| monster mower | |
+13Mississippi1313 jackduup DICE464 Ropertractor14 Jamus NZHproduction Ford Boi Salt-Man Chunk dangeroustoys56 Webmaster motorhead45102 redzz02 17 posters |
Guest Guest
| Subject: Re: monster mower July 27th 2010, 5:45 am | |
| add a guard or a tensioner, this will be my problem when it comes to that! |
| Subject: Re: monster mower July 27th 2010, 11:09 am | |
| Could go with a tensioner setup off a snowmobile in the transmission- has the two 'pucks' and a spring between em. Or use a idler sprocket hooked to a lever arm and spring. | |
Guest Guest
| Subject: Re: monster mower July 27th 2010, 12:48 pm | |
| you could get a hold of one off a bike, that's my idea |
redzz02 Site VIP
1st Place Build-Off 2015
1st Place Build-Off 2017
1st Place Build-Off 2018
| Subject: Re: monster mower August 1st 2010, 10:17 pm | |
| i made my chain shorter and aligned it better and so far it has only poped once back in the woods so it is going good hopefully i can post pictures in the next couple days | |
Guest Guest
| Subject: Re: monster mower August 2nd 2010, 6:03 am | |
| yay just out of interest how big is the chain on it? |
redzz02 Site VIP
| Subject: Re: monster mower August 3rd 2010, 11:04 am | |
| stretched out from end to end it is about 2 1/2 feet long | |
Ford Boi Member
Age : 40 Join date : 2010-08-22 Points : 5465 Posts : 242 Location : Yarmouth, Nova Scotia, Canada
| Subject: Re: monster mower August 25th 2010, 1:35 pm | |
| That looks like a cool project, I like the long arms in front and I'm curious to see what you will fab to keep it stable. I have had something like this in mind for years, just never had the drive to do it lol. Good job, can't wait to see more progress! | |
redzz02 Site VIP
NZHproduction Member
Age : 29 Join date : 2010-08-28 Points : 5303 Posts : 120 Location : Davis Ca
| Subject: Re: monster mower August 29th 2010, 7:00 pm | |
| im wondering how is your steering arm hooked up so you can turn the wheels | |
Ford Boi Member
| Subject: Re: monster mower August 29th 2010, 7:24 pm | |
| Man those machines are friggin' sweet. I think when I get bored with my Rally I'm going to go bigger like yours! Good work guys I'm impressed. I want to see some action pics now tho | |
redzz02 Site VIP
| Subject: Re: monster mower August 29th 2010, 9:21 pm | |
| the steering works because on craftsmans the steering arm comes out from under the frame and not ontop of the frame and i welded a section onto the arm to make it longer and reach. and P.S. if you make one make the chain as short as posible and make sure you reinforce it alot so the chain doesnt pop every 2 feet back in the woods | |
Jamus Established Member
Age : 45 Join date : 2010-06-28 Points : 5803 Posts : 511 Location : Southern WV
| Subject: Re: monster mower August 29th 2010, 9:57 pm | |
| What did you use to custom cut your driver's side front tire? I'd like to remove a few lugs from my stock tires, maybe get some free traction. - redzz02 wrote:
redzz02 Site VIP
| Subject: Re: monster mower August 30th 2010, 3:12 pm | |
| i do not know thats how i got it sorry but when i do cut tires i just use a utility knife | |
Ropertractor14 Member
Age : 110 Join date : 2010-02-23 Points : 5468 Posts : 84 Location : Nova Scotia, Canada
| Subject: Re: monster mower August 30th 2010, 4:58 pm | |
| I used a carbide bur to cut a set of tires for one of my tractors. Quite messy, but it makes your tires look factory. | |
| Subject: Re: monster mower August 30th 2010, 5:12 pm | |
| Yeah, there's plenty of messy ways that are reported to work well. I'd like to find a cleaner way that doesn't require buying a tire groover. I wonder if a big kitchen knife would work if you sharpened it up really good. I can see myself breaking utility knife blades left and right. | |
Chunk Established Member
| Subject: Re: monster mower August 30th 2010, 6:10 pm | |
| Wow. Really dont do things half assed do ya buddy!?! Aeseom work. Got any more detailed shots of the front suspendion set up?
The lime green looks awesome too! | |
redzz02 Site VIP
| Subject: Re: monster mower August 31st 2010, 6:55 pm | |
| i have never broke one blade and i can take more pictures this weekend | |
redzz02 Site VIP
| Subject: Re: monster mower September 12th 2010, 1:58 pm | |
| hey sorry guys for taking so long but heres some more pictures of the front end and my new winch on it the bar going on a diagnal serves as a sway bar and keeps the axle from moving left to right the two bars running from the frame to the axle are the two traction bars, as you can notice the one closest in the picture has a l shape welded to the traction bar and is attached to the bottom of the front axle. this keeps the axle from twisting under and ripping your shocks in half in this picture you can see the steering arm closer and the mounting brackets for the traction bar(two pieces of angle) the steering arm needed to be extended this is all for now, hope it helped, and soon under the build section i am building another monster mower but it will be titled "Monster Mud Mower" this one will not be as tall and will be for masive amounts of mud and offroading | |
redzz02 Site VIP
| Subject: Re: monster mower November 27th 2010, 12:55 pm | |
| finally got around to making a shifter, one that you dont have to reachdown inbetween the belts, and not one you have to bend down at all to get too the linkages underneath it, it goes through the foot rest. its kinda like a suicide shifter, and i think its cool and somewhat different than most peoples shifters on mowers let me know what you think | |
DICE464 Member
Age : 28 Join date : 2010-07-30 Points : 5358 Posts : 129
| Subject: Re: monster mower November 27th 2010, 10:13 pm | |
| Nice shifter. Will the linkage underneath be safe? | |
redzz02 Site VIP
| Subject: Re: monster mower November 28th 2010, 9:08 am | |
| Sorry, I should have worded that better. I meant will it be up and out of the way of getting hit by anything on the trail? That thing is pretty tall so I guess it's not an issue. | |
redzz02 Site VIP
| Subject: Re: monster mower November 28th 2010, 11:57 am | |
| oo yea, my old shifter stuck down alot lower and didnt even come close to anything unless i was running over bushes and stuff but then again thats just like leaves and stuff, plus im not rockclimbing or anything like that with it, i built it for mud, deep water holes, and the occasional trail ride | |
redzz02 Site VIP
| Subject: Re: monster mower November 28th 2010, 8:12 pm | |
| You should make a skid plate for it so nothing jams up the shifter . | |
| monster mower | |
