| | husky 7 speed questions | |
+5dangeroustoys56 Doug Chopperhed cumminsbayou ibdalovely1 9 posters | Author | Message |
ibdalovely1 Member
Age : 45 Join date : 2012-12-27 Points : 4433 Posts : 92 Location : dayton ohio
| Subject: husky 7 speed questions February 12th 2013, 6:59 pm | |
| well ive found mowers with hydro trans and 4-5-6 speed transaxles but where dose the 7 come from this its a husky has a 12.5 briggs in it and a 42 inch deck probbaly gonna be a parts mower but is it a ok trans or they junk i will get pics up it got dark before i could take them | |
| | | cumminsbayou Member
Age : 27 Join date : 2011-11-04 Points : 4987 Posts : 232 Location : fairhope Al.
| | | | Chopperhed Moderator
Age : 58 Join date : 2012-10-14 Points : 5220 Posts : 801 Location : Edmonton, Alberta, Canada Eh!
| Subject: Re: husky 7 speed questions February 12th 2013, 11:02 pm | |
| Likely. It will have a weird ass variable drive pulley setup with a worn out Forward, neutral, reverse transaxle | |
| | | Doug Site Owner
Age : 29 Join date : 2012-12-24 Points : 7745 Posts : 3044 Location : Lebanon County, PA
| Subject: Re: husky 7 speed questions February 13th 2013, 12:07 am | |
| - Chopperhed wrote:
- Likely. It will have a weird ass variable drive pulley setup with a worn out Forward, neutral, reverse transaxle
In this instance the vari drive sucks. The transaxles are good though, you just dont have any extra internal gear ratios. Head Forum Administrator ** Chat Moderator ** Facebook Page AdminATLTF Facebook Page ** Chatbox ** How To Upload Pictures
| Subject: Re: husky 7 speed questions February 13th 2013, 12:32 am | |
| An F-N-R would work best with a Centrifugal clutch, or a sled style CVT
| | | ibdalovely1 Member
| Subject: Re: husky 7 speed questions February 13th 2013, 4:03 pm | |
| Mine was nearly identical before I stripped it down and started hacking it up | |
Age : 53 Join date : 2010-02-10 Points : 7042 Posts : 1726 Location : Florida, USA
| Subject: Re: husky 7 speed questions February 13th 2013, 4:42 pm | |
| Its an MTD - good thing about MTD's is theres plenty of room inside the chassis to mount another trans, the bad thing is the chassis is in two pieces ( front and back half) and it bolts together - if it were welded together and braced, itll be a good strong chassis.
The variable drive gets alot of flack, it has its issues sometimes, but it is a decent drivetrain , specially for simply mowing.
Im going to use a 2003 bolens chassis for the base of my rat rod tractor, itll be strengthened to handle a 18HP twin, straight rear axle and lowered stance. | |
| | | Doug Site Owner
| Subject: Re: husky 7 speed questions February 13th 2013, 5:17 pm | |
| Like everyone else said, its an MTD all right! I got two of those body style, the one is my racer and the one is pending. Head Forum Administrator ** Chat Moderator ** Facebook Page AdminATLTF Facebook Page ** Chatbox ** How To Upload Pictures
| | | ibdalovely1 Member
| | | | theswampmachine Member
| Subject: Re: husky 7 speed questions February 14th 2013, 2:02 pm | |
| Why is it everyone hates the variable speed axles? I have one on my mud mower and it works just fine. | |
| | | Doug Site Owner
| Subject: Re: husky 7 speed questions February 14th 2013, 2:07 pm | |
| - theswampmachine wrote:
- Why is it everyone hates the variable speed axles? I have one on my mud mower and it works just fine.
Experience. I hated mine, always burnt up my belt and slipped when I hit water. Head Forum Administrator ** Chat Moderator ** Facebook Page AdminATLTF Facebook Page ** Chatbox ** How To Upload Pictures
Age : 49 Join date : 2012-04-23 Points : 5667 Posts : 1091 Location : Galion, OH
| Subject: Re: husky 7 speed questions February 14th 2013, 2:49 pm | |
| Never tried to offroad one, but I like my geared transmissions a lot so no need to experiment | |
| | | Marines2621 Member
Age : 27 Join date : 2012-12-31 Points : 4549 Posts : 215 Location : Mountainburg, Arkansas
| Subject: Re: husky 7 speed questions February 14th 2013, 8:18 pm | |
| Mine says 7 speed. Its just a MTD transaxle with a vari drive on it. i wielded that crap and have a double pulley clutch up front | |
| | | Minimechanic New Member
Age : 27 Join date : 2013-04-17 Points : 4225 Posts : 16 Location : Maine
| Subject: Re: husky 7 speed questions April 18th 2013, 8:23 pm | |
| Okay so the problems with this set-up is that after constant use in the same gear the clutch will become worn in that spot and will slip (I've lost 7 and 6 on mine so far and i got it last summer, also another problem is the slipping once it hits water, the reason for this is the spring on the clutch isn't strong enough to keep ample tension on the belts, and it isn't really feasible to put tensioner pulleys on it because of the spring also. I put a stock murray deck pulley on the front of mine and left the stock 9 in on the back and it pretty much bypassed the clutch and it didn't slip all the way until it shredded the old rotten belt on the back, speaking of which does anyone know the dimensions of the rear belt? | |
| | | Marines2621 Member
| Subject: Re: husky 7 speed questions April 18th 2013, 11:11 pm | |
| I redid my mtd. Took out the vari-drive. Put one inch square on top of the transaxle. Between the chassis and transaxle. Have a double pulley clutch. Now I run a full belt. Haven't had and problems | |
| | | | Sponsored content
| Who is online? | In total there are 15 users online :: 0 Registered, 0 Hidden and 15 Guests
