be a little of a point as raising it will still likely to be a problem . The toro runs underneath I wondered if this would be better putting it in middle of the wheel ?
I wonder if someone has done this already this is my machine
Fitting Countax - X rims to front of Westwood Gazelle W11? Dscn3412
its a Westwood Gazelle W11E 1983
FOSWMT
FOSWMT
PostSubject: Re: Fitting Countax - X rims to front of Westwood Gazelle W11?   Fitting Countax - X rims to front of Westwood Gazelle W11? Icon_minitimeAugust 26th 2014, 6:56 am
I picked up these cheap would these be better for front. They have a 15mm bearing surface wich then fits a 32 mm bearing i think
Fitting Countax - X rims to front of Westwood Gazelle W11? Dscn3710
FOSWMT
FOSWMT
PostSubject: Re: Fitting Countax - X rims to front of Westwood Gazelle W11?   Fitting Countax - X rims to front of Westwood Gazelle W11? Icon_minitimeAugust 26th 2014, 9:42 am
Wood need to find 15,mm x 25.4mm bearings to fit my tractor hubs. Would they cope with wieght please?
rarbaugh07
rarbaugh07
PostSubject: Re: Fitting Countax - X rims to front of Westwood Gazelle W11?   Fitting Countax - X rims to front of Westwood Gazelle W11? Icon_minitimeOctober 31st 2014, 7:40 am
Or buy/have machined some bronze bushings you can adapt just about anything.
» Puzzling Westwood Gazelle handbrake
» What's the minimum hp needed for my westwood gazelle
» Make your own front 4 wheel drive axle?
» What are people using for front rims?
» Wanted bigger front tyres and bigger rims
