 Peerless wont move, need help!
5 posters
Cr8zyB0b
Cr8zyB0b
Peerless wont move, need help! Empty
PostSubject: Peerless wont move, need help!   Peerless wont move, need help! Icon_minitimeApril 16th 2013, 11:35 am
I am new to building off road mowers but i have managed with every thing so far apart from the transaxle. It was sitting out side for over 3 years before i retrieved the tractor when under close inspection i found that that it would not move forward so i thought it was in gear checked that the gear shifter moved and it did i tried what was supposable neutral still no luck so i stripped the tractor from the mower and found that the wheels would only turn in opposite directions and both would not go the same way at the same time this would happen in all gears!! really don't now what to do and it has put my build on hold and i don't really want to shell out for a new transmission before i test every thing else.. PLEASE HELP
PostSubject: Re: Peerless wont move, need help!   Peerless wont move, need help! Icon_minitimeApril 16th 2013, 11:38 am
You'll probably have to disassemble the transaxle to determine what the problem is. I could be debris from something stuck in the gears, or could be rust (reverse chain?), or any number of things. Sounds like the axles are free and the differential is working.
Chaos Build
Check out the pics and vids!
Haspin 2021 thread
Haspin Acres Rally 2022!
TheRainbowBoxer on YouTube
Cr8zyB0b
Cr8zyB0b
PostSubject: Re: Peerless wont move, need help!   Peerless wont move, need help! Icon_minitimeApril 16th 2013, 11:43 am
When ever i spin the wheels it makes a sort of whoosing noise..
Cr8zyB0b
Cr8zyB0b
PostSubject: Re: Peerless wont move, need help!   Peerless wont move, need help! Icon_minitimeApril 16th 2013, 2:36 pm
greener179
greener179
PostSubject: Re: Peerless wont move, need help!   Peerless wont move, need help! Icon_minitimeApril 16th 2013, 3:17 pm
But as rainbow said the wheels going in different directiins is because it has a diff
xxXMowerdudeXxx
PostSubject: Re: Peerless wont move, need help!   Peerless wont move, need help! Icon_minitimeApril 16th 2013, 3:47 pm
Cr8zyB0b wrote:
Problem solved
https://i.servimg.com/u/f69/18/21/98/16/img-2010.jpg
So ur breaks were sticking? Or locked
PostSubject: Re: Peerless wont move, need help!   Peerless wont move, need help! Icon_minitimeApril 16th 2013, 4:06 pm
Frozen caliper. Thatll happen with a steel to aluminum mesh, and its a PITA to break free in most cases.
Your tires are supposed to spin in different directions, that is because of a differential. To get them to go the same way all the time, you need to lock it. Fearlessfront and a few others have tutorials on YouTube, and there are a few how-tos on the forum here as well.
Cr8zyB0b
Cr8zyB0b
PostSubject: Re: Peerless wont move, need help!   Peerless wont move, need help! Icon_minitimeApril 16th 2013, 4:27 pm
Yes the brakes pins where sized in causing the brakes to lock up I got them out and sand papered the pins.. thanks to every one for there help.
PostSubject: Re: Peerless wont move, need help!   Peerless wont move, need help! Icon_minitimeApril 16th 2013, 6:09 pm
Put some grease or never-seize on them as well.
» hydro lawn mower wont move.
» peerless 6 spd wont go back together
» clutch move?
» Help honda mower won't drive it try's to move but won't
» hydro trans will only move at vers slow speed
