i got my craftsman with a honda swing arm like to put 31.10.50. on it anybody know how to make a wheel like that fit i thought bout cutting the center out of my wheels an welding them to my truck wheel or is there a 4 lug that fits a honda like a old toyota or something
If I remember right, the fox body fords from the mid 80's had 15" 4 bolt. not sure if the bolt pattern would be the same. you might check a wheel site for the bolt pattern of a 1985 cougar to see if it matches. 1050's might be too wide for the stock wheels on a road application, but could work on a low speed deal.
Jamus Established Member
Age : 45 Join date : 2010-06-28 Points : 5808 Posts : 511 Location : Southern WV
hey if i understand what your asking, i took my fenders off too fit my honda snow tires. what i did was take the mower wheel, remove the tire and then cut one side of the hub off leaving the center for the axle. then i measure 10 times and made sure the mower hub was perfectly centered in the middle of the honda wheel and welded it in place. with some washes/pacers and a little body cutting they fit and work great. now i just gotta work on making my pulley swap work because the belt keeps faliing off so i gotta make some belt holder things for it. GOOD LUCK! long live mowers
