 What are people using for front rims?
Mr&Mrs.Reckson
dked41
swbeebe
8 posters
swbeebe
What are people using for front rims? Empty
PostSubject: What are people using for front rims?   What are people using for front rims? Icon_minitimeOctober 9th 2012, 9:50 am
I was wondering what everyone is using for front rims? I was trying to find some 8 inch rims, but they don't seem to have bearings. (Rear) I was thinking about installing a grease zerk and filling the keyway in with jb weld or something.
dked41
dked41
PostSubject: Re: What are people using for front rims?   What are people using for front rims? Icon_minitimeOctober 9th 2012, 12:33 pm
Filling the keyway is not neccessary,but go ahead and do it if you you have the time. Grease zerks are a must. I have been using 8" fronts from big MTD tractors , they have bushings and zerks. The rims from old cub cadets, sears, case, john deere, and others will have 8" bearing style front rims. Most older tractors with 12" bolt on rear wheels will have 8" fronts.
swbeebe
PostSubject: Re: What are people using for front rims?   What are people using for front rims? Icon_minitimeOctober 11th 2012, 10:09 am
Thanks, that is what I wanted to know.
Mr&Mrs.Reckson
Mr&Mrs.Reckson
PostSubject: what are people using for front rims    What are people using for front rims? Icon_minitimeOctober 28th 2012, 9:31 pm
try looking at northern tools and check ebay look at go cart rims thats what i use and they work really good cause they have high speed bearings
PostSubject: Re: What are people using for front rims?   What are people using for front rims? Icon_minitimeOctober 29th 2012, 7:42 pm
If its for plain regular running around thru the swamp/trails - stock rear wheels should be fine - a grease zerk could be fitted if its drilled and tapped.
If its for some high speed running around , definitely berings in the front hubs, not to mention making sure the wheels are locked on ( so wont come off) - when i was building a fast mod, i invested in some tapered bering hubs ( like on cars) for the front and some 4 bolt golf karts wheels - mine were like $40 each from northern tools - i bot some smaller hubs for 6" rims for another mod tractor - they were plain roller berings and a lil cheeper.
Jugghead90
Jugghead90
PostSubject: Re: What are people using for front rims?   What are people using for front rims? Icon_minitimeDecember 14th 2013, 2:43 am
I use my stock wheels and tires and made and a axle for it and it works just fine. It's been that way for about a year now.
PostSubject: Re: What are people using for front rims?   What are people using for front rims? Icon_minitimeDecember 14th 2013, 10:53 am
Check out my build thread, I have pics on my front hubs. I run 4.80x4x8 trailer tires at the moment. going to rear rim style soon with some 16-18" tires
PostSubject: Re: What are people using for front rims?   What are people using for front rims? Icon_minitimeDecember 14th 2013, 12:28 pm
Thread from the dead! LOL
I welded Posi-Lube trailer spindles in pace of the factory spindles. Then, triler hubs with a 4-on-4 pattern, which allows the use of any trailer wheels. In this case, I'm using 4.80x4.00-8 (16") snowblower meat.
What are people using for front rims? Spindl11
What are people using for front rims? Frontr11
PostSubject: Re: What are people using for front rims?   What are people using for front rims? Icon_minitimeDecember 14th 2013, 6:36 pm
JD/ Cub Cadet Stock rims with the 3/4" shapered ball bearings.
» What rims fit on a John Deere?
» welding rims?
» Fitting Countax - X rims to front of Westwood Gazelle W11?
» Wanted bigger front tyres and bigger rims
» need help with tires and rims
