 Need welding help!
5 posters
dylansrockinrigs
dylansrockinrigs
Need welding help! Empty
PostSubject: Need welding help!   Need welding help! Icon_minitimeJune 16th 2013, 12:22 pm
I'm new to welding I actually haven't ever used my welder yet so I was wondering if anybody could give me a few tips what I really need to know is what wire speed and heat setting to put it on for of welding a piece of a tube steel bed frame to some angle iron by the way it's a Clarke Weld 130 en
greener179
greener179
PostSubject: Re: Need welding help!   Need welding help! Icon_minitimeJune 16th 2013, 12:27 pm
my clarke 130 en i run a 5 on wire speed and a c thats on anything around 3/16 thats  just me tho.
dylansrockinrigs
dylansrockinrigs
PostSubject: Re: Need welding help!   Need welding help! Icon_minitimeJune 16th 2013, 12:29 pm
Ill try that. Do you run FCAW or GCAW
PostSubject: Re: Need welding help!   Need welding help! Icon_minitimeJune 16th 2013, 12:30 pm
Greener is right - most materials weld better on a/c settings. Only thinner body panels and lightweight materials bond well with D/C welding current. Be sure if it's a double-clamp type welder to not invert the polarity - as in the positive clamp on the metal and weld with the ground lead... it'll work but probably destroy your welder. Other than that, best thing is to practice on material that doesn't matter... a piece of flat steel, practice making penetrating beads 1", then 3" then 6". if you can do that in a straight line with a consistent bead you're golden.
PostSubject: Re: Need welding help!   Need welding help! Icon_minitimeJune 16th 2013, 1:50 pm
Sounds complicated. I just turn mine on, put it on low for the thinner stuff and mess with the wire feed till I get it right.
dylansrockinrigs
dylansrockinrigs
PostSubject: Re: Need welding help!   Need welding help! Icon_minitimeJune 16th 2013, 4:07 pm
I went out and started using it and it fit wires through until it got to the gun and then it started binding up does anyone know how to fix this?
PostSubject: Re: Need welding help!   Need welding help! Icon_minitimeJune 16th 2013, 4:42 pm
did you have the tip off? you have to thread it through the tip yourself
dylansrockinrigs
dylansrockinrigs
PostSubject: Re: Need welding help!   Need welding help! Icon_minitimeJune 16th 2013, 4:43 pm
Yea i had the tip off
PostSubject: Re: Need welding help!   Need welding help! Icon_minitimeJune 16th 2013, 4:49 pm
is the wire coming out at all?
PostSubject: Re: Need welding help!   Need welding help! Icon_minitimeJune 16th 2013, 7:08 pm
If its binding at the tip, I bet your tip is too small for your wire.
PostSubject: Re: Need welding help!   Need welding help! Icon_minitimeJune 16th 2013, 8:17 pm
Need welding help!
» which welding wire is better?
» Welding help Needed..
» welding rims?
» What Welder is the best for mower modding?
» Welding problem please help!
