 WHat everybody wantedfor a locked trans.
jaymz_eric
Murray modder
6 posters
Murray modder
Murray modder
WHat everybody wantedfor a locked trans. Empty
PostSubject: WHat everybody wantedfor a locked trans.   WHat everybody wantedfor a locked trans. Icon_minitimeDecember 31st 2012, 3:57 pm
I fingured out a DETACHABLE OUTSIDE LOCK! I havent tried it yet because I dont have the parts, but I can find any holes in it. What if you had a rod with ball bearing supports (fearless has what Im taking about holding his axle for the racing mower) Then you'd add to gears to the ends, (justline the ones INSIDE a trans case) on the ends, the bearing supports could be mounted DIRECTLY TO THE TRANS AXLE., as there are mounts for the transaxle to the frame) Lastly, youd need to weld, or machine the axles to hold a gear on each side. (these go on the axles for the wheels.) This would DIRECTLY link both wheels, thereof, not needing any welding, so NO crap inside the trans. Anybody punch any holes in this idea?
jaymz_eric
PostSubject: Re: WHat everybody wantedfor a locked trans.   WHat everybody wantedfor a locked trans. Icon_minitimeDecember 31st 2012, 4:34 pm
i get waht your saying, could work if done right, the bearing support device your refering to is called a pillow block by the way Smile
PostSubject: Re: WHat everybody wantedfor a locked trans.   WHat everybody wantedfor a locked trans. Icon_minitimeDecember 31st 2012, 4:40 pm
Seems expensive and unnecessary. You could buy a duplicate transaxle off a scrapped tractor for the same price or cheaper than having to do all of the mill work, as well as all the parts required.
Plus since the gears are exposed, you run the risk of seizing them with rocks, gravel, etc and since they arent lubricated they would get hot and wear quick.
Murray modder
Murray modder
PostSubject: Re: WHat everybody wantedfor a locked trans.   WHat everybody wantedfor a locked trans. Icon_minitimeDecember 31st 2012, 7:39 pm
I know you'd hae to have at least one spare transaxle or a bunch of spare gears. If the heat thing arised, Im sure you could revamp the entire thing to run off of chains and sprokets. and the only milling I was talking about is for the keyways for the gears/sprokets
Tractor Man Jeff
Tractor Man Jeff
PostSubject: Re: WHat everybody wantedfor a locked trans.   WHat everybody wantedfor a locked trans. Icon_minitimeDecember 31st 2012, 9:04 pm
In this hobby, a lot of stuff guys try is most of the time unnecessary. The point is to see how far and what kind of neat and sometimes wacky ideas we can attempt to try. Sounds like a neat idea. I'd be curious to see if it can be done.
PostSubject: Re: WHat everybody wantedfor a locked trans.   WHat everybody wantedfor a locked trans. Icon_minitimeJanuary 1st 2013, 5:56 pm
Sounds alot like the old 60's hot rods/drag racers using a 'quick change' rear end - the rear end has a cover , pop the cover and 2 'stubs' with the gears are actually separate from the main rear axle ( little or no gear oil comes out) and can swap gears almost instantly.
This is what one looks like:
WHat everybody wantedfor a locked trans. Hailbr10
Marines2621
Marines2621
PostSubject: Re: WHat everybody wantedfor a locked trans.   WHat everybody wantedfor a locked trans. Icon_minitimeJanuary 6th 2013, 1:31 am
Use them hot rod rear ends for IMCA Modifieds. Cause of the quick gear changes. Used in all kinds of stock cars lol. Had to add that in
» locked axle??
»  Tranny locked up under pressure?
» locked my transaxle
» LOCKED TRANSAXLE
» peerless locked up?
