| 94 mtd mudder/trail rider | |
+6Thunderdivine redlinemotorsportts Jerbear0612 Doug craftsmancole mudmonkey06 10 posters | |
mudmonkey06 Member
| Subject: Re: 94 mtd mudder/trail rider June 21st 2013, 9:14 pm | |
| - richie thomas wrote:
- mudmonkey06 wrote:
- i went against my inner feeling and put chains on my tires.
they run good, except for the fact that one belt keeps popping off.
out of curiosity, how hard and expensive is it to swap in a peerless. its not that hard, just have to line the stuff up, which means raising or lowering the motor, or tranny, as to cost, you'd have to price a tranny near you, id look for a mst, but the foote four speeds are nice too i also would need to make a new clutch and shift linkage right? that would be the hardest prt for me | |
| Subject: Re: 94 mtd mudder/trail rider June 21st 2013, 9:40 pm | |
out of curiosity, how hard and expensive is it to swap in a peerless. its not that hard, just have to line the stuff up, which means raising or lowering the motor, or tranny, as to cost, you'd have to price a tranny near you, id look for a mst, but the foote four speeds are nice too i also would need to make a new clutch and shift linkage right? that would be the hardest prt for me yea, shift linkage aint no problem if you still have your deck hight bar, but the clutch would be the hardest thing, best bet would be get on off the mower you get the tranny off of, i can do a vid on my shifted if you want so you can see how i did mine | |
| | | mudmonkey06 Member
Age : 28 Join date : 2013-03-18 Points : 4591 Posts : 327 Location : Rindge, NH
| | | | mudmonkey06 Member
| Subject: Re: 94 mtd mudder/trail rider June 25th 2013, 6:08 am | |
| i have a problem. whenever i get stuck and put it in reverse the top belt pops off. does anyone know why this is happening and how to fix it.
in all my years using shift on the go havent encountered this problem.
and it only happens in reverse | |
| | | Guest Guest
| Subject: Re: 94 mtd mudder/trail rider June 25th 2013, 12:20 pm | |
| Sounds like belt flex or at the most a stretched belt. check belt condition,.. or the belt alignment is off. check that all your pulleys are snugged down and look for twisted belt anywhere. |
| | | mudmonkey06 Member
| Subject: Re: 94 mtd mudder/trail rider June 25th 2013, 9:09 pm | |
| - prometheusEDI wrote:
- Sounds like belt flex or at the most a stretched belt. check belt condition,.. or the belt alignment is off. check that all your pulleys are snugged down and look for twisted belt anywhere.
ok ill do that in the morning | |
| | | k2500life Veteran Member
Age : 27 Join date : 2013-06-19 Points : 5368 Posts : 1135 Location : Southern Florida
| | | | mudmonkey06 Member
| Subject: Re: 94 mtd mudder/trail rider June 27th 2013, 6:35 am | |
| - k2500life wrote:
- Also it might need an extra tensioner pulley
im not too worried about the problem because i want to swap in a peerless withe the single belt system. its just annoying | |
| Subject: Re: 94 mtd mudder/trail rider June 27th 2013, 5:01 pm | |
| We had the same thing on my buddys silver mtd.. we ended up finding the belt was routed wrong.. also try putting it in first gear reverse and lifting the seat and remove battery why its running and watch the belt to see what it does. | |
| | | mudmonkey06 Member
| Subject: Re: 94 mtd mudder/trail rider July 1st 2013, 11:51 am | |
| have a new problem now. my engin is blowing out through the carb. does that mean i have a bad valve or could i just tighen it? | |
| | | mudmonkey06 Member
| | | | Sponsored content
| Who is online? | In total there are 27 users online :: 1 Registered, 0 Hidden and 26 Guests ranch king pro 08Most users ever online was 412 on January 7th 2023, 6:59 am |
