| clutch move? | |
+2TheRainbowBoxer tman9114100 6 posters | Author | Message |
tman9114100 Member
Join date : 2013-03-17 Points : 4340 Posts : 45 Location : LaCrosse, WI
| Subject: clutch move? March 28th 2013, 10:03 am | |
| is there a way to move your clutch system from one side to the other? thanks for all your help!!! | |
Age : 49 Join date : 2012-04-23 Points : 5701 Posts : 1091 Location : Galion, OH
| Subject: Re: clutch move? March 28th 2013, 10:12 am | |
| Sure! You can move pretty much anything you want with a little fab work. You would just need to modify the linkage to operate it. | |
| Subject: Re: clutch move? March 28th 2013, 10:31 am | |
| Use a mirror nah, like he said, and keep in mind the push/pull feature. | |
| | | Doug Site Owner
| Subject: Re: clutch move? March 28th 2013, 6:37 pm | |
| The clutch operates best if its on the right side of the chassis. Otherwise, because of how the engine tunrs, the belt will fight against your clutch and you wont have as good of tension. Head Forum Administrator ** Chat Moderator ** Facebook Page AdminATLTF Facebook Page ** Chatbox ** How To Upload Pictures
| | | tman9114100 Member
| Subject: thanks March 29th 2013, 8:17 am | |
| Subject: Re: clutch move? April 2nd 2013, 7:46 pm | |
| - Doug Fackler wrote:
- The clutch operates best if its on the right side of the chassis. Otherwise, because of how the engine tunrs, the belt will fight against your clutch and you wont have as good of tension.
Not if you mirror it I guess, but if you where just to move it from right to left your correct.
Last edited by Thunderdivine on April 2nd 2013, 7:47 pm; edited 1 time in total (Reason for editing : Typos and bad choice of words) | |
| | | mudmonkey06 Member
Age : 28 Join date : 2013-03-18 Points : 4594 Posts : 327 Location : Rindge, NH
| Subject: Re: clutch move? April 2nd 2013, 8:04 pm | |
| to do this use a lot of imagination jk lol with a welder you can do almost anything lol | |
| | | Chopperhed Moderator
Age : 58 Join date : 2012-10-14 Points : 5254 Posts : 801 Location : Edmonton, Alberta, Canada Eh!
| Subject: Re: clutch move? April 2nd 2013, 8:48 pm | |
| Whenever possible, you want clutches and idlers on the slack side of the chain/belt
| | | | | clutch move? | |
| Who is online? | In total there are 53 users online :: 0 Registered, 0 Hidden and 53 Guests
