 4" Rims Alternatives
2 posters
pursang
4" Rims Alternatives Empty
PostSubject: 4" Rims Alternatives   4" Rims Alternatives Icon_minitimeJune 27th 2021, 4:13 am
I'm looking for a set of 2 piece bolt together rims to replace the stockers on my Ford R8. does anyone have a souce for something like this?
Rustbucket Garage
Rustbucket Garage
PostSubject: Re: 4" Rims Alternatives   4" Rims Alternatives Icon_minitimeJune 27th 2021, 9:16 am
What is your spindle size? I presume you have 5/8 but if it’s 3/4 that might be something a tad bit harder to find.
5/8 and this should work.
https://www.harborfreight.com/material-handling/tires-casters/heavy-duty-10-inch-groove-tread-tire-40729.html
pursang likes this post
pursang
PostSubject: Re: 4" Rims Alternatives   4" Rims Alternatives Icon_minitimeJune 27th 2021, 5:25 pm
Thanks for the suggestion but unfortunately HF won't ship to my country and it's looking like I might have ¾" spindles, I'll see what I can find for bearings to fit that type of rim, or have the spindles turned down if I can find an oem spare set, or even have a brass bushing machined, I won't be using this R8 for any high speed stuff so grease fittings with brass bushings should work. time to check out a bearing house.
» New guy, first Off Road/ Utility tractor build.
» What rims fit on a John Deere?
» welding rims?
» need help with tires and rims
» New Sidebuild: JD210 - Racing Mower by the K.I.S.S. principle.
