| what should i do with my tires? | |
+3MowBandit truckin42 theswampmachine 7 posters | Author | Message |
theswampmachine Member
| Subject: what should i do with my tires? May 23rd 2013, 12:21 am | |
| i have carlisle tires they are knobby and probably about 3/4 of an inch tall. i am thinking about cutting them into someone like a V-Tread tire. what does everyone thing? | |
| | | truckin42 Veteran Member
| Subject: Re: what should i do with my tires? May 23rd 2013, 1:47 pm | |
| Well if you do that they will clean out better and clean out faster and mud wont stick as much to the tire. And you might get better traction. | |
| | | MowBandit Member
Age : 28 Join date : 2013-03-16 Points : 4746 Posts : 477 Location : Haddock,Georgia
| Subject: Re: what should i do with my tires? May 23rd 2013, 1:54 pm | |
| - theswampmachine wrote:
- i have carlisle tires they are knobby and probably about 3/4 of an inch tall. i am thinking about cutting them into someone like a V-Tread tire. what does everyone thing?
sounds like a good idea can we get some pics to compare the before and after | |
| | | Doug Site Owner
| | | | greener179 Member
| | | | LAWN MOWER MUDDER Established Member
| Subject: Re: what should i do with my tires? May 23rd 2013, 8:53 pm | |
| - Doug Fackler wrote:
- I would leave em.
I would just leave them as well because sooner or later you will regret it. | |
| | | Doc Sprocket Site VIP
| Subject: Re: what should i do with my tires? May 23rd 2013, 8:58 pm | |
| Yeah- If you mess them up or you don't like the results, you've just wasted a perfectly good set of knobbies. | |
| Subject: Re: what should i do with my tires? May 24th 2013, 10:23 am | |
| That is the only reason I dont really want to do them is because i feel like if i dont like it then i will have to spend more money on new tires. I have a professional tire cutter available to i could get it done right but im just not sure if im going to like them like that. | |
| | | Guest Guest
| Subject: Re: what should i do with my tires? May 24th 2013, 12:26 pm | |
| I would avoid it. I actually cut down a set of speed chains for a compact car to fit my tractors tires... Haven't tried them on the recent build but they should fit perfect as I had cut them a little on the big side for a standard tire... might want to look into that for mudding... |
