 keyway in axle or new axle??
5 posters
dukas
keyway in axle or new axle?? Empty
PostSubject: keyway in axle or new axle??   keyway in axle or new axle?? Icon_minitimeMay 8th 2013, 2:12 pm
I wanna install a disc rotor on my axle but could i get a keyway cut into axle or should i just buy axle with keyway already cut
motorizedeverything
motorizedeverything
PostSubject: Re: keyway in axle or new axle??   keyway in axle or new axle?? Icon_minitimeMay 8th 2013, 2:32 pm
you could make them part of the rims
dukas
PostSubject: Re: keyway in axle or new axle??   keyway in axle or new axle?? Icon_minitimeMay 8th 2013, 2:33 pm
How?
motorizedeverything
motorizedeverything
PostSubject: Re: keyway in axle or new axle??   keyway in axle or new axle?? Icon_minitimeMay 8th 2013, 2:50 pm
make a flang that comes off of ur rim and have the brake rotor bolt on to that
dukas
PostSubject: Re: keyway in axle or new axle??   keyway in axle or new axle?? Icon_minitimeMay 8th 2013, 2:51 pm
Ok thanks
PostSubject: Re: keyway in axle or new axle??   keyway in axle or new axle?? Icon_minitimeMay 8th 2013, 3:10 pm
What type of axle are you using that isnt keyed?
The only thing about making the rotor part of your rim is that you want to make sure it is dead centered. Otherwise the rotor will "hop" and destroy your caliper.
dukas
PostSubject: Re: keyway in axle or new axle??   keyway in axle or new axle?? Icon_minitimeMay 8th 2013, 3:34 pm
The keyway isn't long enough
PostSubject: Re: keyway in axle or new axle??   keyway in axle or new axle?? Icon_minitimeMay 8th 2013, 5:24 pm
If you're careful about it, you can cut your own keyway. Having done this myself with great results, I offer the following-
This is best done with a Dremel or other mini die grinder. Use a speed square to mark the shaft, ensuring straightness. Mark the shaft with a scribe. Use a cutting disc to trace the scribed lines, cutting down no more than half the depth of the key. Switch to a grinding wheel, narrower than the key, and slowly hog out the material between the slots. Work slowly, using minimal pressure. Stop frequently to check your progress with a length of keystock, and to let the shaft cool.
PostSubject: Re: keyway in axle or new axle??   keyway in axle or new axle?? Icon_minitimeMay 9th 2013, 7:42 am
As doc said. I've cut my own, just take your time. Used an air grinder with cut off wheel.
» No Keyway? No Problem!!!
» 820 keyway size?
» Can I tow a LT without an axle with another LT? Maybe ...
» steering rod to axle help
All-Terrain Lawn Tractor Forum :: Technical Forum :: Drivetrain & Brake Tech :: Brake Support-
