| hydro lawn mower wont move. | |
Dustin138 Member
Age : 27 Join date : 2011-06-15 Points : 4972 Posts : 40 Location : Upstate NY
| Subject: hydro lawn mower wont move. June 27th 2011, 12:30 pm | |
| Every once in a while my mower wont move. when i release the clutch/brake it stalls the engine. It does not matter if in reverse,neutral, or foward. Some times if i wiggle the belt and move it a little the mower will start to move a again. But this time my mower is suck in a half foot deep mud and water. The mower was moving then i shut it off to get some thing then when i came back to start it, it started but stalled when i put it in gear. This happened beffore ussually it is when the mower is parked on a hill. It is a 2005 Craftsman lt1000 with the Kholer 17hp OHV engine with hydrostatic trans-axel. Any ideas???
| | | Guest Guest
| Subject: Lawn mower wont move June 27th 2011, 2:38 pm | |
| sounds like a stuck brake. wet belt will cause it to slip.. but not stall the motor. could be the hydro pump locking up too. |
| | | Dustin138 Member
| | | | Guest Guest
| | | | Dustin138 Member
| Subject: Re: hydro lawn mower wont move. June 27th 2011, 9:12 pm | |
| the button uder the seat so when you stand up the mower shuts off..that button... the button came loose..that was the problem | |
| | | Guest Guest
| Subject: Lawn mower wont move June 27th 2011, 9:25 pm | |
| It sounded like the motor was bogging down under load and dying. sorry for the bad info. I have heard that a friend of a friend ( not me) pushed the button in and shoved a cotter key in it and bent it over to jam the switch.( again not me , and I cant condone such actions) not safe on a go fast trail mower. if you flip it over and fall off, you dont want it running very long..but usually they will suck oil in the cylinder and die anyway |
| | | Dustin138 Member
| | | | noledroByrreK Member
Age : 30 Join date : 2011-01-14 Points : 5370 Posts : 252 Location : DFW Texas
| Subject: Re: hydro lawn mower wont move. July 14th 2011, 8:08 pm | |
| yea i ripped out all my wiring including the safety switches. then decided i wanted one encase i fell off so i rigged the under seat one back up. | |
| | | Dustin138 Member
| Subject: Re: hydro lawn mower wont move. July 15th 2011, 2:42 am | |
| yea i left every thing on because i dont know any thing about the wiring in lawn mowers and like i said i might be getting a mowing deck for it. | |
| Who is online? | In total there are 48 users online :: 0 Registered, 0 Hidden and 48 Guests
