| Sears trail/mudder named Grace | |
mowerjunkie03 Member
Age : 20 Join date : 2018-10-29 Points : 2598 Posts : 342 Location : Burnt Ranch, California
| Subject: Sears trail/mudder named Grace May 17th 2019, 5:45 pm | |
| Here's the Sears Suburban 12 I picked up for free on Wednesday. It is missing the motor, clutch, alternator, gas tank, and gas tank plate. It's also a real rust bucket. I am abandoning the Craftsman GT and will probably return it to stock. I rather build the Sears any day. Here is the plan folks: 25×10-12 Kenda Bearclaws from Craftsman GT Locked 633a 11-15 hp clone 5in trans pulley 6in engine pulley New pan seat Rear utility rack Maybe different dash 19+in front tires(still undecided) Dark red and black paint. I'm sure I'm forgetting some thing but I'll go back to that later. Needs alot of clean up bust should be a great build. I already started to tear down and will have an update tonight. | |
| Subject: Re: Sears trail/mudder named Grace May 17th 2019, 9:30 pm | |
| - MightyRaze wrote:
- Nice and your ghost grille is in good shape!
Yes I'm very happy the fiberglass parts are in good shape. I don't love the dash tho. It just doesn't suit the build. | |
| Subject: Re: Sears trail/mudder named Grace May 18th 2019, 3:34 pm | |
| I finished getting it all taken apart and cleaning the frame up this morning. There is some pitting on the foot boards and on the frame under the dash were there had been a mouse nest. But over all it looks pretty good. I have no idea what the clutch is supposed to look like and where the pivot point is so if one of you Seras owners could help me out that would be great. Thanks! | |
| Subject: Re: Sears trail/mudder named Grace May 19th 2019, 12:19 am | |
| Another shot. Under the battery tray behind the engine is how mine was. You can see the linkage connecting to it. | |
| - MightyRaze wrote:
- There are a couple ways the clutch could have been.
Mine Is like: Hangs from the battery tray.
There was another way that bolted down on the frame. I don't have a pic of that.
http://www.stripmine.org/sears/ good source for manuals. Thanks Mighty! I did some research and learned that the clutch bolted to the engine on alot of them and that's probably why mine is missing. I need to know the distance from the clutch pulley to the pivot point to where the linkage pushes it. And about where the pivot point is according to the frame. No big deal tho. I can figure it out. Thanks again. | |
| Subject: Re: Sears trail/mudder named Grace May 19th 2019, 12:05 pm | |
| Okay I'm sure some one would have been willing to take some measurements for me but I am a very impatient person so I used a pic from a video by a YouTuber called Suburban Living and I knew the idler pulley was a 3in so I made a conversion to figure out the isze of the clutch. I'm just gonna try to make a copy of the original clutch but I still don't totally know where to pivot point should be since the battery tray is missing I have no reference point. | |
| Subject: Re: Sears trail/mudder named Grace June 9th 2019, 4:23 pm | |
| I've been neglecting this thread alittle because I haven't made any significant progress but I have been tinkering a bit. I got the 633a opened up so now I have the one from the Craftsman GT and the one from the Sears open and side by side. I had ordered a third diff gear to moose knuckle lock the GT and I destroyed my cast iron hubs gettin them off so my plan is to put the moose knuckle locked 6 bolt diff carrier with the spined shafts and steel hubs in the original roper 633a. The reason I'm not just putting the hole AYP 633a in the Sears it the mounts are wider and it doesn't fit. | |
| Subject: Re: Sears trail/mudder named Grace August 1st 2019, 12:01 am | |
| Well as I mentioned in the rally thread I have been neglecting my forum updates lately and I finally got back working on the Sears like 2 weeks ago so I'm gonna try to get y'all caught up on whats going on. So I started putting back together and I got it on all fours! I'm lovin the look! Nothin like a good Ghost Grille!! Obviously I'm gonna need to tear it down for paint in the end put I gotta build er up first. I modified the bumper I had made for the Craftsman GT to fit on here.
Last edited by mowerjunkie03 on August 1st 2019, 11:06 am; edited 2 times in total | |
Destructive Member
Age : 45 Join date : 2019-07-20 Points : 2024 Posts : 57 Location : King, NC
| Subject: Re: Sears trail/mudder named Grace August 1st 2019, 11:17 am | |
| - Destructive wrote:
- This Sears is starting to look rowdy! I love the front axle width, did you use 2x2x1/8" on it?
Thanks! Actually is the stock front axle I just cut off the lower brackets and welded all the sections that the factory skipped. Like along the sides of the spindle tubes. And I have just return from a slight leave of absence and I dont believe you were here before so welcome to the forums Destructive. | |
Destructive Member
| Subject: Re: Sears trail/mudder named Grace August 14th 2019, 2:21 pm | |
| Once again I fell behind on updates. I utilized some low quality materials fram a baby crib to make a rack. Like I said not great materials but with all the braces and triangle gussets it's quiet strong. I just need to get some grate for it. I finally got a motor!! Sort of... I brought home a old Honda GX270 from work so I could start mocking up my clutch. It's a junker but there is two other ones at work so I will probably take the good crank out of this one and put it in another one that also needs a rod and a governor. Not as easy as buying a Predator. But in the end I will have a good 8.5hp Honda for under 100 bucks. It fits quite well. People often use the GX340/390 which are slightly larger and much more difficult to fit. A GX270 is not quite as powerful but will get the job done! I have a question for y'all. I am considering running a 8in front pulley and my past experiences with large engine pulleys is that they don't disengage that well and are rather noisy when engaging. Could someone chime in and tell me there thoughts on this. Will it clutch fine or should I keep in under a 7in? Let me know. Thanks! | |
| Subject: Re: Sears trail/mudder named Grace August 14th 2019, 4:39 pm | |
| Great job on the tube work for that back rack MJ! Reminds me of a monster truck chassis, haha. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: Sears trail/mudder named Grace August 16th 2019, 1:07 am | |
| - AllisKidD21 wrote:
- Great job on the tube work for that back rack MJ! Reminds me of a monster truck chassis, haha.
Thanks AllisKid The tubing it self is vey weak but I focussed on good geometry and added the triangle gussets. I managed to make something very strong so I'm happy with it. My welder started acting up and is not working well at all so the welds aren't pretty but there strong. | |
| Subject: Re: Sears trail/mudder named Grace August 16th 2019, 1:10 am | |
| - MightyRaze wrote:
- I have run a 9 inch and it disengaged fine. Just make sure you have engine belt guides.
Okay I think I'll give it a try then I was just worried it would clutch poorly. Not to mention it increases the belt speed beyond what we usually do which puts more ware on belt, idlers, pulleys, keepers, but whatever. The rear is proving to difficult to swap so I think I'll give it a try. | |
| Subject: Re: Sears trail/mudder named Grace August 16th 2019, 1:23 am | |
| I tore apart the motor which turned out to be a GX240 and everything looks good. I brought home another motor from work which is a 270 and I was hoping to use the larger block but things already weren't looking to good... Nasty GX270!! Then I pulled apart the 270 and found a disappointing surprise. The governor blew apart and ruined everything!! Blew the cam, rod, piston, oil sensor, even the block is banged up. Oh well guess were building the GX240. Do you all think 8hp will be enough? I plan on porting the head and using a larger carb but I am going to us the governor so were limited there. Oh well can't win them all. I will not be discouraged! Thank you all for the advice and support! | |
| Subject: Re: Sears trail/mudder named Grace September 8th 2019, 11:47 am | |
| I got spacers for the Sears! They're 5×4.5×1.25. There only 1.25 in thick but I was worried any thicker would be to much for my trans. They should add some stability and improve my stance alot! I got some stuff from gopowersports.com for the Honda GX240. I got an air filter adapter so I can have a snorkel then have the pod filter up high under the dash or something. I also got a performance carb jet and some 35lb valve springs for it. I'm hoping to get alittle more rpm out of my motor so I can get the speed I want without running ridiculous pulleys. How much rpm do you think a stock honda rod can take?? | |
2019 Build-Off Entrant
1st Place Build-Off 2020
Age : 22 Join date : 2018-11-09 Points : 2855 Posts : 582 Location : Reeses Mill, WV
