 welding rims?
Hillbilly Homer
Hillbilly Homer
welding rims? Empty
PostSubject: welding rims?   welding rims? Icon_minitimeNovember 16th 2012, 1:45 pm
Question Ok this is for you guys that weld a big rim to a small rim how do you get the small one centered in the big one Question
CornishMorgan
welding rims? Empty
PostSubject: Re: welding rims?   welding rims? Icon_minitimeNovember 16th 2012, 2:36 pm
Are you able to put a metal bar through the center holes, kinda 1 wheel on top of the other and then weld it.
welding rims? Empty
PostSubject: Re: welding rims?   welding rims? Icon_minitimeNovember 16th 2012, 3:58 pm
Depending how the back of the larger rim is and how well the smaller rim will sit on it - the smaller rim might need to be trimmed to fit flush - best bet is to mesure from the smaller rim edge to the larger rim edge and make sure its the same all the way around .
Another way to make sure its centered is to make a jig from some wood ( easier to build) - a dowel down the center of the small rim, then a block bolted to the larger rim - slide the dowel into a hole in the larger block that is centered in the larger wheel's hub.
Id tack weld the smaller rim and make sure its centered before fully welding....
Hillbilly Homer
Hillbilly Homer
welding rims? Empty
PostSubject: Re: welding rims?   welding rims? Icon_minitimeNovember 16th 2012, 7:57 pm
Thank you. What i plan on doing is welding front mower rims to a car donut spare to level out the old merry. i am tired of always going down hill lol!
welding rims? DSCF0296
Hillbilly Homer
Hillbilly Homer
welding rims? Empty
PostSubject: Re: welding rims?   welding rims? Icon_minitimeNovember 20th 2012, 7:34 pm
i found two T117/70D14 that are shaped just wright. im going to drill the bolt pattern in the rim and bolt them together.
lol! i will post pics lol!
welding rims? Empty
welding rims?
» Need welding help!
» Welding help Needed..
» Welding problem please help!
» 4" Rims Alternatives
» What rims fit on a John Deere?
